Question about Philips GoGear ViBE Digital Media Player
How do I fix a loose headphone jack. when I plug in my headphones it has a bad connection and I have to tape the headphone tight fitting into the jack. I have replaced the headphones but that was not the issue.
SOURCE: Headphone jack issues
The Marv is right about these being delicate. My little MP3 player's headphone jack developed a bad connection where it was soldered to its tiny little internal circuit board. If you're good at soldering and have great hand-eye coordination, then you might give it a try. Remove the battery from the player, first. Carefully disassemble the unit, check out the connections, and solder away. Be careful not to get solder across points that shouldn't be connected. You have little to lose, if the player is frustrating you to the point where you are about to chuck it in the trash, anyway.
Posted on Aug 25, 2007
ThaMp3Doctor
  • 8596 Answers
SOURCE: NO sound??
Make sure the volume is turned up sufficiently. If it is, then get it exchanged if still in warranty.
Posted on Apr 08, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: head phone jack only plays right side/brad new headphones
Call Philips, get replaced - this is a common problem across all mp3 manufacturers. You can look at the YouTube video on repairing mp3 player headphone jacks, but i doubt it will work without causing more problems with your mp3 player.
Posted on Aug 26, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: NO sound??
Recovery Mode for Philips' GoGear
Open the Philips Device Manager (Start à All Programs à Philips Digital Audio Player à SAXXX à Philips Device Manager) and click on the “Repair” tab. Then click on the “Repair” button to start the repair process. Most of the time, when your player is in that state, the Device Manager will not recognize that your GoGear is plugged in. If this is the case: Disconnect the player from the PC, and make sure the mp3 player is turned off. Hold in the volume + button on the mp3 player, and reconnect the player to your pc while holding in the volume + button. Continue holding the volume + for 10-15 seconds until a "Found New Hardware Wizard" pops up. It should recover your device if there isn't anything internally wrong with the player. Warning: this procedure will result in your songs being erased off the player, so they will have to be reloaded.
-Tha Mp3 Doctor
Posted on Nov 25, 2008
  • 8 Answers
SOURCE: HEADPHONE JACK DOES NOT WORK
what kind of headphones do you have??? some Mp3s cannot supply enough power to those big headphones out of the market right now... try to use a earbud or earphone first and if they are not working it means that the jack is defective
Posted on Sep 07, 2009
I want to connect a Sony Wireless headphone to the receiver w/o disabling the speakers.
Normally you shuould connect the headphone inserting the plug in receiver's jjack. If you've gou no jack, you can't use the headphone
Jun 02, 2015 | Onkyo TX-DS474 Receiver
Have a cassette walkman that will only produce sound on one side of the headphones when jack is put into the outlet for the headphones. i know it's not the headphones because i've tried other ones too...i...
Hi ya
Well Aiwa stereos are very hard to open and designs to break when opening, however some models can be opening without too much issue.
So before you try to open the item, try these if you have some switch cleaner or alcohol tape head cleaner - put a little drop onto the headphone jack and insert and move around the socket just incase there is dirt on the contacts inside, also clean the tape head too just incase of the same,
if not then its an open up, sometime the solders come loose, so with a soldering iron just warm the solders up a little this may fix it.
if this does not it may be a broken part inside the jack - they can be replaced but not easy - spares can be got from ebay from china, for about 1.00gbp
hope this helps
Feb 14, 2014 | Aiwa HS-PS40 Personal Cassette Player
How to use headphone? I entered the headphone socket but the sound is not come out the Head phone
MAKE SURE STATION IS ON AND VOLUME IS UP. CHECK FOR CRACK WIRING AND LOOSE CONNECTION AT BOTH ENDS. PLUG JACK FITS PROPERLY AND NOT LOOSE.
Aug 16, 2013 | Samsung I9100 Galaxy S2 Speaker Headphone...
Headphone jack does not make a good connection
I have a couple of these players and have found that some headphones do this and some do not, maybe try a different pair and see if they fit any better, if the player is new you could think about returning it.
Mar 23, 2009 | SanDisk Sansa E280 MP3 Player
Loose headphone jack
if there isn't screws to take the MP3 player apart then their are clips on the inside
Unscrew the screws (or if you have clips from the on/off switch use a screw driver to open it. this isn't the most safest way to open it i could break so this is a last opption.)
ussing a sodering iron resoder the conection between the loose headphone jack and the curcit board.
(you can pick up a sodering iron at Radio shack for as low as 10$)
Oct 19, 2008 | Samsung Yepp YP-P2 Digital Media Player
Headphone issue on Zen Micro.
you have a loose connection on your headphone jack, need to solder the jack back in place.
Dec 07, 2007 | Creative Labs Zen Micro MP3 Player
Although headphones jacks are convient. They are very delicate as well. It take very little pressure agaist the jack when plugged in to bend the pins inside the jack that makes the connection. Then they get temermental. Generally the only recourse is to replace the headphonejack in the unit. better left to the techs. replacing can be tricky. But just to make sure you say you have tried other units. Here is something that works once in a great while. Unplug the unit dip the headphone jack {the tip on the headphones} in rubbing alchol insert it in the jack on the unit and spin it repeat several times let alchol evaporate then stick jack back in unit an spin again. Plug unit back in and see if it is better or the same.
Aug 05, 2006 | Mach Speed Trio DA-8033 MP3 Player
Philips GoGear ViBE  Digital Media Player Logo
262 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
