Question about Garden
My craftsman LT 100 does fine on level surfaces, but on the slightest incline it will not pull itself. Please help me solve this problem. Thanks
  • 407 Answers
Could be one of two problems.The drive belt may be stretched,and worn.Or the tires may have tread worn to much.I would start by checking the drive belt.With the mower off,and in gear.Reach in and make sure the drive belt is tight.If it is not,replace it.
Posted on May 27, 2011
Cub cadet trouble shooting
low on trasmission fliud replace right away with new filter
Jul 09, 2014 | Garden
Husqvarn lgt2654 wont pull
Make sure the drive belt is routed right. Go to partstree.com click on
husqvarna and put in your model number and click on the drive scematic and it will show the routing of the belt.
Jun 23, 2012 | Husqvarna Lawn Tractor - 54in. Deck, 26...
I have a 42" Craftsman
HI IF YOUR BELT IS LOOSE THEN YES YOU NEED A NEW BELT
IT IS A V-BELT GROUND DRIVE-95 25
PART /160855
Sep 02, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Dvd is stuck will not come out it is just spinning
>>> Please leave feedback so I can continue helping You & Others
LOOK FOR A SMALL HOLE IN THE FRONT TO PUSH A PAPERCLIP INTO, BUT TURN THE UNIT OFF FIRST. Try pulling the car fuse out, will have stereo/radio written on fusecase.
Thanks,
Adam.
Feb 19, 2011 | Soundstorm SDVD-100 Car DVD Player
I have a Pride Victory scooter that suddenly does not have enough power to pull even a small incline. It does fine on a paved level surface. It has two new batteries which are fully charged and load...
HELLO,VISIT :WWW.ALLDATASHEET.COM ITS WHAT IT SAYS IT IS ALLDATA ON ANYTHING,ITS FREE & TYPE IN YOUR PRODUCT & DOWWNLOAD THE TROUBLESHOOTER FOR IT,THE PDF VERSION.HAVE A NICE DAY COLI.N.
Dec 01, 2010 | Pride Mobility Victory 3 Wheel Electric...
From start the ecceleration is very slow.tac wants to go to 4 , the car is barly moving . the car is fine at higher speeds, but slows up at the slightest incline
Transmission may be slipping. Check transmission fluid level. Make sure you read the dip stick for specific instructions for your vehicle. Most cars are checked while the engine is hot at idle with the transmission in park.
May 17, 2010 | 2001 Mercury Cougar
GSXR 400 rev problem
The float level in your carb probably needs to be adjusted. If the gasoline level in your float bowl is borderline low, your bike may run fine when level. But on the incline, the gas level at the jet may be too low causing your engine to be starving for gas. The solution is to remove the bowl and bend the tab on the float that pushes the valve up so that the gas won't shut off until the level is higher. If you are a good mechanic, you may try this yourself. If not, take it to someone who can do this for you.
Nov 04, 2009 | 1998 Suzuki GSX 400 Impulse
Won't back up!
well slipping in reverse would be tranny...;but by saying the engine spits,,,sputters ,,,stalls,,,,sounds like engine not enough power to drive it in reverse...i'm guessing forward no problems...first thing comes to mind is in reverse engine moves on motor mounts as you give it gas..could be wiring harness rubbing on block causing short condition..when in forward engine moves opisite direction...while idling in park, shake wiring harness all over different spots see if you can simulate the condition.....are there any engine codes....also does it have a problem in reverse on a flat surface... or only on a incline....if only on an incline check fuel pressure while in reverse on incline.. see if loosing pressure for some reason..on incline fuel goes to lowest part of tank...
Oct 15, 2009 | 1991 Mercury Capri
I need to replace the fuel filter on a 1993 buick regal. Where is it located? I think I have found it but can see no way to remove the old one?
Husband found it but it did not solve the problem. But we can now hear the pump energize but the car still will not crank over and start. It acts like it is going to but just dies right away. This problem first started whenever I would go up the slightest incline, it would start running rough. Then on level surfaces it would go back to running fine and then one day it just would not start. Any suggestions?
Dec 07, 2008 | 1993 Buick Regal
Garden Logo
66 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
