I have an Indigo Zodiac pool robot. The wires in the blue cable that connects the robot to the power box have come out. Can you please tell me how to rewire, Thanks
djnick989
  • 1067 Answers
SOURCE: Blue tint to picture
cheak projecter mode your in under hdmi mode blue cool settings on hi ? eash input setup is differt use warm colers not cool 1 2 3 so on u know what i mean sum sterio have hard time with hdmi out to dvi might wann use coumpuont out from reciver to 15 pin vga sum projecter in 720 p mode have gard time 1080i so on u relly need dvi out from setrio to dvi more less for monister cable best use compunt cable projecter only 16 millon colers anyays ok not 529 billon like samsung plmasa would be were u would wann use hdmi to get all those colers but coumpunt is more then worthy wiyth projecters output ok
Posted on Jan 23, 2008
  • 586 Answers
SOURCE: no picture but only sound
If you are expert and have experience then follow the instruction given below:
Check first Filament is lighten-up ? If yes then check ABL Voltages, if filament voltages not present check horizontal out put transistor. and check also safty resistances in surrounding area of H OUT Transistor.
And if you are not a tech person then i advise you to please contact any expert nearby, this problem bit technical.
Hope this will solve the problem.
Thanks for using fixya.
Posted on Jul 24, 2009
  • 10 Answers
SOURCE: Zodiac Baracuda Zippy Pool Cleaner hose tear
I haven't seen any bulletins on the Zippy hoses. You might adjust the flow to the cleaner. You can find the Manual for the zippy cleaner on this page beneith the diagram. It shows how the star control works. You can also contact the Mfg Technical Support at Phone: 800-822-7933 They might be able to warranty a hose or two for you.
Posted on Nov 05, 2009
  • 366 Answers
SOURCE: the zodiac works for seveal minutes, then the pool
sounds like you may have an air leak somewhere. If not from your zodiac hose, it may be in the plumbing itself. Check the threaded fitting on the suction side of the pump, check the pump lid o-ring, and depending on the pump, check the gasket between the hair/lint pot and the volute or seal plate (especially if it's a sta-rite).
Posted on Nov 22, 2009
  • 106 Answers
SOURCE: Zodiac Pacer pool cleaner not sucking water or moving
Remove diaphragm and check for rips or tears in plastic.
Posted on Jan 14, 2010
Jandy Zodiac FloPro 2HP connecting Red Wire to which screw L1 or L2?
follow the owners manual.
if you are hooking this pump up as 220v, you will have two hot wires. one goes to L1 and the other to L2. it matters not which is where as they are both supplying power. be sure to connect the internal ground wire AS WELL as the bonding wire to the outside lug
Apr 28, 2014 | Zodiac Jandy 2Hp Flopro Pool Pump For...
Does the Red wire connect to the L1 or L2 Screw
when hooking up a pump on 220v, there are two hot wires. it doesnt matter which hot wire goes where. both L1 and L2 are power terminals
My zodiac cleaner keeps climbing the wall and then sucks air
You need to adjust the suction down on the cleaner. This type of cleaner only needs about 10lbs of vacuum pressure
Apr 14, 2014 | Zodiac Pacer Pool Cleaner
Zodiac indigo
Zodiac builds dirt. Jandy used to be pretty good Polaris is hanging by a thread ( both acquired by Zodiac.) I\'m an 18 year veteran in the pool industry. Sorry for the bad luck.
Aug 07, 2013 | Pool & Spa
No power, dash or hazards hiace van
Hi indigo you can remove the blue anti corrosion spray by removing the terminal and scrubing it with a wire brush also the hiaces have a main fuse in what looks like a white box attached to the positive wire close the battery that has fuses that look like strips of metal that if they are broken the power is cut to the vehicle. It usually takes a short circuit to blow the fuse but i have seen a few blow out of the blue.
Good luck i hope this helps
Jun 15, 2017 | Cars & Trucks
We found out tpday that we have 19 leaks in our inground pool liner which is not quite 2 years old!! The only thing we've changes this year is we purchased a Barracuda Robotic pool cleaner. Have you ever...
It will have a strong suction to the pool floor and could grind bits of sand into the liner. You might want to try a Arneson Pool Vac.
Be sure they put cork feet on it though so it goes easy on the liner.
If and when you replace the liner be sure to put an under-liner down first. This will help with problems that run along these lines.
Sep 13, 2010 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Does not run. Turn on power supply, get red light indicating power. Robot does not respond. Unplug blue cable from power supply. Measure 30VAC across pins on power supply. Do not measure continuity in blue...
Hi
Most likely a loose wire is touching metal somewhere inside your unit. You may consider replacing the power unit because it might be cheaper then repairing it. Or have a technician to take a look to the internal wiring since it is a bit tricky.HOwever click on the link below to order a replacement:
http://www.dolphinpoolcleaner.org/replacement_parts.htm
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Jun 28, 2010 | Smartpool Dolphin Robo - Kleen Above...
May 31, 2009 | Zodiac Pacer Pool Cleaner
Electirity connected but will not start
I found a disconnected wire in the screw -on plug which connects the power cable to the battery. I am expecting a reply from Maytronics to tell me to which of the three remaining connection points to connect the black wire. The white is still attached to point number 1.
May 16, 2009 | Smart Pool Inc Dolphin Diagnostic...
Computers & Internet Logo
51 people viewed this question
David Payne
David Payne
