Question about Craftsman Garden
Sorry for my english. I by Sears tractor with a
Sorry for my english. I by Sears tractor with a motor Briggs and Stratton 441777 0726-E1 in 2007. I never use....stay in the box. I use this week after 4 years for the first time, and oil go out under the motor and go on the strap. I can't see where she come out ! (1/12 of pints after 6 hours) May be the oil seal ? But I am not a expert ! Do I have to take out the motor ? Thank you very much for your answer. Bye ! Jacques.
  • 3 Answers
SOURCE: Huskee 25 hp lawn tractor with briggs & stratton motor wont start
Most all manufacturers have the Users Manuel available on line you will need the Make and Model to pick the correct one. Have you replaced the battery. It can show the correct voltage but have no cranking amps. I believe if the solenoid is trying to engage the Dead Man switches are closed. With the starter disconnected from all power sources do the teeth on the starter turn or are they locked up? If they refuse to move do you have an Auto Zone around or another parts store or electrical engine repair store that can test the starter. Make sure the mowing deck is not engaged while you are trying to start the engine. I hope these rudimentary suggestions help.
Posted on Jul 18, 2009
  • 138 Answers
SOURCE: Craftsman LT 1000 with Briggs and Stratton 20 OHV
lift your seat and look at the label that you got your model number from. to the right of the model number is the serial number. the first six digits of the serial number is the date your tractor was made - for example: serial no. 060802D002756 would make the unit made June 8, 2002
Posted on Aug 18, 2009
panilling9
  • 284 Answers
SOURCE: how to adjust valves on briggs and stratton 17.5
Remove spark plug
Remove cover from engine that covers the flywheel
Remove rockerarm cover or valve cover
Find TDC (top dead center) by rotating the flywheel by hand and your finger over the spark plug hole as you rotate the flywheel you will feel pressure against you finger at some point then stop.
This is the compression stroke it is called now find a long slim round piece of plastic or plastic ink pen to stick in the spark plug hole (If you are careful a slim screwdriver can be used ) and find the piston top, then slowly rotate flywheel again (cw) as the piston is moving up pushing the plastic up as you rotate the flywheel slowly.
a max. piston up or tdc as you turn you will feel and then the piston starts to go the other way,at that transition this is tdc (piston is on top of stroke) leave it there,,both valves should be closed at that point.
Have a feeler gauge and set the exhaust valve at a loose .002 and the intake a loose .004 be sure engine is cold when valves are adjusted
Feeler gauge goes in between the rocker arm tip and valve stem top for each valve setting.
Note the rocker adjustment at the push rod side of each valve by tightening and loosening to make adjustments,lock your adjustments in place and rotate flywheel a few times and recheck settings
Posted on Sep 20, 2009
  • 760 Answers
SOURCE: I have a Sears Craftsman lawn tractor 917.256531
Make sure you didn't overfill oil. You can download a manual here: http://www.managemylife.com/mmh/owner_manuals/27208/CRAFTSMAN-Lawn-Tractor-L0808359?brand_name_search=917256531+CRAFTSMAN
You can find parts at www.searspartsdirect.com
Many manuals are listed on page once you look parts
Posted on Oct 02, 2010
  • 203 Answers
SOURCE: I just want an owner's
http://www.briggsandstratton.com/engines/support/operators-manuals.aspx?NTT=42A707-2238-E1
Should fix you right up.
Posted on Oct 05, 2010
Testimonial: "I am sorry if I sounded rude about the manual. I just could not find the right link. Thank you for your timely answer. I 'm sure this will work."
Wondered what year Sears made this tractor?
If the tractor has a Briggs engine, the code on the engine will give you the manufacturer date of the motor, most likely correlating with the model year of the tractor. Here is how you read the Briggs and Stratton engine code.
http://www.scribd.com/doc/25153865/Briggs-Stratton-Small-Gas-Engine-Service-Maintenance
May 14, 2011 | Garden
WHAT WEIGHT OF OIL IS NEEDED FOR A YS4500 W/ A 21 HP BRIGGS AND STRATTON MOTOR
I have used 30 WT oil in all my 4 cycle engines. You could google Briggs & stratton to get some info. Sears will sell you an operators manual. Try googling Sears, you might get lucky & get the manual for free..
Louie Almond
Mar 27, 2011 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
I have a sears craftsman tractor,18 hp electric start. No. 917.254860. engine no. 422707,type no. 1522.01. briggs and stratton. engine won,t turn over. Replaced plugs,coil,carborator rebuilt to specs. New...
From your description it seems that the starter is not engaging to turn over the engine. First ensure all the connections of the thicker cables to the battery, starter and tractor frame are clean and tight. If starter motor is turning but still not engaging it will mean that the pinion on the starter motor is binding on the shaft. You can buy a new starter pinion gear from your local B & S agent.
To replace pinion, remove starter motor from engine, remove old pinion and put on new one and reattach starter to engine. If fuel & spark are right you should be up amd running.
Sep 16, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Engine won't start and backfires
Did you loosen the coil when you changed the key? Check the setting between the flywheel and the coil. !0,000ths, I think.
May 17, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Jd tractor 11hp briggs engine has no stark
I would check the stator which is located on the top or side of the motor, this is what produced spark and if there is rust on it it will lose spark. so basically remove the fan housing the top of the motor and you should see it either on top or directly on the side i believe it has one wire going to it green in color and is held down by two bolts. good like look out for the rust
Apr 17, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
