Question about Carrier 38CKC036 Air Conditioner
How do I recharge the freon in my unit? model is 38CKB060300
    Genius:
  • Carrier Master
  • 1,033 Answers
Hello, freon should be charged by a hvac technician with a epa card. But the way you charge it in is hook up the manifold gauges to the unit tjen take the yellow and hook it up to your refrigerant bottle. If this is a R-22 unit then you add vapor refrigerant to the low side of the system untill your superheat is correct if it is a fixed orifice system, however if it is a txv system then you chek the subooling. If it is a 410a system then the same principle applies however you flip the cylinder upside down and add liquid refrigerant through the low side a little at a time here is a link that shows you proper charging methods http://www.air-conditioning-and-refrigeration-guide.com/charging-air-conditioning-systems.html.
Posted on May 27, 2011
Where in Southern California can I get it recharged with freon?
Generally portable a/c units are not recharged because they do not contain a service port like a home or auto a/c unit does. At the factory they charge the unit crimp the tube then weld it closed. And no one can service freon unless then can vacuum recover it.
Aug 05, 2015 | Amcor NanoMax 12,000 BTU NanoMist Portable...
How do i recharge freon for me Friedrich KM18J30A-3 window unit?
only a certified HVAC technician has the license to carry and use the freon used in home A/C units. it's not like the car units we can do ourselves.
Jul 14, 2012 | Friedrich QuietMaster KM18L30 Wall/Window...
Duro therm , penguin 2 1988 model
ADDING FREON IS A LITTLE MORE COMPLEX AND BEST LEFT TO A PRO, YOU CAN MAKE SURE THE FAN IS OILED AND THAT THE FINS ARE CLEAN, TAKE NOTE IF YOU SEE A OILY SPOT ON THE UNIT THIS MAY BE THE SIGN OF A FREON LEAK ,, IT MIGHT BE WELDED AND RECHARGED .. THATS MORE BETTER THAN BUYING A NEW UNIT CUZ THESE AINT CHEAP ! JAY THE POOL PUMP GUY IN LONGWOOD FL
Feb 02, 2012 | Dometic Rooftop RV Air Conditioner
I have a Fredders A3X05F2A-J model and was wondering how to recharge the unit, if possible? If so where could i pick up a recharge kit?
I don't beleive there is a DIY kit for recharging window air conditioners. At least not one, that would be reasonably affordable (less than $100.00) . Now, if you have a friend who's in the auto repair business and as part of his work, he recharges automobile AC compressors, he may can help you. As he would have the knowledge to balance the high and low sides of the compressor. As well as evacuate and capture any freon that's left in the system. As freon has be banded by the EPA. R134a is now the refrigerant used in AC compressors. By now, I guess you figured out, that recharging the system is not necessarily a DIY project. It's best left to the pros.
Hope this was of hep to you and thanks for choosing fixture.
Jul 24, 2011 | Fedders A3X05F2A Air Conditioner
I have a minisplit unit that leaks out the freon
try leak stop that they sell for refrigeration and air conditioning systems
Dec 12, 2009 | Heating & Cooling
How do i add freon to fedders model # A6X05F2B
you dont!!! Only an EPA certified technician can do this. Besides that this is window unit and therefore it is a sealed unit not meant to be recharged. Some newer models allow for this but not this Federers. It probably just needs a good coil cleaning is all, if its losing refrigerant than it has major problems not worth fixing---buy a new one thats more efficient---the energy savings will pay for the unit.
Jun 15, 2009 | Fedders AEQ07FBG Air Conditioner
Recharge freon ge heat & ac unit
Jump out the control, make the machine run constantly and recharge it.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 21, 2009 | GE Heating & Cooling
Need to know what type of freon to use to recharge a one yaer old Beverage Air Sandwich table refrigeration unit. Is this the same process as recharging an automotive AC system?
Beverage air used R134a almost exclusively on refrigerators. The process is similiar to ac systems. You should weigh the charge in as per the data plate. Be precise as over or under charge can dramitically affect the performance of the unit. Hope this helps
Mar 29, 2009 | Beverage-Air 44.9 cu. ft. / 1271 liter...
Beverage air dd78e not cooling
change setting on thermostat and see if anything changes. If yes, that's the prob if no, freon level. start there.
Dec 14, 2008 | Beverage-Air Beverage Air 2- Tap Unit...
Carrier 38CKC036 Air Conditioner Logo
376 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
