Question about ASUS P7P55DE Pro Motherboard
USB PROBLEMS DOES NOT READ THUMB DRIVE - ASUS P7P55DE Pro Motherboard
  • ASUS Master
  • 27,725 Answers
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
hope this helps
Posted on May 27, 2011
My DTSE9 kingston Usb pen driver is not read by the Pc or laptop
W 7
First, please disconnect all USB devices and then perform the following steps: Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
for XP or earlier
Click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers right click to reinstall drivers
ports (com&lpt) right click update driver if this fails to fix the problem
Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
Reasons a Thumb Drive Won't Work
Depending on the degree of malfunction, fixing a thumb drive might not be feasible. Viruses
Thumb drives are capable of getting viruses.
A program or a corrupt file can be placed on the drive that will freeze the drive, delete files or infect any computer you place the drive into.
A simple virus scan of the drive is probably all you need to fix this problem.
Usage
Over time, continuous use of the drive will wear out the USB portion of the thumb drive.
The metal contacts will eventually wear until USB ports can't read the drive.
Clean the contacts periodically with rubbing alcohol to give the drive longevity.
Loose Pieces
Because most people keep their thumb drives on a key chain or in their pockets, it's possible the insides can loosen.
This is one reason a thumb drive won't work, and there's not much you can do except to use protective cases.
Moisture
Moisture can ruin a circuit board quickly.
Rain, condensation and sweat can short a thumb drive quickly.
Keep the Flash drive away from liquids and use a protective cover if you keep it in your pocket because the heat can create condensation.
Heat
Heat is another factor that can ruin electronics.
Anytime a circuit board gets too hot to operate, it overheats and malfunctions.
Data can be lost and the thumb drive might become unusable if it is kept in the heat too long.
Apr 14, 2013 | Kingston DTSE9 32GB USB 2.0 Flash Drive
My Brother PE770 won't read my USB
USB thumb drives can begin to have problems with their formatting over time. Try taking off all your files and formatting it with a PC. I have a Mac and sometimes devices do not like the USB drive because the Mac has place some 'hidden' files on it. Your software may ask if you want any files erased on the thumb drive before it write the new files on it. Answer yes which will reformat the USB drive.
Jan 27, 2013 | Brother PE770 Computerized Sewing Machine
Usb port on my zenith plasma z42pj240-ub, i plug in my cruzer usb to it and nothing.
First I would make sure you're on the "media" input setting. Then if it still won't read, I would try a generic thumb drive without the software and see if that makes a difference. Sandisk has added software protection that is hard coded into the thumb drive and it may be interfering.
Sep 29, 2011 | Zenith Z50PX2D 50 in. Plasma HDTV
Sandisk Cruzer 8gb Error
Make sure you are logged in as an administrator. I'd also try the thumb drive in a different computer just to make sure the problem isn't with the thumb drive itself. The drive could also be unformatted, or formatted with a filesystem for a different platform that can't be read by XP.
Oct 20, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
SanDisk 4GB thumb drive not recognized by my computer
Try any other computer but not open drive only see if they can read it. Also change USB port, sometimes some ports dont accept devices. Also check for latest antivirus software last such case viruses dont let me read any of my USB drives. If driver works to oter PC then you have virus.
Aug 11, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Acer 3100 laptop running windows xp, my USB ports are not working
No my repair shop see's this alot. All my employee's use thumb drives religously in our shop. I see this happen often esp if it gets used alot. I have even seen this happen when its removed while shutting down the PC. It is possible to attempt to reformat the thumb drive. If you unsuccessful, get a new thumb drive.
May 16, 2009 | Acer Aspire 3100-1405 Notebook
Asus P4P800-X USB Problem
Maybe your USB port on your computer is model 1.0 while the hard drive is a 2.0. That would cause it not to read it. Check your system information and see what model your USB ports are.
Mar 17, 2009 | ASUS P4P800-X Pentium Motherboard
Rescue data on optima attache 4G thumb drive?
Leave the thumbdrive plugged in to the computer and reboot.
Right click on my computer, click Manage, click on disk management, locate your thumb drive, right click and choose assign (or change) a drive letter. If it already has a drive letter, give it a different one as it’s already in use
Is this thumb drive USB specific? Some of the newer ones require a 2.0 USB port. It's possible you're plugging it into a 1.0 port.
open my computer and hit the f5 key on your keyboard for a refresh.. might not have posted.
try one or more of these
Jul 29, 2008 | PNY Technologies GeForce 6200 128MB AGP...
My System Windows Xp Cannot read Usb thumb drive
If you insert it on a USB located on motherboard there usually should not be problems, only if you forget to enable in BIOS, USB 2.0 or USB legacy support. If you have a card reader installed, please verify the pin connection required. You can find it in your motherboard manul. USB Legacy is generally required if you want to boot from some USB device and not all motherboards require that to be enabled to recognize and boot from USB devices.
Bye.
Jul 27, 2008 | Microsoft Computers & Internet
Philips DVP 5982 DVD Player USB issues
try formating the thumb drive with a fat32 partition before using it in the dvd player
Mar 16, 2008 | Televison & Video
ASUS P7P55DE Pro Motherboard Logo
59 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
