Question about Sony FD Trinitron WEGA KV-32HS510 32" TV
KV32HS510 Standby light blinks 7 times. If I unplug the unit overnight the next morning when I plug it in it will work
  • dschaare May 27, 2011
    Thanks I am very much into electronics, so thanks again for letting me know what 7 blinks was all about.
  • Sony Master
  • 2,098 Answers
7 blinks is an error code for "Horizontal Deflection failure". Once the unit gone to this fault, it will automatically shuts down the unit. This kind of symptoms is not DIY if your not handy with electronics because you will work in the high voltage circuitry section where the flyback transformer located.
Faulty electrolytic capacitor in this section will produced an out-of-regulation condition and will vary the high voltage output of the flyback transformer and will trigger the X-ray protection circuit. Sometimes it will work normal but there's a time it can no longer stable itself and will gone bad. Bad solder joints (cracked,dried,cold solder) will do the same symptoms and this section is prone for that because of heat build-up upon operation.
If you don't have necessary tools and test instrument and can't troubleshoot the unit yourself, I would advice you to look for a qualified tv technician to isolate the symptoms.
Also, check if your unit is still under warranty/extended warranty period, avail it because the manufacturer will fix it for free. Don't attempt to open the back cover because it will void the warranty.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on May 27, 2011
Battery life draining overnight
Try disabling everything you can through the software, if not possible, unplug them. Then plug one in at a time and leave it overnight. If its OK in the morning, plug in the next item, and so on. Make sure battery is fully charged between each test. When the unit discharges overnight again, the last item you reconnected befroe it discharged is the one causing the voltage drain.
Aug 20, 2014 | Toshiba NB520 Netbook
IT WONT TURN ON MY SONY KV32HS510 BLANKS 7 TIMES
Try unplugging for a few hours. Unit may need a reset. If that doesnt help try looking for any burned up fuses. Beware the tv holds charge even when unplugged. You could also take it to a repair shop, most parts are still available for those units. Hope this helps.
May 29, 2011 | Televison & Video
My Sony Trinitron shut down last night. I
4 times standby light blink shows that tv got problem in vertical deflection section and probably vertical output IC got defective, need to be replaced.
Replacement of parts in circuit board requires soldering work and expertise so call local tv repair shop guy if you are not familiar with soldering work.
Thanks.
Jul 25, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
KV32HS510 Blinking standy light will not turn on blinks 7 times
This happens when high voltage reaches 33k,it shuts down for safty. Unplug it from the wall outlet,then remove the back from tv,then check the power supply And horizontal circuits.for faults,with an ohm meter,check all solder joints for cold or bad solder connections,resolder most, check fuse,if no reading on the meter with one probe on one end and the other probe on the other useing the ohm scale,replace the fuse. Always replace it with the same amps,its writen on end of fuse......hope this helps...........
Feb 22, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have power but it will not turn on. unplugged from power cord overnight then plugged into wall worked fine until i shut it off again, now it keeps blinking the delay light
go to turn tv on,hear a poping noise,once then tv standby lite blinks 3 times repeatily but no picture or audio.can you help me out with this thank you
Feb 14, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Sony Trinitron Wega Standby blinks & the TV won't turn on
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 12, 2017 | Sony FD Trinitron WEGA KV-32FS120 32" TV
KV-40XBR700, won't come on, standby light blinks 7 times.
sony KV40XBR700 tv no picture but sound is on, standby light blinks 6 times
Jul 20, 2009 | Sony KV-40XBR700 40" TV
I have a Hitachi Plasma TV model 55HDS69 that recently went black while being watched. I turned the main power off and unpluged it overnight and tried turning it back on, but only the red standby light...
Do it again, only this time unplug any video and audio inputs and outputs, unplug it from any power source, and leave it sit overnight.
I had the same problem with my Hitachi. I called a local repair shop and he said to unplug it for 10 minutes and start it again. That didn't work so I got it ready to take to the shop. I disconnected everything. The next morning I decided to check it one more time so I reconnected everything. It worked just as it had before.
I hope it works for you.
Jul 13, 2008 | Televison & Video
Sony KV32hs510 - Won't come on flashing light - 6 or 7 times
hi there, you have the hardware prob., at the power supply section., test the bleeder resistor which is 100 kilo ohms or higher, do some check up and test. ty
Feb 16, 2008 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Sony FD Trinitron WEGA KV-32HS510 32" TV Logo
411 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
