Question about Skull Candy HESH Consumer Headphones
My headphone cable is broken. How do I replace it?
    Scholar:
  • 59 Answers
Buy a good Jack to Jack cable, open your headphone, find out where the two cables are soldered, unsolder them.
Cut one end of your new cable, remove the plastic aroud the 2 wires on a small lenght and solder your new wires where the old were.
Et voila.
Hope this helps
Posted on May 27, 2011
Broken headphone jack on dell d630
Yes! if the plugin is not secure the connection will be poor causing unstable reception in the audio department.
May 10, 2012 | Dell Latitude D630 Laptop Computer PC...
My bose headphones have just stopped working, is there a decent chance I can get them repaired fairly cheaply?
You can try taking to a electronic repair shop to check if the cable is broken somewhere, if so, it can be repaired, if thats not the case bad luck. always take care of the headphones cables, never tie them tight always keep them loose.
Apr 07, 2011 | Bose On-Ear Headphones
My right ear headphone is not playing any sound through it how do i fix this
you need to open it carfully and see if cables or one cable or broken
If the one cable its broken you need to solder it the speaker
Mar 28, 2011 | Sennheiser HD 205 Professional Headphones
You hear one side if I move the cable to the sides and sometimes sounds the other hand I think can be a cable cut
It's a broken wire, obviously. it's probably broken near the jack or the headphone. ur going to have to replace the cable
Mar 08, 2011 | Skull Candy G.I. Consumer Headphones
I purchased this mp3 on 11th devmber. the music is not getting through to the headphones - can you help? is it powered by a battery & is one included as standard?
Hi mharrington9,
You may want to post the make and model of your mp3 player. Someone may have solved the same problem with the same player, and would then be able to give you a more specific answer than this one;
I assume you have replaced or re-charged the battery first, and that full power to your player did not help. If so, it is likely to be a problem with the headphones, the headphone receptacle, or the amplifier inside the mp3 player;
1) Headphone problem?
Get a different set of ear-bud headphones, and try them out. If the alternative set works but your headphones do not work, it's the headphones.
1a) Large headphones, small player?
If your headphones are large, but the power of your MP3 player is small, the player may not have enough power to drive the headphone speakers. If you run your MP3 player through an additional amplifier, you may then have enough power to get sound out of your headphones.
1b) Broken wire in ear bud jack?
Most of my broken ear-bud sets have failed because one or more of the wires has broken, usually at the plug-end. There are 3 thin wires; If you break the left-channel or right-channel wire, only one earbud goes out. If you break the ground wire, both earbuds stop working, or you may hear a very faint sound at full volume. If you like to solder things, it is possible to get a new plug, cut off the old one, and solder in a new one. But it may be easier to get a new set of earbuds.
2) Broken Receptacle?
Plug your ear-buds into a different, working MP3 player. If the ear-buds work, then
Plug your MP3 into a computer through the data cable, and try to play something through the computer.
If the MP3 works through the data cable, something is wrong with the receptacle for your ear-bud plug.
You may be able to get your MP3 player replaced under warranty, since the purchase was recent. Or, if no warranty and you feel adventurous, take the back off and try to re-solder or replace the receptacle-- Though this usually ends in irreparable damage to the MP3 player :-\
3) Broken MP3 player?
If you can't get any music to play through the data cable or the computer, something is seriously wrong with the guts of the MP3 player. Try for a warranty replacement if you can.
Best of luck, mharrington9
Dec 12, 2010 | Audio Players & Recorders
The jack on my Sony MDR-NC6 has broken off. Can I
See my tip on dodgy cable/jack on headphones. If the jack is different to the one shown, you should be able to get it from Maplin (UK user) or Radio Shack (USA).
May 31, 2010 | Sony MDR-NC6 Consumer Headphones
The plug at the end of my bose headphones is broken
See my tip on replacing dodgy/cables plugs on headphones
May 28, 2010 | Bose Audio Players & Recorders
The cable on the headphone is broken, no music comes out anymore. Can I repair them / open the in ear headphones to resolder them ???
If the broken link is along the cable (not in the earphone) just cut the cable very close to the earphones and replace it with a new one (a stereo cable should contain at least 3 different wires inside). If the cable is broken inside the earphone itself, it is possible to solder it but because we are talking about a earphone it could be hard to open them and to closed them back in.
Apr 19, 2010 | V-Moda (BFRED) Headphones
Right speaker in headphone wire is broken or something, keeps going out when the headphone wire is moved. is there anyway to repair this?
The wire connection inside the cable is broken. You can disassemble it, cut the wire past the broken point (usually where it makes a sharp bend) and re-solder it. If the wire is too short, you need to get an new wire or get the wire from a donor headphone and replace it.
Aug 29, 2009 | Skull Candy G.I. Consumer Headphones
Skull Candy HESH Consumer Headphones Logo
208 people viewed this question
Top Skull Candy Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Owen Barnes
Are you a Skull Candy Audio Player and Recorder Expert? Answer questions, earn points and help others
