Question about Intel D945GCCR Motherboard
I bought new seagate 500GB hard disk and installed windows 7.When i start my computer window loads and just before welcome screen it restarts.Sometimes my hard disk produce a sound and my computer does'nt work...Please tell me what is the problem and what should i do now??
  • Ankit Nimesh
    Ankit Nimesh May 27, 2011
    This sound was also produced in my previous hard disk.I have installed drivers of my chipset.It produces abnormal sound.After the sound my CPU's red light turn on f0r 2-3 seconds then it goes off.
  • 817 Answers
You say the hard drive sometimes makes a sound. Are you saying an abnormal sound or the correct sound? If it makes an abnormal sound then send it back to the supplier for a replacement. If it makes the normal sound the reinstall windows 7 again and see what happens. You also do not say if you have loaded any drivers? if not do not use those from the motherboard disk but download them from the manufacturers site. Start with the chipset drivers, then graphics then sound then network and the rest dont really matter.Next go to windows update and install all the updays inc SP1. hopefully now your pc will work just fine.
Posted on May 27, 2011
  • 3 more comments
  • Ankit Nimesh
    It produces abnormal sound.This sound was also used to produce in my previous hard disk.I have installed all drivers of my cipset.
  • Victorman
    Victorman May 28, 2011
    Well to be honest i dont rate seagates drives. i have alway built systems with Western Digital drives and had no problem with them. So now you have got into windows as you have installed drivers. Change the drive again and dont worry about the red activity light. As long as you can boot into windows and the system has good speed then all is well. There are a lot of background servies running in windows so the activity light may be on and off for some time.
    Good luck
  • Ankit Nimesh
    Ankit Nimesh May 28, 2011
    When i start my computer window loads and just before welome screen a blue screen apear for 2-3 seconds and then computer restars
  • Victorman
    Ah so now we are getting to know whats happening. You are getting a BSOD (Blue screen of death as it is known). The message says something like windows has shut down to prevent damage to your computer etc. On about the 3rd or 4th line is the stop error. it maybe something like IRQ not less or equal to..... or maybe like a program name.exe. Anyway i must know what it says and the codes it gives. the first and last are the important ones and they look like 0x000000?? it the ?? that is the clue to what is wrong. If you google these codes you will find out what is causing it. Most times it is a bad or outdated driver that causes a bsod. By the way can you boot into safe mode (by tapping F8 on start up)?
  • Ankit Nimesh
    Blue screen just appers hardly for 2-3 second.I am unable to see the error code.
Seagate FreeAgent 500gb Hard Drive not showing up on computer
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
click start control panel administrive tools computer management disk management right click on your drive select properties
click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in one box then select
check now start or you might tick one box then return after its finished the first repair then return and tick the second box
(I have found better results ticking the first box then reurn and tick the second box) you should not do anything while the chkdsk utility is in progress any input may damage this drive
hope this helps you
Mar 25, 2012 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
How do I format my new Seagate 500GB FreeAgent GoFlex Hard Drive to Fat32 for use with Xbox 360? I am using Windows 7 and when I open up the formatting options only NTFS and exFAT are available.
Windows Disk Management can only format a hard drive less than 32 GB to FAT32. If you want to format your 500GB drive to Fat 32, you need to use third party program like AOMEI Partition Assistant. http://www.disk-partition.com/free-partition-manager.html
Dec 25, 2010 | Seagate 500GB FreeAgent GoFlex Hard Drive
My desktop crashed. I lost everything on it. I thought I downloaded some informatin on my Seagate Externa harddrive, however, I am having problems connecting to other computers to see if any information is...
External hard drives are plug and play, the drivers are build into windows.
IF the hard drive was connected when your computed crashed, and the hard drive was in use, it may have damaged it.
If it does not automatically connect to other PC's looks like it has been damaged
Aug 20, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I bought a seagate 500 But I don't know how to put pictures on it
Yes. Its possible.
  • Step 1: Analyze the system requirements of the Windows operating system. Windows XP requires 1.5 gigabytes of free hard drive space. Windows Vista requires 20 gigabytes (for the Home Basic edition) or 50 gigabytes (for all other editions). The system requirements for older, outdated versions of the Windows operating system, such as Windows Me and Windows 98, can be found on the official Microsoft Windows Web site (link in the Resources section).
  • Step 2 :Connect the external hard drive to the computer with which you plan to use the hard drive. Use the hard drive's original cables included by the drive's manufacturer. It does not matter what connectivity standard you use. Windows will automatically detect the external hard drive.
  • Step 3: Click the Start menu in the lower left-hand corner of the PC screen and select My Computer.
  • Step 4: Right-click the icon for the external hard drive. Click Format from the pop-up menu. Format the external hard drive in the NTSF format.
  • Step 5: Insert the original Windows installation disk into your computer's CD-ROM drive. Close the Installation Wizard when it appears on the screen.
  • Step 6: Return to the My Computer window from Step 3. Write down the drive letters assigned to the CD-ROM drive and the drive of your external hard drive. For the sake of this article, we will use the example of D:\\ being the external hard drive and E:\\ being the CD-ROM drive. These are typically the letters assigned to CD-ROM and external drives in the Windows operating system.
  • Step 7: Click the Start menu button and select Run.
  • Step 8: Type "E:\I386\winnt32.exe /syspart:D: /tempdrive:D: /makelocalsource /noreboot" (without quotation marks) and click OK. This launches the Windows installer file on the Windows installation disk in drive E:\\ and commands it to install on the D:\\ drive (your external hard drive). The Windows Installer Wizard screen will appear. (Change the Drive Letter as in your Machine)
  • Step 9: Select the Full Install option in the Windows Installer Wizard. You will then be guided through the Windows installation disk. Follow the on-screen prompts to complete the installation. Depending on the speed of your computer's processor, this may take several hours. Be prepared to enter important information, such as your Windows registration key to register your copy of the Windows operating system. Do not close the installation window until the installation process is complete.
Please rate the answer if you feel that this solution solved your issue.
Thanks for contacting Fixya!
Step 10 Shut down the computer and disconnect the external hard drive. You can now use the external hard drive to boot up another computer using the installed copy of the Windows operating system.
Jun 29, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Dear ... I have recently purchased Seagate's Freeagent External Hard Drive (500 GB Capacity). It was working all right for about 10 Days, but now I face a peculiar Problem. This drive does not show in the...
Plug it back in and try this. Right click my computer and click "Manage"
When the window opens select "Disc Management". In the bottom of the screen you will see all the Disk drives installed on you computer. Right click on your drive and select "Properties". When the window open click the "Tools" tab and finally Run the Error Checking Tool. It will scan and fix any issues with the disk. Cheers :)
Jun 27, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I am not able to instal OS in my home PC. Asking me to install scsi drive. my hard disk seagate. where download this flopply disk bios drive software
hi
Checked the Bios Setting and check whether the Hard drive is recognizing or not -
Check the Boot sequence
Check Boot from the CD Drive
Format the Hard drive
it will work
Feb 23, 2010 | Seagate 500GB Maxtor Diamondmax21 SATA2...
SEAGATE HARD DISK DRIVE PROBLEM...
just remove the jumper settings of the HDD like this one.;
choose the master without a jumper.
let me know
Oct 04, 2008 | Seagate Barracuda 7200.7 160GB 7200rpm...
Does Seagate Free Agent 1TB support Windows 2003 Server
Go to Computer Management. (compmgmt.msc) then to Disk Management and assign drive letters .
u will c ur disk.
Jun 19, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Intel D945GCCR Motherboard Logo
73 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
