Question about Epson Stylus Pro 4000-PS InkJet Printer
How to unclog nozzle on epson stylus pro4000 - Epson Stylus Pro 4000-PS InkJet Printer
  • Epson Master
  • 4,341 Answers
Try rubbing alcohol on a cotton swab.
Posted on May 27, 2011
Why won't it print or scan?
How To Unclog Brother Multifunction Inkjet Printhead Nozzles
www.inkmagic.com/shopcontent.asp?type=Unclog...Inkjet_Printhead...
Many Suggestions and Directions to Unclog you Brother Multifunction Inkjet ...problem when a new cartridge is put in, your Brother printer will do a priming. ... So, before you blame the compatible cartridges for your Brother printer not printingproperly, ... Many companies want you to believe that "one ink does all printers".
How to Unclog Epson Printhead Nozzles - - InkMagic ...
www.inkmagic.com/epson_clogged_printhead.htm
Clogged nozzles - Epson printers Epson printers have a built-in, permanent printhead.... To overcome this problem when a new cartridge is put in, your Epson printer ... If you manage to get all nozzles printing after 6, 8, 10 or more cleanings your ...InkMagic International remanufactured 2,000 - 4,000 HP inkjet cartridges a ...
All-In-One Printer Fails To Print Black Ink? - Super User
Jan 05, 2016 | Epson Inkjet Multifunction Machines;...
When printing lines appear
when printing, if there is while line appear, please perform Nozzle check to see if there is any missing dot, if yes, perform head cleaning to unclogged your print head.
Jun 12, 2010 | Epson Stylus CX4800 All-In-One InkJet...
I cannot get the nozzles unclogged. I replaced
If head clean doesnt work, have you tried any other cleaning from printer software??
If no go you may have damaged the printer head.
Jan 27, 2010 | Epson Stylus C88 InkJet Photo Printer
Does not print
***hi there,il be willing to help you on that. ****
the nozzles of the printer might be clogged by dried inks thats why when your printing, its feeding the paper, as if its printing but no inks on the paper. print a nozzle check to see which part or color have clogs, if there are gaps or breaks, do head cleaning untill no more gaps then try printing.
Running a Printer Check
1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus NX100 Series. 3. Hold down the nx100_tx100_ug.1.96.1.jpg Stop button as you press the nx100_tx100_ug.1.96.2.jpg On button to turn the Epson Stylus NX100 Series back on. Hold down both buttons until the nx100_tx100_ug.1.96.3.jpg On light begins to flash, then release the buttons. 1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus NX100 Series. 3. Hold down the nx100_tx100_ug.1.96.1.jpg Stop button as you press the nx100_tx100_ug.1.96.2.jpg On button to turn the Epson Stylus NX100 Series back on. Hold down both buttons until the nx100_tx100_ug.1.96.3.jpg On light begins to flash, then release the buttons. 1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus NX100 Series. 3. Hold down the nx100_tx100_ug.1.96.1.jpg Stop button as you press the nx100_tx100_ug.1.96.2.jpg On button to turn the Epson Stylus NX100 Series back on. Hold down both buttons until the nx100_tx100_ug.1.96.3.jpg On light begins to flash, then release the buttons. 4. Check the nozzle check pattern that prints to see if there are gaps in the lines. nx100_tx100_ug.1.96.5.jpg 5. If there are no gaps, the print head is clean and you can continue printing. If there are gaps or the pattern is faint, clean the print head. If your printouts are unexpectedly light, or dots or lines are missing, you may need to clean the print head. This unclogs the nozzles so they can deliver ink properly. Print head cleaning uses ink, so clean it only if quality declines.
You can also clean the print head by holding down the stop button on the printer for three seconds. (This only works when the red ink light is off.) Run a nozzle check to confirm that the print head is clean.
Caution: When you don’t turn on your printer for a long time, print quality can decline, so turn it on and print a few pages at least once a month to maintain good print quality. ***if my troubleshooting steps are helpful, pls vote for me, i will appreciate it, so that I can be a part of fixya, thanks, Godbless****
Jan 10, 2010 | Epson Stylus NX100 InkJet Printer
Unclogging my printer it does not print
do this with a little bit of care, put your mouth on the little hole on the side of the cartridge while covering the other one the on the same side and ~blow~ some strong air in just enough to get the ink out of the nozzles.
if that does not work, next time save money and get you a refill kit like this from amazon.com ( I don`t work for them)
http://www.amazon.com/Refillable-Specially-Formulated-equivalent-individual-cartridges/dp/B000Y5D65W
Mar 31, 2009 | Epson Stylus CX3810 All-In-One InkJet...
Won't Print
Sounds like print head issue; have it serviced or u can try this :
How to Unclog Epson Print Heads
Jan 21, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Epson Photo R265 Lines every 2.5 cm
check if those lines matches the positions of the rollers inside the printer - you can see some of them by opening the cover
Dec 24, 2007 | Epson Stylus Photo R340 InkJet Printer
Epson photo ex head clogging
Hey Bob Get in touch with the http://www.TheServiceManualShop.com and ask them abouth the manual cleaning methods for your printer. They have a document that is very discriptive about cleaning clogged nozzles.
Apr 10, 2007 | Epson Stylus Photo EX InkJet Printer
Epson Stylus Pro 4000-PS InkJet Printer Logo
91 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
