I have my d link router and i think that someone can access on my password and i want to change it what will i do
  • 56 Answers
Changing your wifi password is a process that is both simple and complex to explain.So the best thing to do is to look up how to do this. There are a large number of really good and well written that would help you out a lot faster and better than I could explain it. I have included a link to one to assist you further
Best of luck
http://www.ehow.com/how_4927667_change-wireless-settings-dlink-router.html
Posted on May 27, 2011
Wireless password
The wireless password for a router is established by the administrator of the router. This is whom you should ask for the password. Hacking into the router wont help you find it because the password is not displayed...it is a series of dots. You CAN, if you access the router setup, CHANGE the wireless password to something you can use - but if you are hoping to piggyback or hack onto someones service using their wireless password, you're out of luck.
Aug 10, 2014 | D-Link Computers & Internet
Need password on wireless guest account
The possibilities are -some one might have changed it for you. If someone got your password or hacked it then they could get on your network and change the password on the wireless router. Or did the router get reset without your knowledge(has the non-guest access changed)? If you left the default log in to the router you might want to change it also, it makes it harder even if someone gets wifi access.
Mar 31, 2014 | Computers & Internet
How to change wifi password on Buffallo AirStation WBR2-G54 router
I'm not 100% sure, but I think the password is actually programmed into the bios of the router, so you can't change it...could be wrong. If someone is using your router, they must be aware of your password, remove the password sticker off your router and keep it in a safe place
Nov 24, 2013 | Computers & Internet
Many people hacked my password so i want to deactive this id instantaly plz disable my account immediately
Try accessing the router's management console to change the password. If someone else changed it or you have no access to the router, press and hold down the reset button behind the router to reset the router. After you have reset the router, immediately change the password to prevent others from using it.
Mar 08, 2011 | Computers & Internet
Someone is acsessin my router and useing my internet without my permission i need to change the password but i cant
Reset both password (1) pasword for access router via GUI (2)Wi fi security password WEP or WPA or WAP
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Then click on administration and change password .
Then Click on wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
Apr 17, 2010 | Belkin Computers & Internet
How do I find the access code so someone else can log on and use my wireless internet connection?
Contact you ISP...they will give you either you IP address to log on to access the network settings or they will just give you the password over the phone.
Mar 26, 2010 | Zyxel (91-004-361002) Wireless Router
Not a problem with router but I need to put a security password in place as I think someone else is using my router.
Go to your IP for that router and put it in Internet explorer.
Most IP's are 192.168.1.1
It may let you set a password up, some do not.
Oct 18, 2009 | NetGear DG834G Router
I need to change my security password to my router. someone changed it so its not working
ok
access your router with following link
http://192.168.2.1
then type user name as "admin" and password as "admin" or "password" or blank
then go to wi fi security then go to encryption key and change it if you want to change then save setttings and check.
Jul 10, 2009 | Belkin (F5D7230-4) Router (587009)
I need help changing the MTU settings on a D-link DI-624 router.
you have to enable wi fi in your router for that you need to access it.
Coonect your router to 1 computer with ethernet cable then access following link
http://192.168.0.1
or
http://192.168.1.1
then type username as "admin" and password as "admin" or blank or "password"
Then go to wirelesss and enable wi fi .
Jun 17, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
How to install a password in a DWL-2100AP
The usual setup IP address for DLink wireless routers is
192.168.0.1
and the user login = admin and no password is required.
If you have not changed the password and the default SSID then it is recommended that you set a password and change the SSID so that it will help prevent someone hacking into your DLink wireles router and changing your setings to their advantage..
Feb 19, 2009 | D-Link AirPlus Xtreme G DWL-2000AP...
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
