Question about LaCie MosKeyto - USB Flash Drive - 16GB USB 2.0 Hard Drive
Lacie moskeyto is undetected in Windows 7 - LaCie MosKeyto - USB Flash Drive - 16GB USB 2.0 Hard Drive
    Novelist:
  • 77 Answers
If your BIOS is set to "allow classic USB support" (or similar terminology), then you are restricted to the drivers available at the date of BIOS version (or your PCs date of manufacture). The reason is, 16gb flash dd not exist n 2006. Most PCs/BIOS before 2006 can only mount 4gb flash memory or less. Most 2007 through early 2009 is limited to 8gb (this is not a restriction for USB HDD enclosures, older PCs can mount hundreds of gigabytes with older BIOS drivers).
1. If your BIOS allows you to change this setting, deselecting it may allow the OS to load a driver (Vista and Win7 both have native 16gb drivers).
2. Updating BIOS, if a newer one is available for your PC is also a solution, as flash media driver updates are almost always included.
3. if neither options are available for your PC, then you can go get a specific driver for this device from LaCie.com
One caveat: LaCie is renowned for slicing flash memory into two partitions. One is usually a "fake" read-only CD partition. This will not work in many updated BIOS, and even some of the newest PCs. USB HDDs can have multiple partitions, but not flash memory. If this is the case with your PC, then again, your only solution will be getting a device-specific driver from LaCie.
Posted on May 27, 2011
  • LaCie Master
  • 27,725 Answers
Click start right click on computer select properties then select device manager look through all of your devices if you see a yellow question/exclamation mark ? ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Posted on Nov 09, 2011
My Lacie Moskeyto USB stick can no longer be seen by my PC. More than that if the stick is inserted the My Computer window remains blank and the "hampster wheel" turns indicating the PC is...
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
hope this helps you
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
hope this helps you
Sep 12, 2011 | LaCie MosKeyto - USB Flash Drive - 16GB...
I have a 8 Gb Lacie Moskeyto flash drive, without ejecting it from my laptop, my laptop was left to sleep. Upon starting up my laptop, my 8 Gb Lacie flash drive, was left "Unrecognized" by...
When you switch on your computer press the F12 key that should take you to the boot screen , scroll down to the usb drive and press enter it should boot up to that .
Nov 02, 2017 | LaCie MosKeyto - USB Flash Drive - 16GB...
I have a Lacie mosKeyto 8GB USB Flash Drive. When it it inserted into a PC it just does not show up at all, meaning computers do not detect it. What can I do? thanks
hi have you try connect it to other computer? if is working i guess your usb port have problem try to connect your flash drive to other usb port at the back your cpu. if not working your usb flash drive have problem. thanks
May 28, 2011 | LaCie MosKeyto - USB Flash Drive - 16GB...
I can't access my files on the LaCie Moskeyto 16 GB USB flash when I plug in the dive in my laptop. The device manager says that no driver has been installed.
you might need to update the drivers or reinstall it
if you are having trouble with your drivers
here is a general look at the drivers and how to update them
if your computer came with a motherboard disc the drivers could be on it
ports(com&lpt)right click update driver hope this helps
Apr 06, 2011 | LaCie MosKeyto - USB Flash Drive - 16GB...
My lacie starck hard drive is not recognised by new computer, running windows 7
You need to install some components like lacie desktop manager,intrergo etc that came with the original device
Look for them on lacie's webpage
GameSting
Jan 23, 2011 | LaCie Computers & Internet
I have the Lacie Rugged hard drive 320,undetectable
Since you have tried connecting the hard drive (HD) into two computers (Win7 and Vista) and both of them had the same problem, you may want to try replacing the cable of the HD.
Another thing, try connecting the HD into a Windows XP computer and see if same thing will happen. If you're hearing a clicking sound while the HD is turned ON, I'm sorry to say but the HD is no longer working. That clicking sound is also called the "Click of Death".
Thank you!
Dec 10, 2009 | LaCie Computers & Internet
LaCie MosKeyto - USB Flash Drive - 16GB USB 2.0 Hard Drive Logo
618 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
