MANUAL FOR RH LOGIC 400/300 OFFICE CHAIR ASSEMBLY. AM TRYING TO REMOVE THE HEADREST FROM CHAIR
SOURCE: trying to remove a headrest from passenger seat in 2007 xc90
push & hold button on headrest while pulling up
Posted on Feb 19, 2009
ourhowse
  • 2007 Answers
SOURCE: Headrest removal
When you pull it up all the way, you should see a very small hole at the base of the rod. Poke a small nail in there and that will release the catch.
Posted on Jul 01, 2009
  • 277 Answers
SOURCE: How do you remove Driver's Side ( RH drive) tail
If it doesnt have a acsess panel to remove in the trunk you will have to pull carpet cover back to get acsess to plastic wingnuts or bolts holding it in. Hope this helps
Posted on Jun 19, 2011
emissionwiz
  • 76691 Answers
SOURCE: How to remove the front headrest of Holden 2008 SV6 commodore ?
You need a special tool that slides down the side of the head rest shaft and release the spring clip retainer.
Posted on Jul 12, 2012
  • 14 Answers
SOURCE: Ordered Fuego Multi-Function Task office
step 1: press the 5 casters into the holes on the star base (it's a firm press until they snap into place) turn it over so the wheels are on the ground and push the gas cylinder into center hole. place black sleeves over it. set it aside.
step 2: attach armrests to seat base using bolts (I) and washers (K) (the longer and thinner bolts and smaller washers) using the allen wrench supplied.
step 3: attach the seat plate (the thing with the 3 handles) onto the bottom of the seat cushion using bolts (J) and washers (L) ( the fatter and shorter bolts and larger washers) usint the same allen wrench.
step 4: place the set onto the base into the big hole that acceps it. then sit on it to ensure it stays, otherwise when you pick up the chair it will come off the base.
step 5: slide the seat back bar into the groove where the know shows at the back of the seat. you may have to loosen that knob first. when it is in, press the little black plastic button (M) into the hole at the bottom of that seat bar to keep it from sliding out when you pull it up to adjust.
step 6: play with the levers to learn how to do different adjustments.
step 7: congratulate yourself and be proud that you did it!
Oh, make sure all the bolts are tight before putting into use.
Posted on Jul 22, 2012
Needing repair manual for 1998 lincoln mark viii lsc. cant find the air ride suspention compressor
  1. NOTE: Air compressor and compressor air drier assembly is located ahead of the front RH wheel. It may be convenient to service the solid state compressor relay and the four air line connections by disassembling and carefully bending back the forward section of the RH front fender apron (16054).
  2. Raise vehicle on hoist. Refer to Section 00-02 . Suspension must be in full rebound.
    1. Remove wheel and tire assembly.
    1. Remove RH front fender splash shield (16103).
Jul 27, 2017 | Lincoln Cars & Trucks
I need assembly instructions
Google the chair model number. Or; go back to the store and take some pictures. of an assembled chair of the same make and model.
May 14, 2016 | Furniture
How to remove the headrest
At the bottom of the two metal posts you should see a metal piece that you press in and the headrest should slide upwards...
Mar 28, 2015 | Pride Mobility Products Health & Beauty
How to toggle a headrest to reverse
What kind of chair and head rest do you have?
Most headrest require a reset/mode switch to be activated when you do not have your head touching any part of the headrest.
Sep 14, 2014 | Invacare Health & Beauty
Realspace calusa 857-562 office chair assembly manual instructions
This is the assembly for the Realspace Calusa Mesh Back Chair purchased from Office Depot (Item # 857-562). Mine didn't include instructions, so I chatted with customer service so you don't have to. 21937093-7787-4d5c-b10a-039106d04319.png 4653abb7-9b00-4c0c-b897-bda872bd5d08.png
Jan 19, 2014 | Furniture
I am looking to buy a Jet 3 from a neighbor but there is no manual. I am trying to find out if they fold up to put in a trunk.
On the Jet3 Ultra the armrests and footrests fold up. The headrest is adjustable up and down. I don't recommend removing the seat except to work on the batteries - the wiring could be damaged. My answer is NO! This is a 300+ lb. power chair and very awkward to manhandle.
Sep 25, 2012 | Jet 3 Ultra Power Chair
How to remove headrest of a 1990 lexus LS400 power seats, can you help please!!!
On both sides of the headrest spokes are little adjuster rings. Adjust the headrest up to the highest position. Push down on both of the adjuster rings. While doing that, pull up on the headrest and it will pop right up. Here is a link to help you with all other questions: http://www.clublexus.com/forums/ls400/18383-trying-to-remove-front-seat-headrest-on-ls400-dont-want-to-break-it.html
Apr 26, 2011 | 1990 Lexus LS 400
How to remove front stabilizer bar in '05 Scion TC
I don't know if you can get the bushings out without changing the bar or not, but changing the bar is a big job for a DIY. I was thinking about it but will probably have a pro do it for me. From the shop manual: 1. PLACE FRONT WHEEL FACING STRAIGHT AHEAD 2. REMOVE COLUMN HOLE COVER SILENCER SHEET (See page SR-9) 3. DISCONNECT NO. 2 STEERING INTERMEDIATE SHAFT ASSEMBLY (See page PS-21) 4. DISCONNECT NO. 1 STEERING COLUMN HOLE COVER SUB-ASSEMBLY 5. REMOVE FRONT WHEEL 6. REMOVE ENGINE UNDER COVER LH 7. REMOVE ENGINE UNDER COVER RH 8. REMOVE FRONT STABILIZER LINK ASSEMBLY LH (a) Remove the 2 nuts and front stabilizer link LH. HINT: Use a 6 mm hexagon wrench to hold the stud if the ball joint turns together with the nut. 9. REMOVE FRONT STABILIZER LINK ASSEMBLY RH HINT: Use the same procedures described for the LH side. 10. DISCONNECT TIE ROD END SUB-ASSEMBLY LH (See page DS-6) 11. DISCONNECT TIE ROD END SUB-ASSEMBLY RH (See page PS-21) 12. DISCONNECT PRESSURE FEED TUBE ASSEMBLY (See page PS-21) 13. DISCONNECT FRONT SUSPENSION NO. 1 LOWER ARM SUB-ASSEMBLY LH (See page SP-22) 14. DISCONNECT FRONT SUSPENSION NO. 1 LOWER ARM SUB-ASSEMBLY RH HINT: Use the same procedures described for the LH side. 15. REMOVE FRONT FLOOR PANEL BRACE (See page EX-2) 16. REMOVE CENTER EXHAUST PIPE ASSEMBLY (See page EX-2) 17. REMOVE HOOD SUB-ASSEMBLY 18. REMOVE NO. 1 ENGINE COVER SUB-ASSEMBLY 19. SUSPEND ENGINE ASSEMBLY (See page MX-19) 20. REMOVE NO. 1 HOOK (See page PS-22) 21. REMOVE FRONT SUSPENSION CROSSMEMBER SUB-ASSEMBLY (See page PS-22) 22. REMOVE FRONT NO. 1 STABILIZER BRACKET LH (a) Remove the 2 bolts and front No. 1 stabilizer bracket LH from the suspension crossmember. 23. REMOVE FRONT NO. 1 STABILIZER BRACKET RH HINT: Use the same procedures described for the LH side. 24. REMOVE FRONT NO. 1 STABILIZER BAR BUSH (a) Remove the 2 No. 1 stabilizer bar bushes from the stabilizer bar. 25. REMOVE FRONT STABILIZER BAR
You can download the manual online for about $15. Well worth it.
Jun 30, 2009 | Scion TC Cars & Trucks
Wiper motor replacement
SECTION 501-16: Wipers and Washers 1999 Town Car Workshop Manual REMOVAL AND INSTALLATION Mounting Arm and Pivot Shaft Removal
  1. Disconnect the battery ground cable (14301).
  1. Remove the windshield wiper pivot arms (17527).
    1. Remove the nuts (one each side).
    1. Remove the windshield wiper pivot arms.
  1. Remove the LH and RH cowl top vent panels.
    1. Remove the hood weatherstrip.
    1. Remove the screws.
    1. Remove the retaining clips.
      • Disconnect the LH and RH washer hoses.
  1. Position the windshield wiper mounting arm and pivot shaft (17566) assembly aside.
    1. Remove the nuts.
    1. Remove the bolt.
    1. Position the windshield wiper mounting arm and pivot shaft assembly aside.
  1. Remove the windshield wiper mounting arm and pivot shaft assembly.
    1. Disconnect the electrical connector.
Motor —Windshield Wiper Removal
  1. Remove the windshield wiper mounting arm and pivot shaft (17566) assembly; refer to Mounting Arm and Pivot Shaft .
  1. Remove the windshield wiper motor (17508).
    1. Remove the output shaft bolt.
    1. Remove the bolts.
    1. Remove the windshield wiper motor.
May 01, 2009 | 1999 Lincoln Town Car
Trying to remove a headrest from passenger seat in 2007 xc90
Feb 19, 2009 | 1990 Volvo 740
501 people viewed this question
jasbo
jasbo
