Question about Admiral 26 cu. ft. Side-By-Side Refrigerator
Suction line going to compressor is freezing up causing water leak on floor
  • 32 Answers
Sounds like it could be a dirty coil or low freon
Posted on May 27, 2011
Freezing Water line
Hello
The problem here is your water valve. It does not shut off all the way and allows very slow water flow through the water line. It is so small that it freezes in the supply tube causing a blockage. When your ice maker calls for water the pressure from the blockage pops the line out causing your leak.
You need to replace your water valve. Dual valve at the back of the fridge.."water inlet valve")
Jul 18, 2017 | GE (PSS26MSRSS) Side by Side Refrigerator
Ad50uss is not producing water. Fan and compressor is running . Coils are not getting cold, is refrigerant low? Or could it have a leak? How do u check for refrigerant leak and how do u add refrigerant and...
Compressors have 3 or 5 tubes coming out of the can. Probably 3 in this case. The largest is the suction and the smaller one is the hot gas line. The 3rd is crimped and brazed over. The suction line should be cool or cold (no frost or ice) and the small one should be hot. Be careful of fans. Also, that small line is normally hot enough to burn you. If they are the same temperature, its either low or out of refrigerant (Very common), the liquid line could be plugged (Rare), or the compressor is not pumping (also rare). From here on, you need a compound refrigeration gauge and a line tap. An amp probe would be nice but not needed at this point. If you have an amp probe and the compressor is running and not pumping, the amps will be lower than the name plate RLA or FLA by quite a bit. The name plate should tell you what type of refrigerant it takes. 134A is the new standard but it could be different (R12). Knowing the right type is a must. I have seen compound gauges, line taps, and R134A in hardware stores but you can't add any refrgerant on less your sure no air has gotten in. If the pressure in the suction line matches up close to the ambient temperature when the compressor is off, it has refrigerant. With the gauge on the suction line, start the compressor. If the gauge drops into a vacuum of 25 inches or more, the compressor is probably OK but the refrigerant is gone. If the leak is on the suction side, there will be air in the system. The moisture in the air will freeze immediately at the metering device and it wont get cold. If it all leaked out its another whole process to find and repair the leak, evacuate the system and weigh in the proper charge. I hope this helps. There is a whole process for all of this. Let me know if you have the equipment. I'll get you through.
Oct 14, 2013 | Whirlpool AD50USS Dehumidifier
All the coils on the unit outside froze up
Hello, if the inside fan was not running then the evaporator coil cannot absorb enough heat to vaporize the refrigerant, and the suction line will freeze including the compressor. Liquid refrigerat instead of vapor passes thru the suction line into the compressor. Lack of airflow or a low refrigerant charge is what will cause the line to freeze. In your case it was no airflow
Jun 14, 2012 | Goodman Heating & Cooling
Ice on suction line
hello, usually the suction line will form ice when there is low airflow due to a dirty filter or plugged eveaporator coil, also if the unit is clean then it is possible that the unit is low on refrigerant charge due to a leak. Inwould also check the thermostat on the unit to make sure it is fuctioning properly, I have seen may units where the thermostat cause the compressor to run continously and cause the suction line to freeze.
Jun 14, 2011 | LG Electronic Window Air Conditioner
Water leaking
depends on where its leaking. Air conditioners create condinsation it is a by product of it function. the water should drain thru a drain line and either go into a floor drain a pump or outside. if its leaking all over your floor it may be a clogged drain. If its not working well too then it may be freezing up and causing excessive condinsation beyond the drain area. you should make sure your filter(s) are clean and the drain is clear.
Sep 18, 2009 | Heating & Cooling
Water leak behind/under refrigerator
There can be a few problems causing this. Diagnosis with a good flashlight is the best way, actually see what is wet.
The most likely is a part of the cold side pipework that has a lump of frost on it that has built up and is dripping. I have seen this many times. Switch the fridge off and use a hairdryer to melt the ice. Then dry it off and either wrap it with a small piece of foam pipe wrap and even cut a strip of bubble wrap, wrap it with 3 or 4 layers and secure with tape. This keeps the cold in and stop moisture in the air freezing and building up.
A breakdown in the wall insulation. This causes condensation on the outside of the cabinet anywhere on the appliance. There is no way to fix this.
Or that the metal tray on top of the compressor that evaporates water from the defrost cycles is rusted through or over filling.
Slide a piece of cardboard under the rear of the fridge and bring it forward to the front feet. Remove the cardboard after 24 hours and see where the drip is on the cardboard. This will tell you where under the machine the water is coming from.
Dec 05, 2017 | Maytag MFC2061KES Stainless Steel French...
I have a jenn air JCD2389GES. Every day I'm getting puddles of water underneath the the unit. Our ice maker is turned off (broken for the third time)but the water line is still open to dispense water. We...
The condensate drain may not be draining into the pan under the fridge or it may have a leak or could even be not connected to the condensate pan in the evaporator.
Another possibility is that your condenser might be dirty or plugged causing the suction line going to the compressor to freeze up and then thaw leaving puddles under the fridge. Clean the condenser (the coil under or behind the fridge) and it should stop.
Over stocking the freezer will cause this as well. If you cover the air return in the freezer the evaporator will freeze up and the suction line will freeze back to the compressor.
Jul 09, 2009 | Jenn-Air JCD2389G Side by Side...
Water leaking from freezer into fridge
there are several things to check for. The condensing defrost tray under the fridge can crack or develop a hole and leak onto the floor. A door gasket not closing properly may cause sweating and leak onto the floor. Some fridge's have a humidity switch inside the fridge that should be turned on to prevent sweating on the center bar between the fridge and freezer section. If your fridge has developed a frost free failure problem, often the frost will travel down the suction line at the back of the fridge and drip water on the floor. The heat exchangertubing can separate and also sweat and drip on the floor. A kit to repair a separated heat exchanger line, comes with instructions as well. Ice maker and chilled water fill lines can crack and leak as well, this is fairly common with the plastic lines as they can dry out and crack.
click this link for more help  http://www.applianceaid.com/refrigerator.html
Mar 31, 2009 | Kenmore Refrigerators
Water leaking
Hi
There are several things to check for: The condensing defrost tray under the fridge can crack or develop a hole and leak onto the floor. A door gasket not closing properly may cause sweating and leak onto the floor. Some fridge's have a humidity switch inside the fridge that should be turned on to prevent sweating on the center bar between the fridge and freezer section. If your fridge has developed a frost free failure problem, often the frost will travel down the suction line at the back of the fridge and drip water on the floor. The heat exchanger tubing can separate and also sweat and drip on the floor. A kit to repair a separated heat exchanger line, comes with instructions as well. Ice maker and chilled water fill lines can crack and leak as well, this is fairly common with the plastic lines as they can dry out and crack.
Please revert for any clarification.
A Fixya rating would be appreciated if you found this to be helpful.
Thanks
Rylee
Feb 16, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
So water leaks out onto floor-Jennair side by side
THERE IS A DRAIN LINE HEATER ON MOST UNITS now days, if yours is an older one what you need to do is make sure that it's level, and that the drain line is cleared so that the water has a place to go when it thaws during the defrost cycle.
Jan 27, 2009 | Refrigerators
Admiral 26 cu. ft. Side-By-Side Refrigerator Logo
74 people viewed this question
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
