Question about Samsung SCX-6322DN All-In-One Laser Printer
Scanner locked/scanner error - Samsung SCX-6322DN All-In-One Laser Printer
  • 830 Answers
Check to see if the lock slider is in the locked position. If it is unlocked then something is preventing the scanner to move. Some machines have a plastic strip that can come unstuck on the inside of the glass for the adf. The contact image sensor hits the plastic and prevents its moving to its home position, hence the error message.You need to remove the rear, left and right covers. Next the top covers. the operation panel is next and lots of screws. Finally the glass and its frame come off. you should be able to see what the problem is now and correct it.
Posted on May 27, 2011
Scanner led 110 error code: 217916
the cause is that usb cable supplies power to scanner(there is no power cable) and therefore can not be much long, plug the original cable from scanner directly to USB port in your PC and it will be working correctly. If you use additonal cable to connect scanner to your pc you wil get the error code
Jul 28, 2012 | Canon CanoScan Office Equipment & Supplies
I have canon DR-2010C scanner which gives error after some times.my system is vista.the error is "The device could not be locked. Check to see that another application isn't using the device...
Question
canon DR-2010C scanner which gives error after some times.my system is vista.the error is "The device could not be locked. Check to see that another application isn't using the device -4630".
Answer :- change USB cable which is connect with scanner to PC or laptop definitely it will resolve.
By:- shyam shyam.lal@teamcomputers.com 9210845186
Sep 13, 2011 | Canon DR-2050C Path-Through Scanner
Scanner does not work. 12 scanner error on the display
scanner does not work. 12 scanner error on the display
Jun 25, 2010 | HP LaserJet M1005 Printer
My cx3200's control panel reads scanner error. I unlocked the transportation lock, turned off, turned on. It stayed off for about 2 minutes then came right back on. While the error light was off tried to...
The only things that can cause a scanner error on this unit is a complete scanner harware failure or the scanner lock. With the unit on lock the transport lock and unlock it a few times quite forcibly. Then leave it in the unlocked position and power off and on again. If the light returns then at his point I think a new printer will be needed.
Jan 18, 2010 | Epson Stylus CX3200 All-In-One InkJet...
Printer ar168D Error L1-00
The L1-00\r\n error indicates the scanner didn't return to it's home position or is locked and can't leave the home position. There is a lock switch (designed to lock scanner into place for safe transport) located to the left of the copier and just under the scanner. It's a plastic dial that needs to be turned to the "unlock" position. Once done, your problem should be fixed.
Nov 12, 2009 | Sharp AR-168D Copier
Error message says: Scanner is locked, Computer cannot communicate with scanner.
Have you checked the obvious? The scanner lock switch is located on the bottom of the scanner back right corner. --Ted
Jun 29, 2009 | Canon CanoScan 4200F Flatbed Scanner
Error: Release the scanner lock switch:
The scanner lock is locked pls unlock it dude...
Mar 15, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Problem with lock error
Scanner Locked error shown on screen?2 possible reason, either the scanner unit is faulty or the main board is faulty.
Mar 05, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Error message
Get another scanner. Check whether the lock has not been enabled at the bottom of the scanner. This has happened with me as well and a known Visioneer problem.
Sep 19, 2007 | Visioneer OneTouch 8920 Flatbed Scanner
Scanner seems stuck and causes error
you can always try to install the printer on a friend's pc as a test of the printer...do you have the install cd? if not try canon's site to download it.
Aug 10, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Samsung SCX-6322DN All-In-One Laser Printer Logo
693 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
