Question about Samsung SyncMaster T240 Monitor
Hello, my screen turns on for 1 second and then turns really dark. the screen stays on but can hardly see anything. i have a syncmaster T240
    Guru:
  • 767 Answers
Samsung T240 Problem
try check the cables and connection
Dec 17, 2013 | Samsung SyncMaster T240 Monitor
Is there a new windows 7 driver for the Samsung Syncmaster T240 monitor? The problem I'm having is green flickering, where a green tint intermittantly comes over the monitor.
try reducing the refresh rate of the screen. I Hope the Driver for the moinotor is installed !!
But if it is intermittant..
Then Monitor may be going through normal ageing.
Rate this solution, Write a comment to keep in touch.
Sep 16, 2010 | Samsung SyncMaster T240 Monitor
My samsung t240 screen turns black after 2 secs to an almost black screen, could it be a problem with the fuse as the monitor still has power??? plz help
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 13, 2010 | Samsung SyncMaster T240 Monitor
I have a samsung syncmaster t240 monitor. Boots up normally but the desktop appears for a brief time (1 second) then goes black. I used the torch technique and saw the desktop icons. When I switch the...
I believe the power led button is still on while the screen goes black, if yes, it means the picture board of your monitor is bad that is why it appears for a second and goes black after that
Since the power led button is on, It means the picture board on your monitor is faulty that is why it appears for a second and goes black.
The best thing for you to do now is to take the monitor to a local repairer or any service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself in other to complicate issues.
Take care.
May 01, 2010 | Smart Modular SV3170A
I rebooted my PC and now screen is darker and my colors are off
Check the contrast (darkness/lightness) on your Samsung LCD. There's a menu button on the monitor, press that and select contrast setting from the Menu.
Apr 29, 2010 | Samsung SyncMaster 932B LCD Monitor
SyncMaster 940N - screen has gone dark when turned on and computer booted up. If I get close to the screen I can just about see something on the screen. I have brought up the service menu and all the...
Your problem is usually caused by a bad power supply. You should be able to do the repair yourself, if just requires replacing 6 capacitors on the power supply board. Here is a link to a repair guide that shows how to disassemble the monitor and repair the power supply board.
http://www.ccl-la.com/blog/index.php/repairing-a-samsung-940n-with-a-blinking-power-light/
And here is the a picture of the power supply board.
I hope this helps, if so please rate my solution.
BuddyMc
Apr 16, 2010 | Samsung SyncMaster 940N Flat panel Monitor
Monitor goes blank after 3 seconds -Samsung SyncMaster 920NW
Could be a power issue. If it doesn't show anything at all then that may be the case. It may also be the display itself. It would be a costly repair so you might be better off finding a new monitor.
Sep 16, 2009 | Samsung SyncMaster 920NW Monitor
Samsung syncmaster t240 with thin colored stripes on display
Once you have stripes or lines in the screen then the only solution is to get the screen replaced but that would cost just as much or even more then getting a whole new monitor.
Aug 14, 2009 | Samsung SyncMaster T240 Monitor
Dim screen
If its very dark and you can barely see anything its probably a bad back-light. I'd suggest to take it to your local Best Buy. And yes, they can look up PSP#'s with your credit card, but even easier by telephone number.
Jun 24, 2008 | Gateway SL1450-30165297 Notebook
Open Questions:
Samsung SyncMaster T240 Monitor Logo
369 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
