Question about Hunter Pump Start Relay Psr-22 Pump Controller
Installing new hunter ps22 pump control but can not get power to pump. Checked control voltage coming from the irrigation controller and is at 25v. Checed in comming power from to the ps22 and it checks. ps22 does engage when getting signal from irrigation controler but I get no power on the out side. If I connect the in coming power lead to the out going (eliminating the PS220 the pump runs fine. Assumed that the PS22 was bad but a second one responded in the same way.
SOURCE: Two fans, remotes work with one, not the other
YOU MUST TRY CHANGEING THE CHANNEL ON THE REMOT AND TRY IT THEN IF IT DOES NOT WORK YOU MUST TAKE DOWN THE FAN AND CHECK WHAT CHANNEL THE RECIEVER HAS AND MATCH IT TO THE REMOTE.
Posted on Jan 23, 2009
  • 4 Answers
SOURCE: I have a Hunter 27185
you can use the red or the blk for blk,wht red
Posted on Mar 31, 2009
  • 582 Answers
SOURCE: I have a Hunter ceiling fan with light kit. The
with out seeing the switch and how it's wired . i'll try
do you have power to the light switch it self. you have power to the fan but does the switch for the lights have power, you may have to run a jumper or sepperate wire fir the lights
Posted on Aug 23, 2009
  • 122 Answers
SOURCE: This is for the installation
all the white wires will be all together, you need a common to run the system right, good luck
Posted on Aug 09, 2011
SOURCE: Hunter ceiling fan model 23285-420 w/remote control...worked fine for about a year then lights would start flashing when turned on. Changed remote control and receiver with no change. Eliminated the g
The problem is not your remote on the fan. It is the light kit. We have the same problem and our electrician diagnosed it as the light kit. This problem started just out of warranty, of course, and we are now purchasing a new light kit to fix the problem.
Posted on Feb 26, 2012
Hunter node _ Running water all the time
Solenoid Valve set to manual on St Valve to off position
Mar 31, 2013 | Hunter Industries Hunter NODE-100 Single...
The pumps are not getting any power
I am not sure what an investor is attached to a pump but I can tell you that you need to check the voltage coming from the control to each pump to verify you have the correct voltage going into the pump motors.
If there is no voltage then you need to look at the control where the voltage is coming from to see why you do not have power coming out of going to the motors.
If you do have power going to the motors then you need to verify that the motors are good i.e. take them to a motor shop and have them checked out.
Rod
US Parts Center
888-521-6183
Mar 03, 2013 | Pool & Spa
Irrigation valve vibrates when opening.
Take apart and clean spring /diaphragm is sticking
Clean unt out
Feb 18, 2013 | Hunter Industries Hunter NODE-100 Single...
I have installed a Hunter psr22 pump start relay and connected it to a Hunter src irrigation controller and when I cycle the irrigation controller to manual all stations it will not start the pump. There...
So the mv and c are supplying power to the transformer/relay and out of it, but the pump won't start until the relay is forced.
I'm thinking the relay contacts are oxidized, and need to be cleaned. When they have oxidation, current goes up, and voltage might appear ok. If any start capacitors are in the circuit, they can be faulty, breaking down under a load, while reading ok. I haven't heard of any caps in these systems, but just in case.
The following blog may help you- it's about different controller situations:
http://forums2.gardenweb.com/forums/load/water/msg121639307045.html?9
Hunter's website has some things to check concerning the controller:
http://www.hunterindustries.com/resources/library/product_technical.html
Looks like it could be microprocessor lockup. It's quite a process, but here's what they say is the fix:
http://www.hunterindustries.com/resources/library/Technical/200611_hdln_micropro.html
Good luck, hope this helps, and thanks for using FixYa.
Sep 14, 2010 | RTO Hunter Psr-22 Pump Start Relay
Why my PSR-22 pump start relay does not start the pump even the automatic sprinkler controller is at manual run mode?
It could be that the PSR-22 isn't "relaying" the correct amount of power to your pump. If the PSR-22 is making noise (a hum, or buzzing sound), it could be failing.
Try checking the voltage on the PSR-22 to be sure that it's supplying your pump correctly. Be careful - there's a lot of voltage in there, and getting a shock could be fatal.
Jul 11, 2010 | Hunter Pump Start Relay Psr-22 Pump...
The furnace wont turn on even though it says it is
not all digital thermostats are compatible with the manufacturers circuit control boards in the furnace. Hunter has had this problem several years ago. Other than that you may have miss wired the unit. usually the furnace is used as backup heat (during defrost) or emergency heat if your heat pump konks out. Are you switching to emergency heat for a furnace call?
Nov 24, 2009 | Hunter Fan Company 5/1/1 Programmable...
Hunter Remote 85094-1 doesn't work after I dropped it
Try these simple trick to find out yor remote control working or not....
Point the remote control towards the Camera of a Mobile Camera phone,with the camera on. While pressing remote, we can see a light (Infra Red) coming from its IR LED through the Mobile Camera if the Remote is working.
otherwise, the problem with the Remote sensor or related components of the device
Jan 06, 2009 | Hunter 52" Ceiling Fan With Light And...
Hunter sprinklers vs rainbow sprinklers
I work with both Hunter and Rainbird irrigation components. Both companies have good products. But, I prefer Hunter for the sprinkler heads and Rainbird for the controllers and valves.
Oct 30, 2008 | Ace Hardware Hunter& Low Profile III...
Remote control fan
I had the same problem and I thnk Hunter Fan knows about it....I just called Hunter Tecnical Support at 901-745-9222 and they sent me a new White circular receiver which goes inside of the canopy and it worked fine after installing the receiver....
Mar 14, 2008 | Hunter 21871 56'' Ergonomic Brushed Nickel...
Hunter Pump Start Relay Psr-22 Pump Controller Logo
60 people viewed this question
Top Hunter Garden Experts
richie46
 steve
steve
Are you a Hunter Garden Expert? Answer questions, earn points and help others
