Question about Toys
How to trim. It spins out of control. Trim button doesn't appear to help the problem.
    Problem Solver:
  • 10 Answers
Could maybe be trimming the wrong direction, as in its so far off the one side that small changes to the trim make no difference
Posted on May 27, 2011
How to correct trimming problems did what the insteuctions said and keep having the same spinning counterclockwise problem
Just bought the air hogs helicopter with the crane. Had the aircraft constantly spinning clockwise, no matter how much I turned the trim control counter clockwise the aircraft still rotated. I then turned the trim control in the opposite direction until I noticed the aircraft had stopped spinning, and used the rudder control to fine tune forward flight. So, get the aircraft to hover and turn the trim button in the opposite direction until you see that the aircraft spinning slows right down. If you continue to turn the trim control in the same direction the aircraft will increase its spin, so just dial back the trim.
Dec 29, 2012 | Air Hogs Havoc Heli Helicopters
World Tech Saturn-X - spins, rudder trim doesn't help
I know what the problem is, i had the same issue right out of the box. if you take the cover off the front you will find the battery. on the bottom of the battery is a 2-sided sticky tape to hold it in place, on that tape the is probably a pulled wire. theres red blue black and white (as well as a thicker red and black that lead to the battery. find the wire that is pulled and solder it to the correct part. for me it was the white cable which controlled the top blades. the helicopter spins because both set of blades should counter rotate and if one of the motors isnt getting power from pulled cable the helicopter will spin and flip. Hope this helped. email me at thedew312@gmail.com if you need more help finding where the wires connect
Dec 28, 2012 | Worldtech Devices World Tech 85618 2CH...
Trim kit doesn't stick + front trim frame blocks the side vent
No no CVRS,
Where I live ...
No screws in that duct is a code violation
SO rather than support an operation that is
nationally recognized as a source of KITCHEN
fires...
Perhaps you should consider hiring the work
out to a PROFESSIONAL... Like your life depends on it.
Normally I support all kinds of daring DO-IT-YOURSELF
projects...
Not here... Not today!
Carnac the Magnificent
Jun 26, 2017 | GE Microwave Ovens
Having trouble programing my extreme 3d pro joystick and FSX deluxe. I am using Vista. I can't get the elevator trim up/down to work. Doesn't even seam to work when i press 7 or 1 on the...
I would first of recommend doing a calibration of your joystick. To do that, make sure your joystick is connected to your computer and go to your start menu>>devices and printers. Once your window pops up, find your joystick and right click on the icon, and go to settings. You can find the calibration wizard there. Once that is done, open up your Flight Simulator X, and go to the settings tab. Along the right hand side, click on controls. From there you can configure your joystick buttons to whichever action you like. Please keep in mind as well when your are adjusting the elevator trim, rudder trim, that the adjustments made from one keystroke, or button push, are very very small adjustments. You can change that by moving the slider on the Repeat column, thereby making one keystroke or button push equal to multiple taps!
Sep 13, 2011 | Microsoft Flight Simulator X
MY PROPEL RC EXECUHELI WILL NOT TRIM OR STEER. IT JUST GOES UP AND DOWN AND THE HELI SPINS COUNTER CLOCKWISE
counter clockwise would be the nose tuning to the left. My sons did this and pressing the right trim button on the controler repeatedly untill it slows is all I had to do. If you go to far it will spin int the oposite direction then you have to trim to the left and find the happy middle
Dec 26, 2010 | Toys
My son's helicopter just spins around and won't lift up anymore. It has been sitting for about a month, but worked fine before that. Any solutions? Could the blades have been bent? They don't look like...
replace batteries with new ones and then you let it spin while you trim it out by pushing rotor button ,for heli that spins clockwise push trim button on left side and a heli that spins counter clockwise push trim button on right side continue pushing the corrective button until spining slows and eventually your sons heli will fly straight again these instructions are in the owners manual
Nov 28, 2010 | Air Hogs Havoc Heli Helicopters
Ive a s006 alloy shark remote controlled helicopter and i need to adjust it so it stops spining around but instructions arent clear
have you tried using the trim buttons?,after take off when its around 2ft in the air if the tail spins to the right tap the left trim button a few times and if its spinning left tap the right button a few times and this should stop it spinning it works ok on my one
Apr 28, 2010 | Head Cover For Syma Alloy Shark Rc...
Helicopter keeps spinning in circles and won't lift.
There is a "trim button" on the controller. Ex: if the helicopter is spinning left, press the "R" trim button repeatedly. Takes a little practice to get it down to flying with out hitting anything. Good luck.
May 17, 2009 | Spinmaster Air Hogs RC Reflex Micro...
My Havoc Heli is really hard to control and I need help.
You have to keep tapping the right trim button. Keep tapping it until it stops spinning. If the spinning stops and it just turns, Use the the left right moving analog un til it flies straight.
Mar 15, 2009 | Air Hogs Havoc Heli Helicopters
Toys Logo
165 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
