Question about Microwave Ovens
Flavia coffee maker is not working. It is just blinking.
2 Suggested Answers
SOURCE: Clean light keeps blinking on
push reset button on coffee maker
Posted on Sep 13, 2011
ALL LIGHTS ON MY KEURIG ARE BLINKING. I UNPLUGGED THE UNIT BUT WHEN I PLUGGED IT BACK IN, SAME PROBLEM. JUST BEFORE THE BLINKING STARTED, WATER WENT THROUGH THE BREW CYCLE BUT NO BUTTON WAS PRESSED NOR...
your coffee maker is damage.it has a faulty ic and transistor probably the whole little circuit is burned out .so my advise is to buy a new one if you dont want to get it repaired.good luck.
Sep 25, 2011 | Microwave Ovens
My Kuerig coffee maker putters out the coffee, there is no fluid stream of coffee like before. The coffee maker makes the sound like coffee will come out but then there is nothing but drops.
try runing a descaler throgh it first,see if that solves the problem, after a lot of use scale builds up in most applianced using hot water
Jul 29, 2011 | Microwave Ovens
We have a Mr Coffee 10 cup thermal programmable coffee maker COF FTTX95-1 The clean light is blinking and I can't figure out what else to do. HELP!
When the clean light is blinking it is saying that the tubes are blocked up with mineral deposits. If you waited until the light in blinking then it is going to take some time for a vinegar clean to work.
Just put vinegar where you normally put the water, and let it perk about 1/3 of the water through, and then shut it off for 30 minutes. Then restart and let it perk another 1/3 through. Let set for 30 minutes. Then let it complete the cycle.
Take a look at the output vinegar, if there is a lot of chunks in it, strain it using a coffee filter and then reuse the same vinegar and do it again. Keep repeating until the light is out and the vinegar no longer get the chunks.
Jul 13, 2011 | Microwave Ovens
How do you go about "descaleing" the coffee maker? The water does not flow through the coffee capsule very well.
I know that most grocery stores sell a "cleaner" or two next to their coffee filters/coffee makers/kitchen appliances section. These are usually heavily acidic, and will do a great job of cleaining your coffee maker. I've always been wary of acid in my coffee though, so I just use white vinegar. It'll do a decent job of cleaning out the coffee maker. Run a 1:1 mix of water and vinegar through your coffee maker, drain it, then run water through at least twice.
Scaleing/deposits building up in a coffee maker are signs of imperfections in the water. All tap water has it, but if you don't want to worry about it, use bottled or filtred water in your coffee pot. Plus, your coffee will taste better!
Mar 16, 2011 | Microwave Ovens
How to program my Hamilton beach Coffee Maker,49464 To make coffee in the am before I get up.
12 Cup Programmable Coffee Maker 49464 could help you to operate your Hamilton Beach Coffee Maker. Anyway, if you are looking for a best coffee maker that can extract a perfect cup of coffee, allbestcoffeemakers.com is a great choice. Hope it helps you!
Nov 30, 2010 | Hamilton Beach Microwave Ovens
Coffee maker DCC-2000 will not keep coffee hot,have change the auto off time no effect.
Well the procedure to set the auto button off would be as follows. First set to 0 so it shut off as soon as it started brewing. Once the switch is turned to auto off, then when the numbers are blinking hit the hour button until you get the desired hours you want the heating element to stay on. If this does not keep the coffee warm then most likely you have a heating element down and will need to replace it. Please let me know if this does not help else please accept it.
Thank You for contacting Fixya.com
Mar 03, 2010 | Cuisinart Microwave Ovens
Kenmore Microwave / coffee maker leak
I have a Kenmore Microwave with built int coffee maker (Model 721.63999303). The coffee maker works, but the microwave doe not. Can the microwave be fixed ?
Apr 12, 2008 | Kenmore 63993 Microwave Oven
Microwave Ovens Logo
117 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
