Question about Kenmore Dryers
Dryer wont heat up. heat element has been replaced
    Brigadier General:
  • 3,301 Answers
Check this blog by heatman http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won theres one for gas dryers on this same link
Posted on May 27, 2011
Brand new dryer wont heat
depending on which model roper dryer it can be a thermal fuse,high-limit thermostat,cycling switch,burned off wire in control panel,check each side of the heating element to ground and find 125 v.a.c. then on the side of the element that has low or no voltage on it to ground start at the element and back track the components leading to the dead leg on the element till you find 125 vac to ground and replace or repair component or wire,then you should get 240 to 250vac across heating element terminals
Feb 17, 2012 | Roper Dryers
I have a maytag performa dryer wont heat up sometimes
Hello there:
If there is no heat or heat sometimes please try these solutions
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Jul 14, 2010 | Maytag Performa PAV2200
My maytag electric dryer wont heat up
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
If any of your dryer's thermostats have become defective, they could be the reason that your dryer is not heating. Open up your dryer's cabinet and test each of your dryer's thermostats. If any are faulty, replace them.
A defective timer motor could also cause your dryer to not heat up. Test your dryer's timer motor. If it is no longer functioning as it should, replace either the entire motor assembly, or just its motor.
Apr 28, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
My dryer wont heat up or shut down
It's not heating up because the heating element is broken and should be replaced. It won't shut down because the thermostat isn't sensing heat and continues to run while expecting heat. So replacing the heating element should get it running properly.
Mar 23, 2010 | Whirlpool LER5636P Electric Dryer
Kenmore dryer 110-86094110 wont heat. Heating
Hi, Check all the thernostats and the thermal fuse for continuity. They should all show a closed circuit. If any of them are open, it will need replaced. It is usuallly the thermostat on the top side of the element housing.
I hope this helps you. If I can assist you further, please let me know.
Vic
Jun 28, 2009 | Dryers
It runs but timer wont advance dryer wont heat.
did you change out the limit switches? they control the heat to the element... and it sounds like you need a new timer
Jan 22, 2009 | Whirlpool GGQ8831L Gas Dryer
Frigidaire GLer642As3
A grounded element on an electric dryer is an element that has broken and the element heating wire has touched something metal, like the cage that is suppose to hold the element or the element metal housing around the element. What this does is, the element only heats on the section that is touching the metal part and usually this part of the element is only heating at about 1/2 heat output. An grounded element can also stay on even when the dryer is not in use!!
May 12, 2008 | Frigidaire GLER642A Electric Dryer
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
