Question about Insignia NS-30HTV 30" TV
What is the resolution and is the tv truley hi def?
    Scholar:
  • 126 Answers
When in doubt google the model number
http://www.epinions.com/specs/Insignia_NS_30HTV_TV
thanks,
michael
Posted on May 27, 2011
How do I hook-up a blue ray HDMI to my AKAI HDTV thru a digital cable box?
If your TV doesn't have an HDMI port on it then you'll not be able to use the player. Some players have hi def output jacks, but it isn't true HDMI so using a hi def cable would defeat the blu ray players resolution when viewing a blu ray disk.
Nov 17, 2014 | Televison & Video
Can't get HD on my TV. Tried with every cable type but cannot get High Def
2 things have to happen. first, your tv has to be set for the correct resolution, second, You need to be recieving high def from your cable/sat provider.Your tv does not make programming high def, it allows high def.
Mar 10, 2011 | Insignia 32" 720p Flat-Panel LCD HDTV
Hi, we have a ps3 we play Black Ops on. Its connected to a Sony Trinitron tv w/composite cables. Lately, the picture has been very hazy and dark, no bright colors like it used to be. Its hard to see where...
green sounds like a TV problem if persists with other games could be TV but im kinda thinking it is ingame settings occasionally updates can reset picture settings in the game i think for black ops it had some kind of adjust brightness until you can't see this object in background and sometimes it helps to go back and check that only other explanation would be you went to different resolution ex: 480, 720(hi def), 1080(highest high def)
Jan 15, 2011 | Sony Playstation 3 (PS3) Console
Activating HD mode
You do not activate or set the TV resolution at the TV, the signal feeding the TV has to be hi-def for the TV to show HI-DEF. TV will show what is being fed with, lo-def in = lo-def display.
Dec 09, 2009 | Sansui HDLCD1908 19 in. LCD TV
How to change a dynex lcd32 tv from 480ip to 1080ip
You do not set the TV resolution, what you put in is what you will get, works the same as your PC monitor. HI-DEF IN = HI-DEF OUT.
Dec 09, 2009 | Dynex DX-LCD37 TV
We have cable T.V. should we run the cable though T.V. when we use s-video cables or use cable though vcr then T.V.
I would hope that you would use a HDMI cable to connect your cable box to your LCD TV - why not display the highest resolution to your screen that you can. HDMI will transmit the 1080P high def signal to your screen. These cables can be found at Wallmart and Target or even Best Buy. Don't need the most expensive and or a 6' length or short will work just fine.
Then use your S-Video cable to connect your VCR/DVD to your LCD TV - This is not a High Def signal - only 480i if that. The P means Progressive or 1080 lines from top to bottom. the I means Interlaced to which means 240 lines once for field one then 240 lines for field two.
You may want to think of a blue ray player to which upconverts your older DVD's to 4x3 High Def resolution.
Happy Thanksgiving and God Bless,
Blessings,
A/V Media Tech Guy
Nov 23, 2009 | Vizio L32 32 in. LCD HDTV
Blinking
Hi, the capacity of your TV is not good for Hi-def.. the resolution of your TV should be equal or less to the capacity of your TV. See the manual for the best resolution for your TV
Jul 06, 2009 | Toshiba 46H84 46" Rear Projection...
Only get 480p
Hi.
Your friend is wrong you will get same resolution of 1080i whether you use component or Hdmi.
But you will need a high def input to tv in order to get this resolution EG high def cable box or satellite.
http://dysonmanuals.llc.nu/
Mar 24, 2008 | Sony KLV-S32A10 32 in. HD-Ready LCD...
Cannot get my tv out of 480
you have to go into the xbox 360 settings and change the output screen resolution to 1080i and also check your tv settings input to receive 1080i also.
Sep 10, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Hd ready?
On any High Def TV, the reciever you need for this set, which does not have a HD receiver in it, is half the equation. Most HD channels have some HD content mixed with SD content on the same channel. SD content on HD signal from cable or satellite tends to be slightly blocky due to the native signal resolution and the resolution of HD (1080i/p or 720i/p).
Apr 30, 2007 | Akai PTH5498 54" Rear Projection...
Insignia NS-30HTV 30" TV Logo
24 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
