Appears to be working but we only get cool air; not outside temp and not cold, no matter how high we turn it up. Model is really Goldstar AC 301KA00871.
    President:
  • 1,515 Answers
This sounds as though you are low on freon. Normally, this is the last thing I would say, but with what you have said, you need to have the charge checked. If all is working but the air is not cold, but cool only, The model you gave me doesn't tell me much on the type system you have, if its a window, central system or package unit. You can try taking the water hose and washing the condenser coil if you are able to do so, if it is dirty it will cause the system pressures to be very high causing it not to cool.Anyway, do this and if you still have this problem, you will need to get it charged up. This is something you can't do on your own, as you can't buy this freon, or you don't have the know how to do this. You have to have the gauges and know the pressures in the system. I hope this has been of help to you.
Shastalaker7
A/C, & Heating Contractor.
Posted on May 27, 2011
My house air conditioner will blow cold air for a while when it is really hot outside ( i live in the california desert area ) but nothing but warm air will come out after the ac has been working for a...
Hi and welcome to FixYa, I am Kelly,
This certainly sounds like a low system coolant level issue. Have someone check the system pressures. Low side should usually be 65 to 70 unit running. High side will vary with outside temps any where from 135 - 170. If you do not have good low side pressures it will affect the high side pressures also. This is really the only way your going to sort this one out.
Look around the evaporator and the condenser for any signs of OIL or dark spots caused by oil. That is usually an indication of a system coolant leak.
Thanks for choosing FixYa,
Kelly
This is who answered your question:
http://blog.fixya.com/index.php/2010/05/award-winning-service
Jul 10, 2011 | Heating & Cooling
Doesn't get cold even if temp is lowered to 62
Lowering the temp isnt going to make it cool faster ever. Check the filter and clean the condenser coil with a hose thats the portion thats outside. let me know what happens
Jun 29, 2011 | Goldstar M5200R Air Conditioner
I've had my air conditioner for a few years now and it no longer cools anything. The fan works, the condenser(?) turns on when I set it to cool instead of fan, but the air coming out of it isn't...
You need to determine if the compressor is running, if it is and you have no cooling then you either have lost charge or bad compressor, these units re not worth replacement compressor
Jun 22, 2011 | Goldstar R5208 Air Conditioner
A/c works fine in the morning, blows out vents at 55* - 59*. later in the day, and as it gets hotter outside, a/c blows hot air. What's up?
could be slightly low on charge-or cooling fan is not working-as the temp outside goes up the ac needs to be more efficent to blow cold air--and really 55 is not that cold--depending on outside conditions should be able to blow at low to mid 40 s
Aug 16, 2010 | 2003 Ford F250 Super Duty Crew Cab
AC not blowing cold air
have ac checked and refilled
Jul 04, 2010 | 1997 Mercury Mountaineer
Ac not blowing cold after outside temp reaches 98 degrees
Sounds like you have dirty condenser coils. Remove the upper shroud and check the condenser for clean. Take a water hose and gently spray out the coils paying special attention not to bend the coils over with too much pressure. This will allow more air movement through the coils and give you better cooling efficiency.
Hope this helps,
Jeff
Jun 29, 2009 | Dometic Rooftop RV Air Conditioner
Cold AC but weak Airflow---Also Driver side not as cold as passenger
The air doors are controlled by actuators that on of them or so may need replacing.
May 09, 2009 | Cadillac Seville Cars & Trucks
UNIT RUNS AN EXCESSIVE AMOUNT OF TIME AND AIR IS COOL NOT COLD COMING OUT OF VENTS CARRIER 58DLA / 58DLX CENTRAL AC FAN AND COMPRESSOR ARE OPERATING BLOWER IS WORKING UNIT IS TURNED ON TO AC TEMP SET AT 76...
DOES THE HOUSE FEEL DRIER IF IT IS 80 OUTSIDE WITH ALOT OF HUMIDITY THE UNIT WILL RUN FOR A LONG TIME TO REMOVE THE MOISTURE(HUMIDITY) OUT OF THE HOUSE BEFORE TEMP DROPS DRAMATICALLY IS THERE WATER COMING OUT OF THE DRAIN PIPE OUTSIDE
May 03, 2009 | Carrier Heating & Cooling
Heating & Cooling Logo
47 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
