The HE washer started flashing F Then H and said 14 minutes remaining. I tried stopping it, no avail, I tried opening the door, Couldn't, I even unplugged it for over a half an hour and it goes back to normal load but I hit start and nothing?? lights go on but no water, (It sounds like water but I don't see any) Please help it my boyfriends washer and I need to figure this out b4 he gets home?? THANK YOU
  • Washing Mach... Master
  • 8,220 Answers
FH: If after 30 seconds the control does not detect water entering
machine, the valves will be turned off and the error code will be
displayed. OR If the control has turned the water valves on and after
8 minutes the flow sensor has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
If there is no water in the unit:
-Make sure that both valves at the water source(s) are turned
on all the way.
-Check for plugged or kinked inlet hoses or plugged screens in
the inlet valves.
-Verify inlet valve operation.
If there is water in the unit:
-Verify drain pump operation.
-Verify that the pressure switch hose is in good condition and
properly connected to tub and pressure switch.
1. Verify there is not a siphon problem.
2. Unplug washer or disconnect power.
3. Verify wire harness connections to inlet valves,
pressure switch, drain pump, flow meter, and
Central Control Unit (CCU).
4. Check all hoses for possible leaks.
5. Plug in washer or reconnect power
6. Verify pressure switch operation.
7. Verify flow meter operation by blowing air through the part and
measuring the resistance.
8. Verify CCU operation by running a Diagnostic test or any cycle.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on May 27, 2011
Kenmore Elite HE5t Washer stops in the middle of cycle with no error codes. Any idea how to fix?
sounds like the door switch either needs adjusted or totally replaced .try leaning against .next time instead of opening it
Aug 24, 2015 | Kenmore Elite HE5t Washer
Indesit IWD7145K Washing Machine Error code F06 flashing on digital display + all program indicator lights. What does this mean. There is no such error code in the troubleshooting section of the manua
F06 - Door lock fault
Issue: Washing machine door cannot be opened or closed/when the door is closed the machine the programme will not start.
Advice: If your washing machine door will not close, please check for any obstructions in the door lock.
OR,
Switch off the device. Disconnect power. Wait about 3 minutes.
Open the door, then close. Reconnect device to the network.
Start device.
Cause: Door lock fails to close / open door lock triac open / closed,
frequency signal fault
Dado
Feb 12, 2015 | Indesit Washing Machines
Its a whirlpool 6th sense washing machine no awd/d 5706, it stopped with a full load in 8 minutes before end time no numbers are flashing up but it wont do anything , i have opened the door took washing...
i have a whirpool 6th sense washing machine and it wont spin and the timer stays on 14 minutes remaining have you come across this problem and do you have a cure
Jul 29, 2010 | Whirlpool Washing Machines
Washer frequently stops cycling at 14 and 27 minutes remaining
I have the same exact problem... can't believe it's just me. I too would love to know what's wrong with this machine! Is their a recall for this???
Sep 04, 2009 | Maytag Neptune MAH9700 Front Load Washer
Whirlpool Duet stopped during wash cycle.
UNPLUG THE WASHER AND TAKE THE 3 SCREWS THAT ARE ON THE BACK OF THE WASHER OUT AND REMOVE THE TOP PANEL OF THE WASHER. CAREFULLY UNPLUG AND REPLUG IN THE WIRING SO THAT U WONT GET THEM MIXED UP. DO ALL OF THEM, FIRMLY BUT GENTLY. THEN HOLD IN THE SIGNAL CYLCE LITE FOR 3 SECONDS. TRY TO RUN A LOAD AND SEE IF THAT WORKS. IT DID FOR US, SO FAR SO GOOD. GOOD LUCK!!
May 30, 2009 | Whirlpool Washing Machines
Duet washer stopped during wash cycle.
take off the panel below the door three screws and look for the tech sheet located on the right side. It will coach yoou thru the codes and common problems. Sounds like it may be the door swithch does it lock when you push the start? If not the door switch my guess would be a machine control. 877-262-1479 parts.
May 30, 2009 | Maytag EPIC MFW9700S Front Load Washer
When pressing the start button a "DL" indicator flashes and then a "F" indicator remains, door does not lock and the washer will not start.
that is the code for door lock. ensure its not stuck or something in rubber boot stopping door from closing all the way and try to reset it.
maybe by unplugging it for a coupkle of minutes
May 24, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Intermittant trouble with code d 11
Answer Duet HT®
Duet®
duet_f_dl_actualsize.gif Duet SportTM
This error code indicates that the door is not locking.
Is the washer door firmly shut?
The door must be completely closed for the washer to operate. The door may look as if it's closed, but it may not be latched. Open the door and firmly close it.
Were you washing a large load?
Before you close the washer door, check for laundry items sticking out beyond the door opening. Leave enough space in the washer to allow the clothes to freely tumble. Reduce your load size if needed.
fl_doorseal.jpg To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, and all of the other conditions above have been checked, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
44 people viewed this question
Top Washing Machines Experts
