Question about Keurig B70 Coffee Maker
Short cup - Keurig B70 Coffee Maker
  • Keurig Master
  • 43,501 Answers
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Posted on Aug 07, 2011
Keurig rivo not puncturing
Just push the cup firmly down onto the lower needle before closing the "clamshell" and puncturing the lid of the K-cup also. Read the attached link, other people have this problem.
2nd link explains problem very well.
Preventative Measures How to Keep Your Keurig Brewing Cup Barista
Fix your Keurig imsolidstate
Apr 17, 2014 | Coffee Makers & Espresso Machines
We have a short cup problem. When we make a tall cup,the machine gives us a short cup instead every time.
heatman101
Jun 12, 2011 | Keurig Special Edition B60 Coffee Maker
How much rice to haw much water
Use 1.5 to 2 cups of water per cup of white rice. Use less for short grain rice. Use 2 cups of water per cup of brown rice.
Mar 29, 2011 | Black & Decker Black Decker HS1000 8Cup...
Today,my keurig started to short cup me, and shortly after that, it will not brew anymore! I noiced while de scaling today( recommended per keurig), that more water is pouring into the water resivor, vs...
The water pump is probably starving for water:1. Remove the clear plastic reservoir and set it aside. 2. Look into the hole that the reservoir sits on. You will see a fine plastic screen that keeps debris from getting to the pump. 3. Clean off the screen. You may have to disassemble the bottom of the machine and remove it to do it right. 4. Put everything back together and the short-cup problem will be history.
Nov 08, 2010 | Keurig Platinum B70 Coffee Maker
Hitachi Chime-O Matic-rice cooker/steamer RD 4056-need instruction book
#1. If you have "Long Grain" rice Ratio is 1 extra cup of Water ie: 2 cups of Long Grain Rice you add 3 cups of water.
#2: If you have "Short Grain " Rice is Equal Portions of Water to Rice, ie: 2 cups of "Short Grain " Rice then 2 cups of water.
Hope this Helps.
BT
Sep 02, 2010 | Zojirushi NS-MYC10 Neuro Fuzzy 5-Cup Rice...
If I pour in 8 cups of water the coffee pot will only make 6 cups
There is a secret compartment they do not tell you about when you buy it. The water is stored there in case of a drought so you can at least have a glass of water...
May 24, 2010 | Oster HDX23 12-Cup Coffee Maker
Water build up under crisper dwawer
I would check the defrost drain cup located in the frig section on the back wall. Take a large syrenge filled with hot water. Insert it into the drain cup and try and seal it into the drain hole at the rear of the cup. Farce as much hot water into the cup to clear any debris cought in the drain cup and hose assembly.
TIP: insert a short rubber hose into the end of the syrenge to make it more flexable to get into the drain cup.
Dec 30, 2009 | Refrigerators
Keurig B70 Coffee Maker Logo
47 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
