Question about Sony PlayStation Portable (PSP) Slim (PSP-2000) Console
How do i fix my format storage problem on my psp go
How to format mine (unable to format system storage(802E1002) ?
Not having my PSP in front of me and not knowing what model you have, or what kind of computer or OS you are trying to do this with, I believe there may be an option to format the memory card from the PSP itself. I believe there has to be an option somewhere on the PSP to do this. My reasoning is that if you put in a brand new memory card, it needs to be prepared for use in the PSP. In other words, the PSP installs files on the memory card so it *knows* how to communicate with it. Basically, it installs a file system on it, much like your computer does when setting up the OS.
--OR--
Pull out the memory card and plug it into a card reader that is hooked to a computer. Then, as it shows up on the *My Computer* screen, right click on the memory card and select format. Be sure you have the right card selected for formatting, or you could hose your computer.
May 31, 2014 | Sony PlayStation Portable (PSP) Console
Tip
How to Rip Movie DVDs to PSP (PSP hack 3000/PSP slim 2000/PSP go)
This article is about how to Rip DVD and CopyDVD Movies to your PSP hack 3000, PSP slim 2000 or the new PSP go. As acrazy PSP fans, I am hot for Ripping any DVD including commercial DVDsand put DVDs to my PSP 3000 for watching, it's cool. So, here I want toshare my method to help you Copy DVD to PSP fast and perfectly.
Readingenriches the mind, first of all, introduce some knowledge about SonyPSP. The PlayStation Portable (officially abbreviated PSP) is ahandheld game console manufactured and marketed by Sony ComputerEntertainment. The PlayStation Portable is the first handheld videogame console to use an optical disc format, Universal Media Disc (UMD),as its primary storage medium. Other distinguishing features of theconsole include its large viewing screen, robust multi-mediacapabilities, and connectivity with the PlayStation 3, other PSPs, andthe Internet. As a media device, PSP supported video format: MP4,MPEG4, H.264/PSP AVC Video. Audio format: MP3, WMA.
How to rip DVD and Copy DVD Movies to PSP ?
Hadmentioned above, PSP supported video format: MP4, MPEG4, H.264/PSP AVCVideo. So, if you wanna put DVDs to PSP, you have to convert DVDs toPSP-friendly format. For ordinary DVDs, there are some DVD Rippersoftware can get it right. But Commercial DVDs are generally encrypted.In order to copy DVD to PSP, you'd need to break that encryption, whichcan be done by Daniusoft DVD Ripper. It is fast and easy-to-use PSP DVD converter software, which has professional performance in ripping DVD to PSP video.
Step1. Download Daniusoft DVD Ripping software, install and launch it.
Step2. Rip your DVDs and Convert to PSP-friendly format.
In Daniusoft DVD Ripper, Click "Add" button, you are allowed to importDVD from local disk or CD-Rom , you are allowed to load DVD Rom, DVDfolders, ISO files and IFO files respectively.
Then Click the pull-download menu in the "Convert to:" option to select the output as PSP-friendly format.
Then click Start and let Daniusoft DVD Ripper do its thing.
Step3. Copy DVD to PSP
Copyingyour movie file over to your PSP to view! Just open PSP Video and clickthe Copy tab. Make sure your PSP is connected to your PC via USB cable!and then just click the movie file, and Copy to PSP.
Tip: If you aren't satisfied with the DVD Movie, you can crop/trim/merge/adjust the DVD Movie by the button "Edit" for better.
on Jan 18, 2010 | Cell Phones
I just formatted my psp go and it has 14gb free space. when i connect it to any pc it shows that my psp only has 40mb free space
format on the go not on the pc if still not working see if this helps
it works by correcting the format on usb.
HP USB Disk Storage Format Tool
Feb 08, 2014 | Sony - Go for PSP
If anyone can help me thank you forever. I have a PSP GO and suddenly appeared to me a message saying: can not read storage system please try to format storage from system settings. when I try to format I...
You need to call Sony. Since it is a PSP Go, chances are you are still under warranty. If you are not under warranty, they will usually fix it for cheap money.
Try this first: Go to Settings > System Settings > Restore Default Settings and then try to format it.
Jun 18, 2011 | Sony PlayStation Portable (PSP) Console
How to upload pictures? what are the properties of a PSP image
Hi, charlesleigh!
The PSP supports most common image formats, to upload the images do the following
  1. Insert a Memory Stick into the Memory Stick slot in the left side of the PSP. Depending on how many photos you want it to hold, you may need to get a larger one than the stick that came with your system.
  2. Turn on the PSP.
  3. Plug a USB cable into the back of the PSP and into your PC or Mac. The USB cable needs to have a Mini-B connector on one end (this plugs into the PSP), and a standard USB connector on the other (this plugs into the computer).
  4. Scroll to the "Settings" icon on the home menu of your PSP.
  5. Find the "USB Connection" icon in the "Settings" menu. Press the X button. Your PSP will display the words "USB Mode" and your PC or Mac will recognize it as a USB storage device.
  6. If there isn't one already, create a folder called "PSP" on the PSP Memory Stick -- it shows up as "Portable Storage Device" or something similar -- (you can use Windows Explorer on a PC, or Finder on a Mac).
  7. If there isn't one already, create a folder called "PHOTO" inside the "PSP" folder (on newer firmware versions, this folder may also be called "PICTURE").
  8. Drag and drop image files into the "PHOTO" or "PICTURE" folder just as you would save files in another folder on your computer.
  9. Disconnect your PSP by first clicking on "Safely Remove Hardware" on the bottom menu bar of a PC, or by "ejecting" the drive on the Mac (drag the icon into the trash). Then unplug the USB cable and press the circle button to return to the home menu.
If this didn't fix your issue please let me know. Hope this helped you!
-Luchen
Mar 07, 2011 | Sony PlayStation Portable (PSP) Console
Just bought a Sony Memory Stick PRO - HG Duo 8GB for my PSP to make sure I had enough memory to do what I want. The PSP reads my old SanDisk 512 MB but says there is no memory stick inserted when I use my...
Have you tried to format in the PSP. Go to System in the main menu, then system settings, then format memory stick. I purchased a new chip for mine and it did not show as storage till i did this. Insert or remove chip only when unit is powered off. If it still does not work take it to the store and have it checked. Hope it helped.
Sep 03, 2010 | Sony PlayStation Portable (PSP) Console
MY memory stick can be seen and read in my pc but doesnt work on my psp
  • Flash Storage:
  • Memory Stick PRO Duo Expansion Slot pspphatmodelnumber.gif pspslimmodelnumber.gif pspbritemodelnumber.gif
All flash storage, including Memory Sticks and internal flash, uses the FAT32 file system. http://us.playstation.com/support/answer/index.htm?a_id=1055
The above shows how to format the Memory Stick PRO Duo in the PSP so the correct file structure will be shown.
Be sure to back up any data on the Memory Stick PRO Duo before doing this as all data will be lost on the Memory Stick PRO Duo device.
Aug 06, 2010 | Sony Memory Stick PRO Duo (2GB) for PSP
The memory stick access light keeps on blinking when i turn on the psp. It cannot detect any memory stick. What does it mean? thanks.
It means that the PSP system was having problems accessing the memory storage device connected to it. Probable cause might be due to corrupted files/data in the memory stick. Normally faormatting the memory stick will fix it, otherwise if formatting won't resolve the issue it means that the memory stick has gone faulty and needs replacement.
Jul 12, 2010 | Video Game Consoles & Games
How would you transfer DVD movies to a PSP using a laptop computer?
In order to transfer movies to a PSP you would need a computer, a USB cable connector and a Memory Stick Duo. In order for movies be played in a PSP, they should be converted into a PSP movie format or an .MP4 file as this is the only extension that a PSP could play.
Next step would be to converting movie format you have into a PSP movie file or .MP4 format. Fortunately, there is a lot of software or applications out there that are capable of converting video files from one format to another. Aside from the regular file conversion applications, there are already PSP video converters available over the internet which can easily convert popular videos like DVD, VCD, SVCD, MOV, RM, MPEG, WMV, 3GP, AVI to PSP video format or the H.264/MPEG-4 format. After you have converted the movie files, it's just a matter of placing them into the memory storage of the PSP.
You will need to connect the PSP to a PC or Mac first, of course, and run the PSP video manager which is located in the "Tool" menu.
The system will automatically detect "C:Temp." The PSP files in this folder will be shown on the left side while files on the PSP will be shown on the right. The PSP is identified by the system as a "Removable Disk". Now, highlight the file which you want to put into the PSP and then click "Copy" and wait until the transfer has been completed.
Please let me know if the provided information has been helpful.
Please rate me if the information provided was able to help you.
Jan 09, 2010 | Computers & Internet
PSP - Corrupt data
b4 buyin a new mem card jus try a friends card... nd c if t works,
May 26, 2008 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Slim (PSP-2000) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
