Question about Cameras
Can sharp XV 315 PA projector be connected to a computer or laptop
mastersaintx
  • 928 Answers
SOURCE: sharp projector
Thanks for the rating. if you need further assistance just select the ASK ME button
Posted on Oct 27, 2008
how do i rest the new lamp on my sharp projector
Posted on Dec 23, 2008
  • 111 Answers
SOURCE: "no signal" message when laptop is plugged into projector
There is a key on the keyboard that has blue text on it. Something to the effect of LCD or CRT. With the monitor connected and turned on, press and hold the FCN KEY as well as the LCD/CRT key. While holding the FCN key keep hitting the CRT key until the image transfers to the external monitor
Posted on May 24, 2009
97F350diesel
  • 1326 Answers
SOURCE: Sharp XG-E650UB LCD Projector
Absolutely, they are designed to do so. You will need a svideo cable for video if your laptop doesn't have a parallel port for external monitor. Most projectors have svideo and parallel ports to use them as monitors. If using the external monitor option you select the alt/enter buttons to display on projector.
Posted on Aug 07, 2009
projdoc
  • 2236 Answers
SOURCE: SHARP XV-Z91E Projector Replaced lamp but
hold down menu, enter, and down arrow, then press power. this is the only way to reset the lamp timer. if it won't turn on and there are no leds lit, you may have to reset the bimetal breaker. to do so, remove the 6 bottom screws and the top 2 screws on the back panel, and remove the top case. on the front side of the lamp housing, you will see a red button. press it. if it clicks, it is reset. if it doesn't, it wasn't tripped, and you have a power supply issue.
Posted on Jan 12, 2010
Sharp projector timer unable to reset after replaced lamp.
Reset the lamp timer.
1,Connect the power cord.
2,While simultaneously holding down "menu","enter" and "down" on the projector, press "standby/On" on the projector and keep all four buttons pressed down until the lamp indicator starts blinking green.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset.
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Mar 07, 2015 | Sharp XV-Z9000, XV-Z9000E, XV-Z9000U...
Sharp projector Bulb replaced but still won't work?
check the ballast
Have a nice day!
Jerry
Lampdeng Limited
Nov 08, 2012 | Sharp Projector Lamp For Xv-z90 Xv-z90e...
Reset sharp xv-100 timer
Mar 05, 2012 | Sharp (CLMPF0053DE03) Projector Lamp for...
Can you help me to download driver for sharp XV-C10A projector. i lost the old one
There shouldn't be a driver for that device. It should just be plug and play. Try plugging it in to the computer and see if it works, if not I'd recommend bringing it for repair.
Mar 23, 2011 | Sharp BQC-XVC10A//1 Projector Lamp for...
I need to buy a lamp for my Sharp projector
http://www.shopvsc.com/Sharp-Replacement-Projector-Lamps-s/130234.htm?searching=Y&sort=7&cat=130234&show=50&page=1&f-XV-C1E=130203
Sep 11, 2010 | Sharp (CLMPF0044DE01) Projector Lamp for...
Color wheel for a Sharp XV-Z2000
you can get the part from a sharp service center and replace it yourself or send the projector to one for repair. either way, try av solutions in ny. they're really good. www.avsolutionsny.com
Dec 17, 2009 | Sharp XV-Z2000 Multimedia Projector
Do you need software on pc to use the projector
Generally speaking, you shouldn't need any special software to use a projector connected to your computer. Usually you only need to set up the projector as a separate monitor under the Windows display properties. This is often done simply by pressing the Function key + one of the numbered keys F1-F12 on most laptops.
Nov 29, 2009 | Sharp PROJECTOR LAMP, Projector Lamp FOR...
Input Screen shows a permanent image
resolution issue. reset the settings to factory default. if that doesn't solve it, make sure the resolution on the projector matches what is on the computer. and it should take mac ok. also check the cable.
Aug 27, 2009 | SharpVision XV-Z9000 Multimedia Projector
Sharp projector
Oct 27, 2008 | Sharp BQCXVZ100001 Projector Lamp for...
Cameras Logo
94 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
