Question about Kenmore Dishwashers
Kenmore Elite 665.17053400. Powers up ok, fills up with water ok, but wash cycle won't start. I can hear the motor trying to turn but sounds like its seized up. If I cancel the wash, the machine drains out the water ok. Does this sound like the moter is shot and if so, what should I expect to pay to have it replaced?
  • Kenmore Master
  • 3,247 Answers
This dishwasher has a very sophisticated wash system. In order to improve the wash efficiency it uses a chopper and a soil sensor. It is very likely the chopper assembly is clogged which is blocking the water from circulation and straining the wash motor.
See this diagram. Item 6 is the chopper. Worst case is the pump motor needs replacement. This is item 10.
Good luck
Posted on May 27, 2011
Washing machine won't wash I.e. bowl won't turn in wash cycle or spin. Fills with water ok. Will drain if start button is reset. Rear panel removed, drive belt in tact.
pull shafe out it is likly broken to find out between timer and shaft look to see if timer move by itself and if it does sorry u have broken shaft
Feb 16, 2013 | Washing Machines
My kenmore elite calypso washer won't fill up enough to get clothes completely wet.
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Jan 17, 2013 | Kenmore Washing Machines
Water fills in, but wash cycle won't start. spin cycle works, changed motor still won't work
Its either in the lid switch or timer. Examine the lid switch. Try starting the wash cycle and press in on lid switch to make sure it activates. If the lid switch is good and you dont hear the motor trying to activate during wash than its in the timer. Does the timer advance? Please comment me back If you need further assistance.
Jul 28, 2011 | Maytag Atlantis MAV6000 Top Load Washer
My kenmore elite dishwasher 665.17053400 motor sounds like its seized. The machine fills and drains ok but won't do a wash cycle. Moter makes a buzzing noize.
This might help you - this type pump assembly doesn't seem to be a serviceable unit - just replaceable.
http://www.youtube.com/watch?v=vNQvDqzMZV4
May 27, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
Kenmore elite dishwasher, does not get the dishes wet
sounds like wash motor is not going . it will fill and control thinks motor is working . then it will drain wash water / ( drain pump is a different motor ) and then refill and so on .. never washes but fills and drains and heats. ( look for leakage under the motor i'm sure you will find some ..
Nov 22, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Clicking Sound / Kenmore Elite Catalyst
sounds like ur coupler is bad easy fix 4 dollar part
Dec 26, 2008 | Kenmore 22422 Top Load Washer
Kenmore Elite HE3 fills but won't spin
do you hear any sound while stops??
like ticking sounds?
Jul 15, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 22956 top loader quit running after agite cycle
If the timer cycles your lid switch is ok.
most likely: motor Switch (on Motor), condenser next to motor, motor itself, or wiring going from the time to the switch,
It is probably cost efficient to replace the unit rather than trowing parts at it .
AB
Apr 06, 2008 | Kenmore 24032\24036 Top Load Washer
Dishwashers Logo
405 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
