SOURCE: installing correction tape
This tape comrs in two small cassettes the full one loads on the L. side of the printer the tape goes across lower than the ribbon and wraps on the R. cassette.
DickyO
SOURCE: How do I replace the printwheel?
All you have to do is open the top cover and let the printer unit move at the center then pull knob towards you it locks to access the print/daisy wheel,remove it and replace it with the better one.Push the knob back.xerox 6010 automatically senses the home positin of the print wheel.
SOURCE: KEYS ARE STICKING ON MY XEROX MEMORYWRITER 6010
The Xerox keyboards can be rebuilt for about 100.00. Under each key is a foam pad that deterates over the years the must be removed and replaced. If you can get the keyboard to us we will do it for you.
DickyO
Cleveland Business Machines
216-241-0027
SOURCE: How can I release margins on my XEROX memorywriter
Get to the margin you wish to change Hold the code key, the key with the green oval and press thr top L. key that says mar rel in green, space or backspace to desired position press R. or L margin key depending on which one you are resetting.
DickyO
SOURCE: need spec information on xerox 6015 memorywriter
I suggest that you look bfor a different T/W as the supplies are no longer made for Memorywriters. IBM wheelwriters are a very good substitute.
DickyO
