Question about Canon EOS 500D EOS Rebel T1i Digital Camera with 18135mm lens
Tried to take pictures of lightening last night and couldn't. My lens kept going in and out and wouldn't focus so wouldn't allow me to shoot. Then I kept getting a BUSY across the screen. Can you help.
    Scholar:
  • 59 Answers
For this kind of pictures, Don't try to focus on a lightning, it is to quick and mabe the overall brightness is not enough for your camera to focus.
So you can try to focus on something at infinity, if you manage then, put your focus on manual before re focusing, this way you will be able to take as many pictures as you want.
You can also try to focus manually directly.
And for you information the best way to take a lightning picture is to put your camera in bulb mode, use a remote control, open the shutter and close it as soon as you'v seen a lightning.
Hope this helps.
and good shooting !
Posted on May 27, 2011
    Sergeant:
    Champion:
  • 214 Answers
Hi I suggest you find out what cause the problem like memory card, lens, or body itself. First, remove lens and memory card both. Please setup M Mode and enable without memory card function. Then set Bulb shutter speed, press shutter release button and hold the button 2 to 3 second. If properly working, you should see image sensor front of mirror box inside and it means mechanical function doesn't have problem. If not, please tell me how it doesn't work as much as describe functional information. Thanks and kindly regard!
Won't start
What engine do you have?
May 20, 2013 | 1989 Ford Bronco
Tip
After reading SteveGorak's experience, I placed the vacuum end of my...
Hello
This is a tip explaining how we can try to resolve a lens error.
Firstly you will need to understand what exactly the lens error is, and how it came to happen.
The most common cause for a Lens error:
  • Misaligned Lens rings
  • Sand and grid wedged in between the lens and the barrel.
  • Dropping the camera
  • Ran down battery
Here is the Fix:
  • Batteries
Firstly you can try removing the batteries and replacing it with a new set of fully charge ones(2500mah).
  • Memory card
If the batteries ran down while you were taking photos with the lens extended, you might also get this error. Remove the the memory card and replace the batteries with a fresh recharged set. Try to power on the unit with the fresh set of batteries while the memory card is removed.
  • USB cable
Connect your camera to your computer using your USB DATA cable which came with the camera. Once the camera gets power in this mode, the screen should stay off, hence, supplying the lens with more power to push or pull out/in.
  • Barrel Guide Pins
Place the camera on a sturdy table with the lens pointing to the ceiling. With a fresh set of batteries installed(Do this without a memory card) hold down the shutter button while you power on the unit.
  • Compressed air and Vacuum
Now, you can either use a compressed air canister to blow around the lens area. This will result in the sand or dust particles to be blown out of the area between the lens and the barrel. Or, you can use a vacuum and and carefully place the nozzle around the lens to **** out the particles.
The following Fixes will be done at own risk and can even further damage you camera.
  • Tap your camera with the palm of your hand a couple of times to displace the lens into the original position, or to dislodge particles in the lens barrel.
  • Try gently pushing/pulling/wiggling the lens while powering up the unit.
I hope this can help you to resolve this problem, and send you well on your way to experience that Legendary Kodak moment.
Kind regards
Andrea
on Sep 06, 2011 | Cameras
I have a canon rebel xsi that is not taking pictures on auto focus. It will take pictures on manual focus, but they're blurry. I changed my lens to a bigger one to see if it was the lens or camera, and...
Try cleaning the lens contacts on the camera body and on the lens.
This maybe the problem, it is not making contact with the lens zoom motor.
Dec 12, 2012 | Cameras
Why does my Nikon D60 while on auto focus or quick shutter speed either not focus and take the pic or focus and not take pics?
I have a 5D Mark II that has acted up like this. 99% of the time it will reset itself it you power off, remove the lense and allow them to sync up. Try this, it may work for you too!
Apr 22, 2012 | Nikon D60 Digital Camera with 18-55mm lens
The auto focus does not work properly with this lens on either my Nikon D5000 or D7000. I have tried all possible combinations of AF settings. Typicaly, when I use single point to focus, the subject I...
Hi, It wouldn't autofocus on the D5000 as the body doesn't have an auto focus motor in the body and since that lens is AF, not AF-S, it won't autofocus. It should autofocus on the D7000 though, how far away are you from the object you're trying to photograph?
Aug 28, 2011 | Tamron SP AF 17-50mm f/2.8 XR Di II LD...
It won't take pictures sometimes. push the shutter button and nothing happens.
The Nikon D40 in Auto Focus mode will only allow the shutter to operate when the image is in focus. When looking through the viewfinder, the bottom edge provides information relative to what you are looking at. See the image below:
Item 2 is the focus indicator. It must be illuminated to allow the shutter to release. If it is not illuminated, the lens has not been able to determine the correct focus. This can happen when attempting to take a picture in low light conditions. Make sure that the front facing "focus assist lamp" on the camera (between the shutter release and lens) has not been blocked or disabled (Settings Menu # 09) and try again. Many times, you will see and or hear the lens "hunt" for proper focus - the lens will travel from one end of its focus range to the other trying to find focus. When it can't, it stops and prevents the shutter from releasing. You can get around this "unable to focus" issue by changing the position of the switch on the lens to "Manual Focus" mode, detailed below:
If a lens has an "A - M" switch, move it to "M" to manually focus. If the switch says "M/A - M " then leave on M/A (unless you're going to be taking several or more in manual mode), as these lenses may be focused manually at any time in either position. As soon as you tap the shutter button in M/A you return to autofocus.
More advanced lenses, like the 18-200mm, 70-300mm VR and 18-135mm, and any lens with an M/A position, may be focused manually at any time without moving any switches. Leave them in their A or A/M positions.
I hope this helps and good luck!
Jun 13, 2011 | Nikon D40x Digital Camera
On my sony A200 camara .. I have a grinding noise when turning camara on and off from lens and sometimes when last bit of auto focus pictures are still good
it sounds like you have some sort of dirt or sand in the lens mechanism. this also could be a symptom if the camera was recently dropped.
if you can, try getting some condensed air and spray what you can in the cracks. if you aren't comfortable doing that, you can take it to a camera shop and have it cleaned.
the same thing happened to my camera and eventually, the lens wouldn't come retract, thus rendering the camera useless.
hope that helps.
May 07, 2011 | Cameras
My Pentax K100D has suddenly stopped working. It hasn?t been bumped or dropped or anything. A few days ago I was still taking pictures, and then a day or two later when I tried it, it wouldn?t work. When...
Hi there as per your mentioned sound or noise is says that the problem create by your camera lens guide pin. Its damaged or dislocate. So i also suggest you to visit the service center. Thanks.
Apr 03, 2010 | Pentax K100D Digital Camera
Canon EOS 500D EOS Rebel T1i Digital Camera with 18135mm lens Logo
307 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
