Question about Haier Dehumidifiers
Dehumidifier running but no water coming in bucket. it's at 76 humidity. only 2 years old..how do i get it to work right
    Brigadier General:
  • 4,736 Answers
If you brief description of the problem is correct, you need to turn the humidity/moisture extraction percentage down to 35% and check and clean the air intake filter. Maintain a minimum of one foot air space clearance around the entire dehumidifier and be sure that all exterior doors and windows are closed. DO NOT attempt to remove and clean the filter with the unit ON and plugged in to the wall outlet.
Hope this helps you troubleshoot and solve the problem. Please let me know. Thanks.
Posted on May 27, 2011
Unit is about 5 years old - 40 pint unit (DN40G). It runs but does not dehumidify (no water in the tank) and humidity in basement is 80%. I wonder if the unit is just too old to work? Do you have any...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Aug 06, 2011 | DeLonghi Dehumidifiers
My dehumidifier runs and the refrigerator or cooling unit turns on, but no water comes into the bucket? Last year it was running fine? fans run and the humidity level is high in the basement
heatman101
Jun 09, 2011 | LG LHD45EL Dehumidifier
My humidifier will not remove water from the air anymore. The unit will run for hours with no water in the bucket. Temperature in the basement is about 63 degrees with a humidity level about 55%. But now...
heatman101
May 07, 2011 | Goldstar Dehumidifiers
My dehumidifier (new air AD 400, 6 months old) stopped working. Fan blows, humidity level is indicated, motor gets hot, but no water comes out. I tried unplugging, resetting, etc to no avail.
heatman101
Sep 18, 2010 | NewAir AD400 Dehumidifier
My Danby Silhouette DDR556RH dehumidifier is less than 2 years old (out of warranty) and is no longer drawing out the humidity. First, the hose connection to the sump pump stopped working (I have cleaned...
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
Aug 21, 2010 | Danby DDR556RH Dehumidifier
My glodstar DH305T7 dehumidifier wont stay on. Clicks on for a second then turns right off. Now it won't even turn on. There is over 70% humidity in my basement. Only 1 year old.
heatman101
Jun 17, 2010 | Goldstar DH304 Dehumidifier
Zenith ZD30 dehumidifier - 1 1/2 years old stopped working had a half bucket oc colledted water in bucket when it stopped. I checked the fuse on the circuit board and have continuity.
Unplug from wall. Take the front cover off and disconnect the 2 wires that attach to the humidity control dial. Plug back in. If it works, the problem is the humidty control dial (mine just went bad). With it unhooked, it will run constantly, but will still turn off when the bucket is full. To turn off, simply unplug.
Jun 16, 2010 | Dehumidifiers
Crosley dehumidifier does not collect water.
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
May 13, 2010 | Crosley 40-pint Dehumidifier
The dehumidifier runs all day but there is only a little water being produced. We have humidity set at 35%, and the actual readings are much higher. This is only a year or so old. The last machine worked...
coolant may be low - warranty should be 5 years
If the room temperature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
I out mine over the floor drain.
Turn off and it will defrost over night.
Only specially made dehumidifiers work below a room temp of 60 degrees (the temp of a basement in winter).
Does it need to be running? A digital humidity sensor from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
Dec 10, 2009 | Fedders A7DH45B2A Dehumidifier
Danby Dehumidifier
I dropped the water bucket by accident on the dehumidifier, and I have the same problem. Here what I found :
First, remove the water bucket and find the circuit diagram, it is very useful.
E1 code is related to the room humidity sensor, E2 code is related to the room temperature sensor and E3 code is related to the safety thermistor sensor. If you have one of these error code displayed, you will probably have to replace the sensor.
The humidity and temp sensors are located on the same board. To access it, remove the water bucket and you will see the 2 screws holding the front panel. Remove the screws, then gently prayed the front panel. Be careful, there is two plastic clip on the top of the panel and they are really easy to break. The board is located at the top right, under the cover. The safety thermistor is located on a pipe on the right side of the dehumidifier.
Aug 02, 2006 | Danby DDR583R Dehumidifier
Dehumidifiers Logo
184 people viewed this question
Top Haier Dehumidifiers Experts
Steve
Shawn DuRee
Michael Youngman
Michael Youngman
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
