Question about Garmin Nuvi 660 GPS Receiver
Garmin 660 opens to where to/view map/travel kit/after that touch screen does nothing.good battery an ant signal.thanks
  • Garmin Master
  • 2,130 Answers
This is a well know issue with this unit and caused by a touchscreen failure. Please see this link for more info. Too much info to retype here:
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Posted on Jun 06, 2011
Change the country setting for a garmin 1350
Typically, when the unit is turned on, the satellitetechnology is able to pin point the unit's current location and provide mapsbased on the user's position. However, if there is not a clear signal or youare located in a different country than the ending destination you are tryingto program into the unit, you may have to manually change the country. For thatplease follow these steps: 1. Touch anywhere on the display screen to access the mainmenu. 2. Tap or select the "Change Preferences" options. 3. Navigate to your map settings. In a Garmin this will belocated under the "View Maps" and then "Change Maps"settings. 4. Use the "Up" and "Down" arrows toscroll through the list of available countries. Once the country you arelooking for is highlighted, press the "OK" button. You will then beasked to select a state or more specific region in the selected country. Onceselected, press "OK" second time. Hope this will help you. Good Luck.
Aug 16, 2011 | Garmin Nuvi 660 GPS Receiver
I have a garmin 1350 that shows only Russian? How do I change it to english?
i have a garmin Nuvi when i turn it on i select agree it loads up all maps then it opens with 6 separate screens select locale you should see at the top of a list A with country and languge press thst to change you the languge also
agree and loads up the maps then it will have 3 options where to view map and travel kit press travel kit then it has 2 more options words and phrases and bilingual dictionaries press bilingual dictionaries there you will see translation of english to spanish french german and many other countries
hope this helps
Jun 27, 2011 | Audio Players & Recorders
My garmin nuvi 660 touch screen dosen't work
To calibrate the touchscreen on a nuvi 300 or 600 series:
  1. Power the unit On.
  2. From the Where to? / View map screen, touch Settings (wrench icon).
  3. Touch Display.
  4. Touch Recalibrate.
  5. A new screen will display that says Press Dot.
  6. Touch the center of the dot.
  7. Keep touching the center of the dot as it moves around the screen.
  8. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated.
If your touchscreen is not responding to any touch and preventing you from recalibrating the touchscreen using the instructions above, please follow the steps below:
  1. Connect your nuvi to your computer with a compatible USB cable.
  2. Open the Garmin Nuvi drive located in MyComputer/Computer. (Note: Mac users can locate the Garmin Nuvi drive icon on the Desktop.)
  3. Open the Garmin folder.
  4. Locate and delete the GUPDATE.GCD file.1
  5. Safely disconnect your nuvi from your computer.
  6. Power the nuvi Off.
  7. Power the nuvi on by holding the power button.
  8. Continue holding the power button down for 1-2 minutes until the screen calibration option displays.
  9. Touch the center of the dot as it moves around the screen.
  10. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated and should respond properly.
Oct 24, 2010 | Garmin Nuvi 660 GPS Receiver
I have a garmin nuvi 660 it says "the screen is currently locked. press the power key to unlock." I have done this several times and even loaded up the latest software. I still get this message. When...
The on / off switch on top has 3 positions, it locks all the way right, when the unit is on make sure you have it in the middle.
There are icons near power button that indicate right side lock.
Oct 10, 2010 | Garmin Nuvi 660 GPS Receiver
The gps automatically shuts off after few minutes
When you turn the unit on and get to the screen showing Where To?, View Map and Travel Kit look on the upper right hand corner of the display and make sure you see the battery icon all green. If it is not then the battery is not charged
Apr 04, 2010 | Garmin Nuvi 660 GPS Receiver
Touchscreen not responding.
There are three levels of fixes, please try them in order:
1. Reset the GPS using the Reset button, on the back, just under the Antenna Hinge. Resetting will turn off the GPS, and then turn it back on, if connected to power. Test, if fixed, great, otherwise, go to fix 2.
2. Turn the power off, then press and hold the powerbutton for up to 2 minutes. The GPS will turn on, and display a "PreBoot Mode" message. When that message disappears, and the screen calibration screen appears, follow the on-screen instructions, and you are fixed. If you still cannot use the touch screen, repeat fixes 1 and 2 several times, just to be sure., then go to fix 3
3. The touch-screen glass has probably broken or lost its connection with the GPX motherboard. You can order new touch screen glass on the web and install yourself, if you are techy in nature, otherwise do a search for "garmin nuvi 660 repair" and choose your service.
Jun 19, 2009 | Garmin nuvi 250W GPS Receiver
Garmin Nuvi 610 I've lost all maps :(
If your map detail is missing, then the map information may have been disabled. To check to see if the mapping has been disabled, follow the steps below:
  1. Power the unit ON.
  2. From the Where to? and View Map page, touch the Wrench icon (Tools).
  3. Touch Map.¹
  4. Touch Map Info.
  5. The unit should display the name of the map that is loaded to the unit. The box in front of the map name should have a checkmark in it. If it does not, touch the box to place a checkmark in it.
  6. Touch and hold the back button.
If the map detail is still missing, contact Garmin Product Support at 1-800-800-1020 M-F 8-7cst.
Note:
  1. Some units may require touching Settings before touching Map.
Oct 05, 2008 | Garmin Nuvi 660 GPS Receiver
Cannot select another state on Garmin 660.
1. From the Where To? View Map, Travel Kit page press WHERE TO
2. Press ADDRESS
3. Press SPELL STATE (should be the 2nd blue box on the page & may read SPELL COUNTY)
4. Press the letter K and Kansas + Kentucky will come up; Press the letter T and Tennessee + Texas will come up, etcetera
5. If the information does not automatically appear, hit DONE and the information will appear. For example on my nuvi 660 if I hit the letter “A” nothing happens until I hit DONE.
6. After pressing the single letter for the sate/province in which you are interested, the unit will prompt you to spell the CITY name.
You will then enter the information as it applies.
Nov 30, 2007 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
53 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
