Question about Kenneth Cole KC1104 Wrist Watch
Kc1395 A128-05 2 screws for watch band or neww watch band (brn)
Missing screw to hold band together need replacement
Most jewelry stores--or even jewelry counters in department and discount stores like Walmart--keep a supply of replacement screws for when one is lost while changing a watch band. Ask around, show them your watch, and you may even get the right screw for free!
May 06, 2011 | Field and Stream F187GWBS e by Field &...
How can I shorten the watch band. I've tried pushing the pins, but they don;t seem to move. What is the significance of the arrows on the back of the band segments? Thank you for your help!
The arrows show you the direction to push out the pins.
  • Look for an arrow on the inside of your watch band. The direction the arrow is pointing is the direction the pin should slide out of the band. If your pin is screwed in, you may not see an arrow on the inside of your band.
  • 2 Look on the edge of the watch band for a small round object, the pin. If the pin head is flat, then it needs to be pushed out. If the pin head has a screw driver groove, then it needs to be screwed out. Depending on the type of watch pin you have, take a sharp pointed tool or a tiny screw driver from a hobby kit or watch tool kit and place it on the head of the pin. You should be looking at the end of the pin on the opposite side from where the arrow is pointing.
  • 3 Push on the sharp tool to push the pin out of the watch band. You will need to use force to push the pin out. If your pin is screwed in, gently unscrew the pin until it becomes loose. Remove the pin with your fingertips. Make sure to put the pin in a safe place, because you will need it again when resizing the watch band.
  • Aug 18, 2010 | Kenneth Cole 1213 Wrist Watch
    Looking for a band screw for 38mm cartier pasha
    mcdevito75 here, BEST BET, look for a small watch repair shop in your area for this screw, anyone would have to have the watch with them for the proper screw, and you may have to have this screw ordered from Cartier.
    Jul 12, 2010 | Cartier Pasha W3103755 Wristwatch
    How do you adjust the band on a rolex watch
    Unscrew bracelet screws from the side and take out/add link. Then screw bracelet screws back.
    Jan 29, 2010 | Rolex Day-Date President 118239 Wristwatch
    Band replacement
    Skagen watches have a fairly unique band. If you have a leather band you can find a replacement from most after market band suppliers like Speidel. For the mesh steel the only after market I know of is from Bariloche. Bariloche. I am still not aware of any titanium mesh suppliers but you can always contact Skagen for replacement bands. They are very good at keeping replacement parts for their watches for several years.
    http://www.skagen.com/service/orderWatchBandParts.fx
    Once you have the band you will need to use a small screw driver to depress and release the spring bar that secures the band to the watch. Place a screw driver in between the ridge of the spring bar and the lug of the watch case and gently move inwards. Remember that the end of the spring bar is spring loaded so it may fly out if you move the end away from the watch.
    Thanks!
    Sep 19, 2009 | Skagen Watches
    10L02 Wittnauer watch~need band screws that connect link to link
    If you can get to a watchmaker or even one of those watck "kiosks" where they mostly replace batteries or even a jeweller they may have what you need.
    Jul 18, 2009 | Watches
    Lost screw to secure watch band on Skagen 355LGSC
    You just have to to see the watchmaker. As all watch band screws are made to particular bracelet, it's allmost impossible to find the right one if you are not in watch repair business. It will not cost too much and will save your time and nerves if you'll ask the watchmaker.
    Find your nearest watchmaker and ask for help.
    Dec 22, 2008 | Skagen 355LGSC Wrist Watch
    Beverly HIlls Polo watch needs band adjustment
    All you prepare a piece of jewelry screw.There will be very tiny screw in the side of the band you better screw it carefully and when the screw is out detach it,and size it that's you like size comes out.That all if want to resize desame what did in the other side. Always do it slowly so there no scratch or visual impaired damaged.
    Jun 16, 2008 | Beverly Hills Polo Club 22-710TTS
    Lost screw
    go to any jewelery store cheers
    Jan 18, 2008 | Watches
    Kenneth Cole KC1104 Wrist Watch Logo
    59 people viewed this question
    Top Kenneth Cole Watches Experts
    Jimmy Accardi
    Gary Nitowski
    Are you a Kenneth Cole Watch Expert? Answer questions, earn points and help others
