Question about Cycling
I want to paint epoxy primer on stainless steel plate, what is the preparation required on the substrate? Or I can directly paint the primer to the steel plate and expect no problem on adhesion
    Problem Solver:
  • 10 Answers
You can eliminate streaks by bead blasting the substrate to create a footing for the paint to ad hear to. Sanding will create scratches.
Posted on Jun 17, 2011
  • 32 Answers
I would sand the entire surface before painting anything. Be sure to clean surface after sanding so not to get debris in paint (bumps). Stainless is hard so you may have to start with heavy grit sandpaper and work you way to a fine grit. Personally, I prefer sandblasting on metal surfaces, but I tend to like a flawless finish when I paint. Never the less, paint needs something to adhere to. Stainless is polished most usually so nothing will stick to it (hence the name stainless) by sanding it you create grooves in the surface for the paint to hold on to.
Posted on May 27, 2011
When aplying fresh paint with roller paint is peeling back of with roller
what is the substrate? (plaster, drywall, painted surface.... etc.)
if the surface is painted: can you tell the generic type of paint used before? and what is the condition of the existing paint, is it chalky? did you try to sand it?
if so, you might need to sand it and remove all flaking and chalking paint prior to application of a new coat. you might also need a compatible primer for best results.
Apr 12, 2015 | Tools & Hardware - Others
Can I paint over a previously painted concrete floor that was sealed with a polyurethane type product?
you did not provide info on the type of the paint and what surface it will be used on - there is difference between the floor, desk, wall and car body... all are flat surface but adhesion and work of the paint differs.
depending on the pre-existing paint, but you need always to "key-in" using 120 grit paper or 150 grit screen.
if paints are of same type, then paint in - if these are two different paints, you need to strip or isolate old paint, and then use new paint.
Sep 30, 2014 | Building Materials
My water pan is corroded. What can I use to recoat the pan? Do I sand down to base material then prime then coat?
Sand off all the corrosion to bare metal. Use a metal etch to scrub it down (any phosphoric acid will do), this can be gotten at Home depot or any home center in the paint section (also know as naval jelly). Clean the area with clean water after applying the acid and let dry. The naval jelly will leave a slight coating after the rinsing and this will prevent rusting afterward. Prime the metal with automotive primer, 2 or 3 coats will do. Let each coat dry completely. Use an epoxy paint (I've used single stage polyurethane and 2 part mixable epoxy type). The 2 part mixable epoxy is more expensive but lasts indefinitely and gets very hard). McMaster-Carr Supply has these products and they can be ordered on line. Apply the paint, let it dry according to the manufacturers directions and you shouldn't have any problems.
Apr 12, 2017 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Is there a stainless steel door panel replacement for bosch dishwasher shx43c02uc
If there isn't, you might try having a local metal shop cut you a piece of stainless, fold and weld the edges to make a cover for the door and adhere it either with epoxy or a small tack-weld. I wound up having to have a cover made for my Mom's stainless-steel fridge when only white and black ones were available and a metal shop doesn't charge much for it.
Alternately, if the metal panel is housed in a frame, try taking apart the frame, removing the panel and flipping it over. They usually just paint the one side, and if the other side is bare metal, such as aluminum, you can use sandpaper to give it a brushed finish and some clear-coat spray paint to give it that shiny stainless look and durability. Then just reassemble the door with the stainless-looking side facing outwards and the wrong-color side facing in. Worked for Mom's dishwasher!
Aug 31, 2012 | Bosch Dishwasher Door Panel White - 245067
Did a kitchen make-over and want to change our white fridge doors to black-can we spray paint them?
Yes, you can buy black appliance paint in a spray can. Do a good prep job first.
On site that sells it...
http://www.globalindustrial.com/p/maintenance/paint/aerosol/krylon-appliance-epoxy-paint-black?utm_source=google_pr&utm_medium=cpc&utm_campaign=Aerosol-Paint-google_pr&infoParam.campaignId=T9F
Feb 28, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
My Hobart Mixer is chipping and needs paint, what kind of paint?
you can get spraycans of paint from hobartcorp. by the way no paint is food grade
Oct 02, 2009 | Hobart Food Mixers
Where is the paint code plate for my 1984 VW vanagon westfalia?
Usually on a plate next to drivers seat, either behind the seat on bulkhead or on part of "floor" that seat mounts to.
Sep 26, 2009 | 1986 Volkswagen Wagon Camper
What causes fisheyes using an inexpensive HVLP system with Tremclad metal paint on aluminum?
Here is some information to solve the problem.
Fish Eyes: A surface depression or crater in the wet paint film. Fish eyes are caused by repulsion of the wet paint by a surface contaminant such as oil or silicone. The depression may or may not reveal the surface under the paint. Make sure the surface is clean.
Etching Primer
If you are going to be painting any aluminum, you are going to need an etching primer. This primer can also be used on steel. It is two-parts (not like epoxy, though) and tends to "bite aggressively" into the metal. It really stinks to have your paint stick well to your primer, but the primer releases from the metal. One of the major benefits is that you can paint over the primer in 1/2 hour, about the time it takes you to clean your gun and mix the paint.
OTHER PAINT RELATED STUFF
Additives: You can get anti fisheye additives, hardeners, flatteners, catalysts, metallics, metal flake, pearls, and reducers to mention a few. Get an anti fisheye thats compatible with the paint you use.
Masks Use a good quality dual cartridge mask for all work. Don't skimp, get the charcoal cartridges, they stop most aromatic vapors.
Jun 12, 2009 | HVLP 10 Piece Hvlp Paint Spray Gun Set
Ugly chromefenders
Paint will not adhere very well to chrome.You will need to get the chrome stripped as it is a plating finish on the steel. Any plating business should be able to strip them for you. Once stripped then use any good quality primer or powder coating
Apr 25, 2009 | 1981 Yamaha XJ 650
Painting
Hello there, You can paint your kitchen hood with special paint (appliance epoxy), but you might want to take it to a professional. It is not a simple job to do. have fun!
Aug 07, 2007 | Bosch (DKE9465EUC) Stainless Steel Kitchen...
Cycling Logo
64 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
