Question about Garden
10-1/2" Bow window (PVC) Was manufactured
  • ray0427c May 27, 2011
    Have pictures?
  • 32 Answers
If the unit is not too long or protrude to far out you can line the bottom with 3/4" plywood and slide into opening. If larger unit Dog legs (angle supports) will have to be added to the bottom of the unit exterior screws will hold longer than nails. Put dog legs as close to where every window joins together (if larger multi window unit) and back down into the framing of the home (use pressure treated lumber) cover with matching home exterior coverings.
Posted on May 27, 2011
How to safely remove adhesive residue from PVC windows?
Natural Eucalyptus oil or natural Tea Tree oil will dilute the glue and enable you to rub it away without affecting the PVC.
(I would prefer not use a solvent such as mineral turps or kerosene or methylated spirits. These will all soften and remove the glue at differing rates but might cause minor swelling in the PVC material. Less likely with the methylated spirits though. You can test a small inconspicuous area first to see if there is any effect).
Nov 16, 2015 | Cars & Trucks
Where can I order pvc and upvc windows and doors online?
Fenesta Building Systems is the largest UPVC windows and doors manufacturer in India. You can order PVC and UPVC doors and windows. For more details visit: http://www.fenesta.com
Feb 24, 2014 | Top Knobs Hardware & Accessories
How can I increase my laptop battery life?
To increase the battery operating timeline you can do a number of things. These usually include dimming the screen, adjusting the power setting to turn the screen off after 10 minutes and stop the hard drive from spinning when idle after a period of time too.
Results will vary from laptop to laptop and depends if the quoted 6 hours 30 minutes time frame is an actual recorded time of usage off ac or based on windows assumption and estimation.
Windows power management can only tell you the time in which battery power is maintainable for based on the consumption rate at the time. With this being said start up and playing games will utilise more power that say word processing after the initial startup has cooled down.
Some laptops can be operated without the battery however there are an increasing number of laptops these days being manufactured without this option. You can attempt to operate it without the battery and doing so will not damage the laptop in any way. If anything it will maintain the life expectancy of the battery.
Jul 05, 2012 | Computers & Internet
Have 12 V bow mount trolling motor that doesn't start working until power is on for about 5 minutes. Then when it does start, have to have the power on 10 just to keep the prop moving. Checked prop and...
Hello, You have several points to check. #1 check your wiring connections--- plug, plug socket, wiring connections internal of trolling motor, condition of wiring to battery, battery terminal connection & charge of battery. #2 borrow someones DVM (digital multimeter) and check the resistance of the speed control as you turn it without any wires connected to it. #3 if problem not found take 2 aspirin and E-mail me of test results "for further review".
Sep 18, 2010 | Minn Kota Maxxum 70 Freshwater Bow Mount...
I want to connect a single phase 24 amp kiln under my waterproved pergola. What electrical work needs to be done and how much would it cost approxmatly?
That kiln requires a 30 amp circuit, minimum. 24 amps x 125%= 30 amps per National Electric Code (NEC).
Without more info, I'll need to make a few assumptions. For the sake of estimating the cost I'll present the following scenario:
1...The distance from your electric panel to the pergola is approximately 100 feet.
2...The circuit will be underground. I'll assume that you will be able to hire someone to dig an 18 inch deep trench from the electric panel to the pergoda for $10 hr. While this should only take 3 or 4 hrs, depending on soil conditions, it could take all day. So I'll assume $80 for this.
3...This will be a 240 volt, 30 amp circuit (see why below).
4...Since you posted under the Intermatic T171, and since that is a 120 volt timer, that the kiln is 120 volts.
5...Unless the pergoda is fully enclosed, NEC still requires a weatherproof installation.
For starters, I don't recommend a 120 volt kiln. Most people I've known who had a kiln always seemed to want a bigger one ;-) Again, I'll do the estimate for a 240 volt, 30 amp kiln, as the price difference compared to a 120 volt circuit is about the same.
Also, I strongly recommend using 3/4 inch PVC conduit as opposed to 1/2 inch PVC or UF (direct burial) cable. 3/4 inch conduit doesn't cost much more than 1/2 conduit and will allow you to install wire up to #6. UF cable, in my opinion, is out of the question because if you ever decide that you want a larger kiln the direct buried UF cable is _not_ easily replaceable. A conduit and wire installation is about the same price as UF anyway.
Here's the breakdown (US dollars):
$ 10 - 30 amp, 2-pole circuit breaker
120 - 300 feet of #10 THWN COPPER wire (40 cents a foot)
20 - 1 bundle (100 feet) 3/4 inch PVC conduit
10 - 3/4 inch PVC elbows, fittings, straps
20 - Weatherproof box and weatherproof cover
+15 - 30 amp receptacle
______
$195
+100 - 2 hrs labor @ $50 hr. (possibly 3 hrs.)
______
$295
+80 - labor for trench
______
$375
+140 - Intermatic T172R (weatherproof) 240 volt timer
______
$515
Other considerations are that, if indeed, the circuit is 100 feet, you should consider using a #8 THWN COPPER wire to account for voltage drop (add $60, @ 60 cents a foot) Using a #10 wire at that distance may not allow the kiln to get to the desired temperature.
If you are anticipating things like lights, 120 volt receptacles, fans and such, the best way to do all that is to install a subpanel at the pergoda.
That should get you in the ball park as far as price. Of course, you can make adjustments accordingly. Remember that prices can vary greatly depending upon geographic location. Also, if you call a contractor for an estimate, _after_ they give you the price, _then_ ask how much they will knock off if you dig the trench.
A contractor price of $600 would not be unreasonable.
Hope this helps.
Jun 02, 2010 | Electric Intermatic T171 24 HOURS 40 AMPS...
R.v. coleman mack furnace
Try calling a local appliance repair or HVAC/refrigeration contractor.
A mechanical refrigeration contractor would have a better chance of having or being able to get replacement parts faster. But you have to get someone with an HVAC knowledge to look at it.
While the R.V. mechanics may be good at simple repairs or general knowledge, you need a trained eye to look at this issue here.
I would suggest to have a tech diagnose the problem and quote to repair. If the quote sounds reasonable, then go for it (your paying for expertise and a warranty). If not, then you at least have an idea of where the problem lies and what steps needs to take place to try to get it fixed.
Jan 06, 2010 | Coleman Mach 15 Air Conditioner
Canoe has damage on the front bow.
Bondo would probably work.
Also, you could laminate a few pieces of something like vinyl siding/facia board over the hole. If the canoe is ABS, the vinyl siding cold be "welded" / fused to the ABS with PVC primer & solvent/cement.
May 27, 2009 | Coleman Cable Coleman Inflatable Boat...
Garden Logo
50 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
