Question about Pitco Frialator SG14 Deep Fryer
FIRE IN FLUE - Pitco Frialator SG14 Deep Fryer
  • Pitco Frialator Expert
  • 684 Answers
There may be soot/ carbon build up inside the fire tubes that's why flame crawl all the way to flue. Also check if your fryer receives the right gas pressure and type as rated on the nameplate.
Posted on May 28, 2011
My king pellet stove keeps backpuffing smoke into the room and also spurting fire out the fresh air intake whole at the back of the stove on windy days.
I would check flue is clean and not blocked also check the flue terminal on the flue pipe is in good condition .
Mar 14, 2018 | Home
I have a flavel calibre balanced flue fire and it will only work on the lowest setting. Any ideas?
This may be a flue problem; stop using the appliance until it has been examined by an expert.
Is your fire the remote-controlled type? If so, have you tried new batteries in the handset? There are batteries in the control box under the fire too; look into the ash pan behind the facia, and if there are any red lights flashing, change the batteries. See last page of your user instructions. If your remote control is faulty, you can control the fire using the + and - buttons underneath the fire, on the control module.
Mar 02, 2018 | Heating & Cooling
Even if it was a wood burning fireplace from the beginning & was converted to gas ?
Now that's a LOT of additional information. I hesitated to answer your question the way it was worded originally.... IF in fact it is a masonry chimney and originally built to burn wood, you should have a chimney sweep do a thorough inspection of the flue to ensure it is safe to use again. Flue temperatures, while burning wood, EASILY exceed 1200 degrees whereas natural gas flue temps are in the 450 degree range.
It also should have a clay tile liner and not be fabricated of brick only. The unsafe thing of an unlined brick chimney or a chimney with a severely cracked liner has to do with unburned gases condensing within the inner surfaces of the chimney. Some of those gases are moist and will condense on the inner surface and eventually have an unsafe build up that can be ignited by an oversized flame or excessive sparks causing a flue fire. During a flu fire, temperatures exced 2000 degrees and an unlined BRICK flue of that age could have lost some mortar allowing superheated gasses to seep into the crevices. Those superheated gasses then explode when igniged by the flue fire and either do extreme damage to the flue, blow the entire chimney apart or in the worst case scenario burn your house down.
I'm sure you've seen houses burnt and the chimney was left standing....but you have also seen damaged houses with the chimneys blown off the end of the house and laying in rubble toppled out into the yard. The latter visual picture was an example of the end result of the gasses exploding. If the chimney was inside the house instead of on the end of the house, the house would have been burnt also.
There is a lot to be careful about when heating with wood and to start off safely you need to have your chimney inspected and the gas components removed with the gas line capped EXTERNAL of the fireplace.
Dec 08, 2014 | Home
I have a Vulcan lg400 propane fryer I have used 4 times at outdoor catering events over the last year yesterday while using it it began what I would call backdrafting. could low propane level in bottle...
It sure did. Never use a gas fryer in low gas pressure for a long time for soot will build up inside the fire tubes.
Check and clean fire tubes, make sure that the flue is not restricted and there should be no air entering the flue.
Regards.
Nov 03, 2013 | Vulcan LG400 Deep Fryer
I have a Vulcan lg400 propane fryer it has only been used 4 times for catering events. yesterday we were using it and after a while it started what seemed like mild back drafting the flame was actually...
Hi there. Flames rolling back instead of shooting inside the fire tubes can be a result of clogged fire tubes or air entering the flue, also check if there are objects blocking the flue. Regards.
Nov 03, 2013 | Vulcan 1VK85DF Hi-efficiency Gas Fryer...
After lighting gas fire ,smoke begins to fill in to room . this is first time this has happened after fitting new flue linner ten years ago
could be some thing in the fire burning , or a blocked flue or linner could be split needs to be checked out
Dec 12, 2010 | Heating & Cooling
Hello, I'm having problems getting a new gas fire fitted in my rental property. I have been quoted at £763. I already have a coal effect gas fire on the wall (no fire place) with a flue and obviously...
Older fires have an exhaust flue and get their air supply from the well ventilated room in which they're fitted. Balanced flue fires are the correct choice for rooms which lack sufficient fresh air ventilation. They have a flue which draws in outside air necessary for combustion whilst also acting as an exhaust for the combustion products. To work the appliance must be completely sealed so that no air is drawn from the room; the pressure of the incoming air and the pressure of the outgoing exhaust is equal so the flue is described as balanced.
The lack of a requirement for fresh air ventilation means that less energy is used; open outside vents let heat out as whilst allowing fresh air to enter.
Balanced flue appliances which exit directly through an exterior wall should cost very little more to fit than a regular appliance: the only additional cost may be in blocking up the old flue outlet and creating a new one but this rarely takes more than half an hour. A sealing collar is fitted to the outside of the flue (included in the flue kit) so there may be additional costs in hiring a ladder (or even erecting scaffolding) if you're higher than the ground floor.
Budget-level balanced flue fires typically cost between £350-£500 and the fitting charge may be fair depending upon your property, but it's also worryingly vague. A properly qualified and experienced gas fitter should be able to give you a precise quote and will already possess all of the tools needed to fit a new flue.
Also, ensure that you have your landlord's written permission to fit the new fire. If you don't then the landlord can claim that you have damaged the property and demand that you restore the property to original condition when you leave. If you get permission then you can also expect your landlord to insist that when you leave the property you do not take the new fire with you and that you supply an original copy of the gas fitter's installation certificate. Without this the landlord is within his/her rights to commission a safety inspection at your expense. Note that subsequent annual gas safety checks are required to be carried out by the landlord at his/her expense as per normal.
Oct 20, 2009 | Dryers
Pitco Frialator SG14 Deep Fryer Logo
348 people viewed this question
Top Pitco Frialator Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Paul Carew
ray gallant
Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
