Question about Kenmore 54501 Dehumidifier
My Kenmore 580.54501 dehumidifier "Water Bucket
  • Kenmore Master
  • 43,501 Answers
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Posted on May 27, 2011
The full bucket light stays on yet no water is collected
if water full light stays on the compressor wont start and remove water from air , investigate why light stays on ? is bucket really full? is sensor knocked out of its fragile holder ? is bucket all the way inside machine so that sensor is connected ?
Jul 04, 2014 | Kenmore 54501 Dehumidifier
Dehumidifier stopped working because "water bucket full" indicator light stays on, although there is no water in bucket.
In the water bucket is a float assm. scale forms on the assm. and causes it to stick. Remove the float assm. and carefully remove the scale. Should start working again once done. If not you may have to replace it.
Mar 11, 2013 | Dehumidifiers
The "full bucket" light is blinking- and the
When the Bucket Full Light is on, none of the controls (other than the On/Off) will work. If you haven't
emptied the bucket, do so. Then make sure the bucket is reinstalled properly into the holder. Failure to do this will cause the Bucket Full Light to stay ON. While you have the bucket out, check the inside of it for a float valve. It may be stick in the UP position. If so, jiggle the handle to make it return to the DOWN position.
I hope this helped you and thanks for Choosing FixYa.
Aug 12, 2011 | Kenmore 54501 Dehumidifier
I noticed that the "bucket full" light is on and
heatman101
Mar 31, 2011 | Comfort-Aire BHD-651 Dehumidifier
I have a model 54701500 and the bucket full light will not go off. I have bypassed the switch and the light still stays on, any ideas?
heatman101
Feb 24, 2011 | Kenmore 54701 Dehumidifier
Bucket full light flashing and 01 in RH display even though it is set at 50%. Turned unit on and off and it did not reset it.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that explains what can be happening to make the dehumidifier show that the bucket is full when it is not.
heatman101
Sep 01, 2010 | Kenmore 54701 Dehumidifier
Even though I have emptied the bucket the bucket full light will not turn off and the dehumidifier will not reset. I tried unplugging the unit but when I plug it back in it still says bucket full
heatman101
Aug 29, 2010 | Haier 45-Pint Dehumidifier
The bucket full light blinks even though it is empty and there is "01" in the screen where the digital humidity level is indicated. Pushing the up or down arrow does not change the "01" number. Unit won't...
Take out the bucket and locate the bucket full switch inside the cabinet. Depress the switch and see if it comes on. If so, you may have to add a shim to the bucket or strap it in with a bungie cord as the bucket is jiggling and makes the unit think that it has been removed.
Jan 02, 2010 | Kenmore 54701 Dehumidifier
Upon start up the full bucket light goes on even though I have a hose connected
make sure the hose connection did not work loose. If it did, water will slowly drip and fill up the bucket over time. If you know the bucket is empty, try readjusting it- it may just be cocked a little bit and this will affect the switch.
Are you supposed to put water in the bucket of the dehumidifier or is the water that is in the bucket now from using the dehumidifier? Dumb question I am sure. But I am renting and have never used one...
The dehumidifier condenses the water on its coils and then it drips into the bucket. Dump out all of the water when the bucket is full. This model has a light that tells you when it is full. If the dehumidifier gets ice on the coils, it needs repair (low refrigerant).
I hope this helps.
Aug 10, 2009 | Kenmore 54701 Dehumidifier
Kenmore 54501 Dehumidifier Logo
605 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
