Question about Ricoh Office Equipment & Supplies
The problem of defining how to identify the required Alascnr Alascnr on the web and through the usp cable cylinders are required for this printer definitions that carry Aso Ncwatik dsm415pf and also the name of Aficio 1515 please send files and definition files for these twin servo and how to run it and thank you
SOURCE: error message:could not locate a valid definitions file.Please go to the program options page and click "update definitions" to download a definitions file.
error: could not locate a valid definitions file. please go to the program options page and click "update definitions" to download a definations file
Posted on Jul 15, 2008
  • 65 Answers
SOURCE: printer wont do anything ricoh aficio 1515 pcl 6
The first thing to try is to turn the machine off, then back on at the red "main power" switch located on the left side of the machine. If the code returns it is indicative of firmware problems or a loose connection.
At this point I would seriously recommend getting a service tech to come out. However, if you want, you can take off the back cover (MAKE SURE THE POWER CORD IS UNPLUGED) and double check all of the connections by (GENTLY) pressing them into their connections. Hope this helps. Let me know.
Posted on Nov 25, 2008
  • 49 Answers
SOURCE: Poor print definition
Try the two links below to sort out print quality and colour calibration.
http://office.support.xerox.com/SRVS/cgi-bin/webcgi.cgi
Steps 4 & 7 on the link below are the most important
http://office.support.xerox.com/SRVS/CGI-BIN/WEBCGI.cgi/,/?St=609,E=0000000000024639304,K=4398,Sxi=10,Case=obj(79194)
Niallbt
Posted on Mar 30, 2009
Fame_Guru
  • 483 Answers
SOURCE: define microprocessor
microprocessor, integrated circuit containing the arithmetic, logic, and control circuitry required to interpret and execute instructions from a computer program computer program, a series of instructions that a computer can interpret and execute; programs are also called software to distinguish them from hardware, the physical equipment used in data processing .
..... Click the link for more information.
. When combined with other integrated circuits integrated circuit (IC), electronic circuit built on a semiconductor substrate, usually one of single-crystal silicon. The circuit, often called a chip, is packaged in a hermetically sealed case or a nonhermetic plastic capsule, with leads extending from it for
that provide storage for data and programs, often on a single semiconductor semiconductor, solid material whose electrical conductivity at room temperature is between that of a conductor and that of an insulator (see conduction ; insulation ).
base to form a chip, the microprocessor becomes the heart of a small computer computer, device capable of performing a series of arithmetic or logical operations. A computer is distinguished from a calculating machine, such as an electronic calculator , by being able to store a computer program (so that it can repeat its operations and make
, or microcomputer. Microprocessors are classified by the semiconductor technology of their design (TTL, transistor-transistor logic; CMOS, complementary-metal-oxide semiconductor; or ECL, emitter-coupled logic), by the width of the data format (4-bit, 8-bit, 16-bit, 32-bit, or 64-bit) they process; and by their instruction set (CISC, complex-instruction-set computer, or RISC, reduced-instruction-set computer; see RISC processor RISC processor [Reduced Instruction Set Computer], computer arithmetic-logic unit that uses a minimal instruction set, emphasizing the instructions used most often and optimizing them for the fastest possible execution.
). TTL technology is most commonly used, while CMOS is favored for portable computers and other battery-powered devices because of its low power consumption. ECL is used where the need for its greater speed offsets the fact that it consumes the most power. Four-bit devices, while inexpensive, are good only for simple control applications; in general, the wider the data format, the faster and more expensive the device. CISC processors, which have 70 to several hundred instructions, are easier to program than RISC processors, but are slower and more expensive. Developed during the 1970s, the microprocessor became most visible as the central processor of the personal computer personal computer (PC), small but powerful computer primarily used in an office or home without the need to be connected to a larger computer. PCs evolved after the development of the microprocessor made possible the hobby-computer movement of the late 1970s, when
. Microprocessors also play supporting roles within larger computers as smart controllers for graphics displays, storage devices, and high-speed printers. However, the vast majority of microprocessors are used to control everything from consumer appliances to smart weapons. The microprocessor has made possible the inexpensive hand-held electronic calculator calculator or calculating machine, device for performing numerical computations; it may be mechanical, electromechanical, or electronic. The electronic computer is also a calculator but performs other functions as well.
, the digital wristwatch, and the electronic game electronic game, device or computer program that provides entertainment by challenging a person's eye-hand coordination or mental abilities. Made possible by the development of the microprocessor , electronic games are marketed in various formats, such as hand-held
. Microprocessors are used to control consumer electronic devices, such as the programmable microwave oven and videocassette recorder camcorder combines a video camera and VCR in a single handheld machine.
The first commercially successful VCR, which used a Betamax format, was introduced in 1975. A competitive format, VHS (Video Home System), was introduced in the same year and became the dominant system.
; to regulate gasoline consumption and antilock brakes in automobiles; to monitor alarm systems; and to operate automatic tracking and targeting systems in aircraft, tanks, and missiles and to control radar arrays that track and identify aircraft, among other defense
PitVipermd
  • 54 Answers
SOURCE: i want free symantec virus definition file
You can also go to www.majorgeeks.com
They usually have the latest free definitions.
Posted on Apr 24, 2009
Will not start GENERAC 5500 PORTABLE GENERATOR
First you need to identify, is there a spark at the plugs? Is there fuel getting the cylinders, it can be so many things until you define at least that, the solutions are too many to list
Oct 15, 2013 | Generac 5724 GP Series GP3250 Portable Gas...
Printer wont print anythink from my computer
you need to check the usp or parallel cable which connect you to the Printer
also check the Driver (the Printer should be installed on your PC)
and also check the status of the Printer and it should be online
Jul 11, 2011 | Office Equipment & Supplies
Hello i am trying to connect my copier to my laptop can you tech me how to do this step by step
1- you need to download drive up to your sys windows & a dongle "USP software "
2- www.estudio.com.sg/download_monochrome_more.aspx
3- use USP cable or better to use a network cable to connect.
4- setup the drive & use usp to copy or setup network ip for the copier & another for computer" making a small lan network "
Jun 14, 2011 | Toshiba e-Studio 350 Copier
I need the cable that goes from my printer to my pc
Its a standard "printer usb cable" that can be gotten at any computer store, radio shack, best buy , walmart, etc
Dec 18, 2009 | HP APOLLO P-2150U InkJet Printer
HP lazerjet does'nt instal on my PC AMD Athlon with L7VMM3MB.
First install the software driver for your printer in your PC and then connect your Printer to PC via USB Cable. Hope your problem will be solved.
Apr 23, 2009 | EliteGroup L7VMM2 Motherboard
Web cam [identifying a drive]
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0
Be sure to plug in the camera in the USP Port before running this software.
As you run the program, write down the info about the camera so you will know what you have .
Double click on this site and download the Camera Diagnostic Tool and run it to check out your camera and/or problem.
http://www.download32.com/webcam-diagnostics-d35065.html
I ran the diagnostic on my camera to give you an idea how well it works.
Give it a try.
Hope this helps. Bud
Dec 28, 2008 | Computers & Internet
Smartbase MP360 Scanner Not Identified by MS Vista
One thing to check and be sure of is that your printer cable (USB) is definately a USB 2.0 cable. Canon have an issue with their printers with scanners in that the data flow sometimes isn't sufficient when an older USB cable is used. The slightest drop of data on startup or during scanning will cause a stop.
Worth trying and has sometimes solved the problem for my customers.
Aug 23, 2008 | Canon SmartBase MP360 All-In-One InkJet...
I have a new hp photosmart c6280 all in one printer. It prints great but I have been having problems printing ship labels through paypal and now usps.com Each label is sent with SAMPLE over the front, so...
I can't tell you exactly what this issue is, but I can tell you with absolute certainty that it isn't your printer. More likely, it's the way in which these files are watermarked or else a setting in the viewing application your printing from, say PDF.
But I can make some very good guesses and to some things which would cause this error...
  1. You are running some sort of trial viewer that has expired and now watermarks as "sample" anything you print. Picture viewers, some commercial document viewers, and some web browser plugins can do this.
  2. You are printing from a webpage and do not have java or scripting enabled. Many browsers require scripting to validate that you are supposed to be printing what your printing and watermark what you print if it can not.
  3. The issue is UPS, not paypal; but paypal uses UPS to do shipping...in this case you will see the error either way baacause your still using UPS but Paypal may have been aware that UPS had an issue and was addressing it with them.
  4. If your using Office products they do have an options setting to watermark print jobs. "SAMPLE" is the default watermark. But this would only effect printing from Word, Publisher, Excel, etc.
Aug 04, 2008 | HP Office Equipment & Supplies
My Brother copier printer DCP-IIOC, will copy but won't print, in fact the computer won't recognise the printer, the usb cable is fine, what is wrong or can you help me please?
Try this :
First check that is defined as default printer in 'installed printer' in Windows, and that you are not sending documents in printout to another non connected printer present in Windows under 'installed printers'.
Unplug completely computer from power socket and from USB for 10 minutes, to get rid of electrostatic problems on USB. Plug everything back and restart.
Check the USB cable, replace USB cable with a different one to check if it was the cable.
Uninstall printer from 'installed printers' in Windows (delete). Disconnect printer from USB, reinstall printer from printer software CD or downloaded driver. Connect printer to usb only after installing, or when explicitly required by software, this is important
Apr 25, 2008 | Office Equipment & Supplies
27 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
