I have a RCportable tv and since I changed batteries I am unable to get the remote to work...I have batteries in correctly. It worked fine until batteries need to be replaced!!! Can some please help Model number on remote RCU450
  • egill6698 May 27, 2011
    My tv is a RCA...Remote is model RCU450..Thanks
  • 2,098 Answers
First confirm if the remote control emitted an infrared after an installation of the batteries by pointing it directly to your cellphone camera, while pressing any button key in the remote control, you will see the flash of the infrared emitter through the camera indication that the remote is working fine. If you can't see a flash then this is an indication that the remote is not functioning. Watch the video below for more info.
Remote Control Testing
If you've confirmed that the remote is not working, you must check if the newly installed battery is fully charged(tried another battery as much as possible). If the battery is not the issue, the remote must be take apart to check for bad solder joints most especially in the battery terminal and in the leg of the infrared emitter. Check also the battery terminal of the remote for corrosion.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on May 27, 2011
    Top Expert:
  • Televison & ... Master
  • 74,251 Answers
Hello
What is the brand name of your TV?.
  • The Knight
    The Knight May 27, 2011
    Please give me the Model Number of the device too.
Samsung 40' tv remote wont change channels the batteries are new and i get a weak no signal on the tv screen
Check the remote control for its infrared emission. Check it with fresh batteries. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site in "Mosaic" or "Magazine" view. It will make surf easier.
Jul 21, 2014 | Samsung Televison & Video
My dvr freezes. i have picture and sound but unable to change the channel or anything dealing with the dvr. i have to manually push the system info button on the box then select done with the remote. ...
Believe it or not, this could be a simple battery problem in your remote. When my battery is low in my remote, some buttons will work and some not. I'd try replacing the batteries in the remote first. If that doesn't work, I would guess that you need a new remote. Sounds like your DVR works fine manually, so chances are that's not the problem.
Hope this helps.
May 14, 2011 | DISH Network DVR-625 DTV Receiver /...
Dish IR Remote 20.0 has problems after sunset.
The problem for me was the TV giving off IR signals that interfered with DISH's poorly designed remote. When the TV's room ambient light sensor was turned on and it became dusk outside the DISH remote would stop working. Moving the receiver away from the TV helps but the problem is not eliminated until the light sensor is turned off.
Until DISH corrects this poor design there may be no other viable solution.
Jul 09, 2009 | DISH Network IR Remote Control
Can't change from HDMI2 back to HDMI1
You need to change via tv selections option for tv, this should be possible by selecting the source for tv feed. This should give various options to select hdmi11, hdmi12, scart1 ect. If remote not working to change look on the tv itself for the control buttons, normally on the back to 1 side (rh from front) then pressing the correct button. If this does not work try turning power off to tv for a couple of minutes and then turning back on. Hope this helps.
Apr 29, 2017 | Vizio Televison & Video
Tv won't stop changing channels
You need to isolate the problem.
1) Unplug the set for a few seconds then plug it in.
2) Operate the TV with the control/buttons on the TV. (Channels etc)
If the TV operates correctly then do the following.
3) Try operating with the remote unit. If the problem returns then it's the remote failing.
Sometime remotes can be reset.
Try this;
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
Try it again. If the problem is still there then the remote is bad.
Since this is a new TV you should use your warranty to replace any bad parts.
Mar 16, 2009 | Vizio L32 32 in. LCD HDTV
Will not turn off or on or change volume with remote
If you have verified the functions work by using the buttons on the TV then do the following.
If the remote does not work now then you may need a new one.
Mar 10, 2009 | LG 42LC2D 42 in. LCD HDTV
TIVO Remote Control Problem
A similar problem happend to me. Buying a new remote fixed it - for about three weeks.
Maybe your new one will work longer.
Mar 06, 2008 | Tivo DirectTV Remote Remote Control
Remote does not work for TV
I assume you had new batteries in the original remote and that the Universal remote was programmed correctly for your TV.
Are there any lights on the old remote that flash when you press a button? If so, does it light?
If the TV doesn't respond to a remote, and the remote is verified to be in working order, then the infrared sensor in the TV is defective amd needs replaced.
Good Luck,
- Jim
Jan 27, 2008 | Sansui TVM1916 19" TV
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
Electro Med Services...
