Question about Lexmark X4270 All-In-One InkJet Printer
I HAVE THE X47850 SCANER HOW DO I SET THE SCANER CODE SO I CAN SCAN?
  • textereugene May 27, 2011
    MY SCANER IS X4850 NOT THE X4270 ALL IN ONR
    I WANT TO SCAN USEING MY X4850 LEXMARK BUT I NEED TO KNOW HOW GET THE CODE TO DO SO
    President:
  • 3,278 Answers
Hello.
You don't need a scanner code (pin ?) to scan. Here are the steps from Lexmark Support:
Step Action 1 Make sure the printer is configured to scan over a network. 2 Load an original document face down on the scanner glass. 3
From the control panel, press I HAVE THE X47850 SCANER - pattlnk_1182007_1150-uparrow.gif or repeatedly until Scan is highlighted. 4
Press pattlnk_1182007_1151-selectbutton.gif. 5
Press repeatedly until the computer you want I HAVE THE X47850 SCANER - pattlnk_1182007_1151-selectbutton.gif/> Press pattlnk_1182007_1151-selectbutton.gif. 7
If you set a PIN during network setup and are beI HAVE THE X47850 SCANER - pattlnk_1182007_1151-leftarrow.gifr />
  • Enter the PIN using pattlnk_1182007_1151-leftarrow.gif and pattlnk_1182007_1152-rightarrow.gif to select a digiI HAVE THE X47850 SCANER - pattlnk_1182007_1146-downarrow.gifp://i.fixya.net/uploads/images/pattlnk_1182007_1150-uparrow.gif" alt="pattlnk_1182007_1150-uparrow.gif" class="h_mi" /> and pattlnk_1182007_1146-downarrow.gif to select a value for that digit.
  • Press pattlnk_1182007_1151-selectbutton.gif.
  • 8 Make your selections using the control panel buttons. 10
    Press the green Start button (pattlnk_1182007_1144-scan%20start%20small.gif).
    Hope this helps.
    Posted on May 27, 2011
    • 2,574 Answers
    1.Disconnect the power cable from the back of the printer.
    2.Hold down the Stop/Clear button.
    3.While keeping the button pressed down, reconnect the power cable. A message on the LCD will display MEMORY CLEARING.
    Note: The Fax, Copy and Scan buttons will remain ON until the message disappears. Only the Fax button should be ON when the function is complete.
    4.Select the personal settings you require as follows:
    LANGUAGE: Press the right arrow key to select the language you want to use, and then press Select.
    COUNTRY CODE: Press the right arrow key to select the country you will be using the printer in, and press Select.
    ENTER DATE: Using the date format dd/mm/yy (in the USA, mm/dd/yy), press Select.
    ENTER TIME: Using the format hh:mm, press Select.
    Select Format: Press the appropriate number to choose between 1=12hr, 2=24hr.
    PERSONALIZE FAX: Press Select.
    Enter Name: Type in the name and press Select.
    Enter Fax Number: Type in the number of the phone line to which the printer will be connected, and then press Select.
    I had a scan for my toyota avalon 1995 xls for the check engein and abs the scan geve a code po315 for the engein and for the abs no code et all the told me it is a problem with the conection to the a
    the problem is a mechanical issue with the crank position sensor. air gap, broken /fallen off or dirt/ rotor damage. For the abs problem check all the wires at the wheels and check for rotor damage.
    Dec 10, 2014 | 1995 Toyota Avalon
    Scaner Short Cut
    did u tried to search for the scanner button software ? try to see for it
    Jul 23, 2010 | Canon LIDE20 Flatbed Scanner
    I have a epson dx4050 and i cant figure out how to scan with it
    usually ..if it is a scaner when you install it it shoud have a software for scaner ..you have to power the scaner ..put the document or picture in ..after that open the scan manager or whatever the software that came with is named..and look for a button scan ...it will scan ..and when it finishes it will open the containing folder..and show you the job s done...usually like tumbnails...this can be opened in full image ...copied..or cut ...or whatever ..they usually remain in that folder for future use..unless choose to delete ..
    Jan 30, 2010 | Office Equipment & Supplies
    Hanging problem
    scan the exit code it will close your scanner and then scan the recall default code (4 times) then scan the ENTER code your problem will be solve
    Eshwer
    Dec 18, 2009 | Eclipse Metrologic MS5145 Barcode Scanner
    How to scan photos to the computer
    start - program- lixmark scaner- click on it-the diloge window for scaner apper choice the dip as300 or more put 300 is good then choice the jpg for hoto to be very easy when you have save the photo make prevew for the picture the scaner will make scanning for the picture in the glass then will apper on you moniter computer select the part you want scanning by mouse then click scan when finish save it .make sure you instull the scaner in your computer good.
    Dec 02, 2009 | Lexmark X7170 All-In-One InkJet Printer
    System error L1 00
    Hello sir; That error code itmeans scaner unit problem, the scaner not left home or not return home, or scan overload,as well as mirrow motor problem, there have no way to reset the only way is replace it.
    Oct 06, 2009 | Sharp AL-1655CS Copier
    Scan document to computer
    install driver of ur scaner
    now connect it with ur comptuer
    install photoshop
    open photoshop go to file click in import and select import via ur scaner name and it will scan document
    Oct 02, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
    Engine light comes on, could it be the gas cap?
    Hello, Yes you can set a code in your computer if the gas cap is loose. Plus do not fill with gas with the engine running or key on as this will set an evaporative emissions code. Thank you
    Feb 28, 2009 | 2004 Honda Accord
    Scaner does not scan
    Printer works well, but the scanner will not scan only leaves a black page
    Dec 28, 2007 | HP PSC 2355 All-In-One InkJet Printer
    Lexmark X4270 All-In-One InkJet Printer Logo
    85 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
