Question about Kenmore Washing Machines
Stack waser won't spin the water out of clothes, there is also a burnt smell present.
  • 95 Answers
On numerous occasions, the lid switch becomes damaged and needs to be replaced. usuaally this is the problem if your clothes are being washed as usual, and then when it comes to the spin cycle, a safety feature engages and prevents the spin at the door switch
Posted on Aug 16, 2008
Kenmore 22622 washer tub will not spin during spin cycle, burnt smell
Sounds like the belt between the motor and the tub is slipping or the tensioner spring may have failed.
Dec 14, 2013 | Kenmore 22422 Top Load Washer
Washer won't spin. smelled burnt.
What is the model number of your unit?
Oct 30, 2012 | Amana Washing Machines
Frigidaire FEX831CS Top Load Stacked Washer / Dryer will not spin - burn smell
The transmission is burnt out. Happened to my mother in law a few months ago.
Nov 13, 2011 | Frigidaire FEX831CS Top Load Stacked...
Neptune MLG2000A doesn't drain completely and has moldy smell
You need to clean the stationary "brush" that collects lint and debris from the water during the cycle. The brush can be seen around the tub directly touching it along the bottom/front of the device. Right were I pour my detergent in, after the cloths are in there. To remove the debris I use a bottle brush. You can expect to use trial and error for your attempts. As far as the water being left.... My device has always left water in the bowl. I periodically just run a cycle with no cloths and bleach...HOT.....Mine is not spinning at the moment...again....I think its another call to the local dealer....AGAIN....
Jun 11, 2010 | Maytag Neptune MLG2000A Front Load Stacked...
Dont remove all water in spin cycle
clogged drain pump,line or pump is failing.
Feb 26, 2010 | Whirlpool Washing Machines
Was washing a load of sheets when it quite and there was a burnt smell in the air. was able to remove all the sheets. then manually removed water, by spinning the basin.
If you inadvertantly try to wash a large load with the water set to small the motor will be overloaded causing it to smell hot and kick out.
If this was your problem it will most likely work again when the motor resets.
Good luck
Sep 05, 2009 | Frigidaire FEX831CS Top Load Stacked...
No water goes into the machine, if i put it on spin it goes into the spin cycle But the water just won"t go into the machine
This could be a real simple fix. 1) Disconnect from power. 2) Take off the front panel by removing two screws near the base. 3) On the left side halfway up is a fuse that may be blown. Replace the fuse.
This worked for me when I had the exact same symptoms. Good luck.
Feb 22, 2009 | Maytag LSE7806A Top Load Stacked...
If motor runs or sounds like it is trying to run, you have a sock caught in the pump. If no noise at all you have a bad lid switch
Jun 07, 2007 | Kenmore 94812 Top Load Stacked Washer /...
Open Questions:
Washing Machines Logo
Sal De
 Brian Main
Brian Main
