When park brake is on engine runs good when you take it off it seems like theres a load on engine. and buzzer beeps 3 times.and the hydraulic temp and low fluid light will flash once. there is lots of fluid just does not work right.when it warms up it willnot move and the buzzer stays on at a high rpm.idle it down buzzer stops then it will move at an low idle.
    Problem Solver:
  • 15 Answers
Just trace the brake cable just to make sure that it is not tangled with the speed cable that conects to the gear box if your car is automatic ,,nuts 4 cable could be loose,,also check the filter for hydraulic pump,,it might be dirty,,,clean it up or replace it,,take care
Posted on May 27, 2011
Changing pump and bleeding power stearing on a 1983 buick riviera
1. Replace any hydraulic line showing external damage. Rubber hoses more than 4 years old should be replaced. Install new seals for all disconnected fittings (as required) and install an in-line power steering filter. Tighten all hose fittings to OE specifications. 2. Flush the entire power steering system using the vehicle manufacturers recommended fluid. Fill pump reservoir to the proper level.
3. Disable engine to allow cranking without starting. This can be done by unplugging the main power wire (large red one) from your Delco HEI Distributor unit. Block wheels, put transmission in neutral or park and set parking brake, then crank engine 5 to 10 seconds (avoid overheating starter motor).
4. Refill pump reservoir as necessary. Repeat step 3 until level is correct.
5. Enable the engine to allow starting. Start engine and let idle. Slowly turn steering wheel from lock to lock a number of times.
6. Turn engine off and inspect fluid level and condition. Add or remove fluid as necessary. If fluid is foaming, wait one hour then recheck level. Repeat step 5 and 6 until fluid level is correct and shows no sign of air. If the problem persists recheck installation and connections.
1. With engine off, apply and release brake pedal 5 to 10 applications to deplete accumulator reserve pressure. With foot slightly pressing brake pedal, start engine. Pedal should drop and then push back against your foot.
2. With engine running, turn steering wheel until lightly against steering stop. After 5 seconds return wheels to the straight ahead position and turn engine off. Apply and release brake pedal. There should be at least one power assisted brake application. Start engine and allow accumulator to recharge before moving vehicle. 3. Test drive vehicle.
NEVER operate any vehicle until brake and booster systems are functioning properly. Remember, your vehicle is only as good as it's braking system. Brakes are the singlemost important component on any motorized vehicle.
Nov 06, 2016 | Buick Cars & Trucks
How do i fix a brake buzzer that goes off while driving a nissan ud 80 truck,seems like the air pump cannot keep up
if it has a belt driven air compressor check belt and tension
it could be a buzzer problem
it could be an air leak in the system ( possible in the park brake diaphragms )
install an air gauge in the drain plug of a tank and monitor the air pressure use
with the truck being driven normally then the tank pressure should not show much variation
test the brake system by tuning the engine off, hold and apply the foot brake and see if the pressure continues to diminish indicating a leak in the system or foot valve operation
finally take it back to nissan ud as it will be still under warranty
Aug 24, 2016 | 2012 Nissan NV
Husqvarna 4623 zero turn mower will not move
Maintanance - How to purge Hydraulic drive system Published 01/13/2010 11:56 AM ' Updated 06/02/2015 02:52 PM
How do I purge the hydraulic system?
Hydrostatic transmissions use oil, under pressure, to provide movement for the tractor. The fluid is pressurized with a pump inside the transmission. If any air is in the fluid, the pump will try to pressurize air. This condition is known as cavitation, and is detrimental to the pump since it allows the pump top operate dry. When the pump cavitates it is not pressurizing any fluid, so the transmission is not able to provide the movement needed.
If your mower is new, or has been stored for a long period (longer than 2 months) the transmission needs to be purged before use. Also, if you experience loss of drive, or slower response, then the transmission should be purged first.
The following procedure will remove trapped air inside the transmission(s).
IMPORTANT: SHOULD YOUR TRANSMISSION REQUIRE REMOVAL FOR SERVICE OR REPLACEMENT, IT SHOULD BE PURGED AFTER REINSTALLATION BEFORE OPERATING THE TRACTOR.
Step 1- Place the rear of the mower safely onto jackstands on a level surface with engine off and parking brake set.
Step 2- Disengage transmission by placing freewheel control, located at the back of the frame, in the freewheeling position.
2a- Mowers with seperate pumps and wheel motors the freewheel is activated by turnign the bypass valves, one on each pump, two full turns.
The oil resevoir needs to be filled to the specifications listed in the owners manual before starting the purge procedure.
Step 3- Sitting in the operators seat(riders), start engine. After the engine is running, move throttle control to slow position. With motion control levers in neutral (N) position, slowly disengage clutch/brake pedal.
Step 4-Move motion control levers to full forward position and hold for five (5) seconds. Move levers to full reverse position and hold for five (5) seconds. Repeat this procedure three (3) times.
NOTE: During this procedure there may be some movement of the drive wheels, but they are not under load. The air is being removed from hydraulic drive system.
Step 5-Move motion control levers to neutral (N) position. Shutoff engine and set parking brake. Check and add oil as needed for units with an oil resevoir.
Step 6-Engage transmission by placing freewheel control into driving position, or by closing the bypass valves on the pumps.
Step 7-Sitting in the operators seat, start engine. After the engine is running, move throttle control to full speed. With motion control levers in neutral (N) position, slowly disengage clutch/brake pedal.
Step 8-Slowly move motion control levers forward, after the tractor moves approximately five (5) feet, slowly move motion control levers to reverse position.
After the mower moves approximately five (5) feet return the motion control levers to the neutral (N) position. Repeat this procedure with the motion control levers three (3) times.
Step 9-Your mower is now purged and now ready for normal operation.For further information or assistance, we recommend contacting your lo
Aug 06, 2016 | Husqvarna Garden
93 ford F800 park brake will not hold
The first thing to check is the amount of linings on the shoes . If less than 50 % replace the linings/ shoes. Next check the adjustment is right up . Park brake operation should never rely on hydraulics for the simple reason that hydraulics leak and the brakes come off. It will probably be spring loaded with the electric over hydraulics holding the brakes off when moving
Feb 19, 2014 | Cars & Trucks
Symptoms 2000 kia sportage Symptoms 2000 kia sportage does not do all the time. Starts runs well but driving road 50mph almost as if ignition shut off split 2nd. Stop car and while running in drive s
Some makers used Vacuum releases for their emergency brakes which had a Vacuum switch connected to the shift assembly. This would account for a stumble if Vacuum vented out through this switch.
More common for shifting stumble to occur from Park to Drive, engaging a load on the engine, not to stumble to a freewheeling Park position. Sounds like idle speed control is sluggish to stabilize the motor.
You also have idle speed control problem with A/C, kind of shows that A/C was what kept the engine running because when you turned the A/C off, the car died.
I am going to give you some Websites for wiring diagrams. Alldatadiy.com amd Autozone.com with free wiring info upon registering your vehicle.
It seems that the base Idle speed control is not working and the A/C idle speed control is.
Also check for Vacuum leaks on the intake manifold by spraying water from a pumpbottle on the seams of the gaskets.
Check ignition Relay or ignition switch for random cutouts. The fusebox layout is on the Autozone site.
I hope my solution helps.
Sep 09, 2012 | 2000 Kia Sportage
My 02 Camry v6' battery was removed for 30 min and put back on - good battery. Engine starts no problem but stalls at idle. No error code. Is a computer-code reload or IAC cleaning ? Seems the car computer...
idle learn procedure:
turn off all electrical items (AC fan, audio, lights, defogger, etc.)
Start the engine and hold it at 3,000 rpm with no load (in park or Neutral) until the radiator fan comes on or the engine coolant gauge shows normal running temp.
Now let the engine idle for a minimum of 5 mins with no electrical loads. If the radiator fan cycles on during this time, you must add the fan running time to the 5 mins.
Feb 10, 2011 | 2000 Toyota Camry Solara
How do I disable brake warning light and buzzer on 93 LaSabre?
have you checked the brake fluid level? what is the label for fuse #6???
Sep 27, 2009 | Buick Century Cars & Trucks
Ultra m923 mid-tower case won't stop beeping
The problem is the board on the case's display. It has temp alarms for your components(video card, hdd, cpu), there are temp probes for you to set so you can monitor these temps. However the board that controls these functions, or at least mine and many others I have read about, is defective. It will change display constantly and sometimes have garbage display. It is setting its own limits for what is considered a hi temperature. The limit it has set for one of your components is < room temperature so it thinks you are having an overheating problem. You can manually set the limit for overheat and it will fix it for a while, but it will prob happen again.
Jul 03, 2009 | Ultra Products Ultra M923 Full Tower ATX...
Engine runs but cuts off when its put into gear.
I helped another 3 series owner and he had a hesitation off idle, the hose was cracked, seems fairly common on high mile cars.
Apr 17, 2009 | 1988 BMW 3 Series
Park brake
Pull up on your parking brake pedal and make sure it is fully up, If it isn't it should turn off the light and buzzer, if it doesn't there is a switch located on the mechanism it operates that is bad are needs adjusting. I hope this helps you!
Dec 26, 2008 | 1997 Buick LeSabre
Computers & Internet Logo
67 people viewed this question
David Payne
David Payne
