Question about Lexmark X4650 InkJet Printer
It shows "remove any obstruction
  • Official Brand Answer
  • 3,344 Answers
Open the printer cover and access the cartridge area. Remove both cartridges. While the cover is open, check for any obstructions in the cartridge carrier's path. Check for any loose transparent strip (encoder strip). If cartridge area clear from these, Close the cover. Unplug and replug the printer into the power source to reset it. When the printer turns on, open the printer cover and reinsert the cartridges. Close the cover and try to print again.
Posted on Jun 01, 2011
My acer Z5700 computer wont keep a disc in it keep ejecting it
hi Cheryl.
Try cleaning the lens inside the drive with a q tip or something of the like or an optical drive cleaner.
You could try to take it apart and find the obstruction.
You could open it and spray compressed air into it and hope it removes the obstruction.
try getting a laser cleaning disk to clean the lens inside.
or this could be something else wrong with it.
just let me know if the above works first.
Nov 22, 2017 | Acer Computers & Internet
Line in card
Take isopropyl alcohol and a clean cloth and clean the printehead of the printer. The printhead is located on the top lid of the printer and has a green and black appearance. Take clean isopropyl moistened cloth and swipe gently across left to right the black portion of the printhead. There may be residue on the printhead obstructing the heat transfer of ribbon to card which cleaning fix.
Worst case the printhead has one or more bad elements (pixels). The printhead is an expensive repair (Parts and Labor) so you may examine your options on repair or trade-in on purchase of a new printer.
Mar 05, 2014 | Datacard SP35 Printer
Where is pressure switch on a wmf740
I think you mean F05, in which case it means that the pressure switch is jammed on full.
You need to remove lower rear panel of washer.
Remove large black hose on bottom of drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well, and look inside the pump.
This should solve your problem.
Apr 06, 2012 | Washing Machines
My washer stopped mid cycle and wouldnt drain or spin or anything. The error message is "nd". Can I fix it myself? thanks
Hi
ND=-no drain error.
Remove the back panel you will see the pump. Simply remove the pump and remove the obstruction that is keeping it from draining. Check for thongs, baby socks and sometimes hair pins or even screws can obstruct the water pump. There's going to be some water left in the pump and drain hose, so get a large towel ready. Remove screws attaching black piece (motor) to white piece (housing), pull out motor and clean the housing and motor impeller. Reverse steps to assemble it back together. If you don't hear pump running after completing the cleaning, you may need to check the wiring and/or replace main control board located inside the console. If the pump seems to be running but no water is being drained - replace pump.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 06, 2011 | Maytag MAH2400A Front Load Washer
The oil indicator is very low and when I speed up it goes up when I slow down it goes down and the chek gauges light comes up. It has plenty of oil how can I fix it
First thing you need to do is have the actual pressure verified by attaching a mechanical oil pressure gauge in place of the sending unit on your engine. If the gauge verifies your dash readings then you have an oil pressure loss inside the engine that needs further diagnosis (worn bearings, obstructed pump pickup etc). If pressure drops enough to turn the light on I would not drive it 'till you know exactly what's happening inside or you can and will have an engine failure.
One warning...if after you remove the pan, you find that the pump screen is not obstructed, Don't blame the pump for the low pressure.....check the bearings. However, regardless of what you find (obstruction or worn bearings) it is advisable to replace the pump. Pumps generally don't fail but ingesting debris (carbon or metal from bearings) will either score or wear the pump housing and vanes enough so that the pump will never reach full pressure.
If the external gauge shows normal pressure, contrary to what the dash gauge tells you, blow out the sender passageway and replace the sender, then add marvel oil at each oil change as it will help dissolve any crud accumulated inside the oil system.
Jan 23, 2011 | 2001 Jeep Grand Cherokee
Code F-05 showing on INDESIT WIXE 127 washing machine. Not emptying or spinning.
Hi
Error code F05 means that the pressure switch is jammed on full.
Remove lower rear cover of washer.
Locate and remove the large black fastened to bottom of the drum.
Remove and clean plastic filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
Hope this helps you.
Jan 03, 2011 | Washing Machines
Error code F-05 showing on my Hotpoint ultima
Error code F02 indicates pressure switch jammed on full.
Remove lower rear panel of washer.
Remove large black hose from bottom of drum.
Remove hose on to pump and check for blockage or obstruction here as well.
Pleas rate my solution.
Thankyou.
Jan 25, 2010 | Hotpoint Ultima WD72 Front Load...
How do i clean a blocked filter on a wma74
Remove the lower rear panel of washer.
Remove the large black hose fastened to the bottom of the drum.
Remove and clean the plastic filter inside hose, make sure you fit it back on correctly, or it will come off.
Remove the hose onto the pump, and check for obstruction or blockage here and in the pump itself.
Please rate my solution.
Thanks.
Nov 23, 2009 | Hotpoint WMA74 Front Load Washer
My HP personal Media Drive,removable disk when inserted in the computer slot, lights only the blue light not the yelow one. Also it doesnt show up the media on " my computer " folder. Did it...
well it is possible that it is corrupted.
but try these steps first
plug it to another port.
download firmware for the device from the device website.
if that work its great
if not then format it. just to let u know by formatting you will loose all the data inside.
cheers
Aug 30, 2008 | HP Computers & Internet
Lexmark X4650 InkJet Printer Logo
81 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
