Question about Acer Aspire 4720 Notebook
Switching off automatically - Acer Aspire 4720 Notebook
  • 56 Answers
Chances are that its overheating and turning itself off in order to save itself from CERTAIN DEATH!! Dun dun dunnnnnn!!
But seriously that is most likely the case. First thing to check is if the fans are working in it. If not make sure they are not clogged with dust, pet hair, or something of the same nature (Dental floss?) If you have no clogs and the fans are working then the heat sink on the CPU may have became dislodged (I worked at a PC repair shop and had this happen before) and the only way to check that is to take the laptop apart. If you are uncomfortable doing that then the best thing to do is take it to a local shop.
Best of luck
Posted on May 27, 2011
My 2003 Oldsmobile altero gets stuck and i have to jiggle the shifter or leave it set for a min befor if will go from park to reverse ect.. Just got the car yesterday
Your problem is more then likely with the Automatic Transmission Shift Lock Control .This is a safety thing . Has a switch , wiring and a electrical solenoid .
Automatic Transmission Shift Lock Control System
The automatic transmission shift lock control is a safety device that prevents an inadvertent shift out of PARK when the ignition is ON. The driver must press the brake pedal before moving the shift lever out of the PARK position. The system consists of the following components:
• The automatic transmission shift lock control solenoid
• The automatic transmission shift lock control switch
• The park/neutral position switch
Sorry to here your having a problem with it already .
There are diagnostic step to find the problem , involves using a DVOM - digital volt ohm meter an using a wiring diagram to locate test points in the circuit . Plus you will need to take parts of your vehicle apart to get to those test points . The most likely part to fail is the park neutral safety switch . The contacts wear inside after hundreds of times of moving the shifter . But without testing this is just a guess .
With the ignition in the ON position, battery positive voltage is supplied to the park/neutral position switch. With the transmission in the PARK position, the contacts in the park/neutral position switch are closed. This allows current to flow through the switch to the automatic transmission shift lock control switch. The circuit continues through the normally-closed switch to the automatic transmission shift lock control solenoid. The automatic transmission shift lock control solenoid is permanently grounded. This energizes the automatic transmission shift lock control solenoid, mechanically locking the shift linkage in the PARK position. When the driver presses the brake pedal the contacts in the automatic transmission shift lock control switch open, de-energizing the automatic transmission shift lock control solenoid. This allows the shift lever to move from the PARK position.
Apr 25, 2017 | Oldsmobile Cars & Trucks
05 Trailblazer transmission says neutral but gear shiftier is locked in park.
The automatic transmission shift lock control system is a safety device that prevents an inadvertent shift out of PARK when the engine is running. The driver must press the brake pedal before moving the shift lever out of the PARK position. The system consists of the following components:
With the ignition in the ON position, voltage is supplied to automatic transmission shift lock control switch. Voltage flows through the normally closed contacts of the automatic transmission shift lock control switch to the automatic transmission shift lock control solenoid. The automatic transmission shift lock control solenoid is permanently grounded. This energizes the automatic transmission shift lock control solenoid causing the transmission shift lever to be physically locked in the PARK position. When the brake pedal is pressed the contacts in the automatic transmission shift lock control switch open, de-energizing the automatic transmission shift lock control solenoid. This allows the shift lever to be move out of the PARK position.
Circuit Description
The transmission range (TR) switch is part of the park/neutral position (PNP) and back-up lamp switch assembly, which is externally mounted on the transmission manual shaft. The TR switch contains four internal switches that indicate the transmission gear range selector lever position. The powertrain control module (PCM) supplies ignition voltage to each switch circuit. As the gear range selector lever is moved, the state of each switch may change, causing the circuit to open or close. An open circuit or switch indicates a high voltage signal. A closed circuit or switch indicates a low voltage signal. The PCM detects the selected gear range by deciphering the combination of the voltage signals. The PCM compares the actual voltage combination of the switch signals to a TR switch combination chart stored in memory.
These are all electronically controlled , yur best bet would be to take your vehicle to the dealer .
Apr 19, 2017 | 2005 Chevrolet TrailBlazer
2000 regal won't go out of park
I would think it has something to do with
The automatic transmission shift lock control system is a safety device that prevents an inadvertent shift out of PARK when the engine is running. The driver must press the brake pedal before moving the shift lever out of the PARK position. The system consist of the following components:
• The automatic transmission shift lock control solenoid.
• The automatic transmission park lock solenoid (Regal only).
• The automatic transmission shift lock control switch.
• The transmission range switch.
Regal
With the ignition in the ON position, battery positive voltage is supplied to the automatic transmission shift lock control switch. The circuit continues through the normally-closed switch to the automatic transmission shift lock control and park lock solenoids. The transmission range switch provides a path to ground in the PARK position. With the automatic transmission shift lock control and park lock solenoids energized the shift lever is locked in the PARK position. When the driver presses the brake pedal, the contacts in the automatic transmission shift lock control switch open. This causes the automatic transmission shift lock control and park lock solenoids to release. This allows the shift lever to move from the PARK position.
Do the brake lights work ? If not could be cause by bad brake light switch .
Nov 28, 2016 | 2000 Buick Regal
Shifter is locked in park on a 2002 bravada that sayes on dash its in reverse
PRND321 Display
The instrument panel cluster (IPC) displays the selected gear position as determined by the engine control module (ECM). The IPC - instrument panel cluster receives a serial data message from the ECM indicating the gear position. The PRND321 display blanks if:
The ECM detects a malfunction in the transmission range switch circuit.
The IPC detects a loss of serial data communications with the ECM. The automatic transmission shift lock control system is a safety device that prevents an inadvertent shift out of PARK when the engine is running. The driver must press the brake pedal before moving the shift lever out of the PARK position. The system consists of the following components:
The transmission range (TR) switch is part of the park/neutral position (PNP) and backup lamp switch assembly, which is externally mounted on the transmission manual shaft. The TR switch contains four internal switches that indicate the transmission gear range selector lever position. The PCM supplies ignition voltage to each switch circuit. As the gear range selector lever is moved, the state of each switch may change, causing the circuit to open or close. An open circuit or switch indicates a high voltage signal. A closed circuit or switch indicates a low voltage signal. The PCM detects the selected gear range by deciphering the combination of the voltage signals. The PCM compares the actual voltage combination of the switch signals to a TR switch combination chart stored in memory.
You need a Tech2 scan tool to diagnose this problem ! possible range sensor !
Sep 03, 2015 | Cars & Trucks
Abs light on wont shift out of park
Hi Judy , what kind of vehicle do you have ? Year an model ? ABS light has nothing to do with it not coming out of park . Problem with automatic transmission shift lock control ! Probably !
The park/neutral safety switch.
With the ignition in the ON position, battery positive voltage is supplied to the automatic transmission shift lock control switch. The circuit continues through the normally-closed switch to the automatic transmission shift lock control solenoid. The park/neutral safety switch provides a path to ground for the automatic transmission shift lock control solenoid in the PARK position. This energizes the automatic transmission shift lock control solenoid, mechanically locking the shift linkage in the PARK position. When the driver presses the brake pedal the contacts in the automatic transmission shift lock control switch open, causing the automatic transmission shift lock control solenoid to de-energize. This allows the shift lever to move from the PARK position. When the shift lever is out of the PARK position the contacts in the neutral safety switch open and the automatic transmission shift lock control solenoid is de-energized.
Jul 07, 2015 | Cars & Trucks
2001 Pontiac Bonneville won't shift out of park
The automatic transmission shift lock control system is a safety device that prevents an inadvertent shift out of PARK when the ignition is ON. The driver must press the brake pedal before moving the shift lever out of the PARK position. The system consists of the following components:
The brake to shift relay
The rear integration module (RIM)
With the ignition in the ON position, battery positive voltage is supplied to the brake to shift relay coil. When the RIM energizes the brake to shift relay, the brake to shift relay switch contacts close suppling battery voltage to the automatic transmission shift lock control switch. The circuit continues through the normally --closed switch to the automatic transmission shift lock control solenoid. The permanently grounded solenoid is energized. This locks the shift linkage in the PARK position. When the driver presses the brake pedal, the contacts in the automatic transmission shift lock control switch open. This causes the automatic transmission shift lock control solenoid to release. This allows the shift lever to move from the PARK position.
Shift Lever Does Not Move with Brake Pedal Depressed ?
Jun 30, 2015 | Pontiac Cars & Trucks
Where is automatic light switch on my 2004 buick rainer cxl model suv
There is no switch, they are automatic. There is a sensor mounted on the top of dashboard that senses light, which tells headlights to turn on.
May 24, 2014 | 2004 Buick Rainier
Why won't 2003 pontiac grand prix. shifter come out of park?
Shift - interlock system problem .
The automatic transmission shift lock control system is a safety device that prevents an inadvertent shift out of PARK when the engine is running. The driver must press the brake pedal before moving the shift lever out of PARK position. The system consists of the following components:
With the ignition in the ON position, battery voltage is supplied to the automatic transmission shift lock control switch. The circuit continues through the normally-closed switch to the automatic transmission shift lock control solenoid. The transmission range switch provides a path to ground for the automatic transmission shift lock control solenoid in the PARK position. With the automatic transmission shift lock control solenoid energized the shift lever is mechanically locked in the PARK position. When the driver presses the brake pedal, the contacts in the automatic transmission shift lock control switch open, de-energizing the automatic transmission shift lock control solenoid. This allows the shift lever to move from the PARK position. When the shift lever is out of the PARK position the controlled ground contacts in the transmission range switch open. This prevents the automatic transmission shift lock solenoid from energizing when the vehicle is out of the PARK position.
Jul 04, 2017 | Pontiac Grand Prix Cars & Trucks
P1646 how much to repair
P1512 Throttle Position Sensor Idle Switch Sense Circuit
P1513 Throttle Position Sensor Idle Switch Sense Circuit
P1514 Park/Neutral Position Switch High Load Neutral/Drive
P1516 Gear Change Park/Neutral Malfunction
P1517 Engine Cranking Park/Neutral Malfunction
P1607 MIL Output Circuit
P1608 Automatic Transmission
P1609 Internal ECM Error
P1641 Fuel Pump Relay No. 1
P1646 Fuel Pump Relay No. 2
P1739 Automatic Transmission
P1775 Transmission Control Module MIL Circuit
P1776 Torque Reduction Request Signal
P1777 Torque Reduction Circuit
P1780 Automatic Transmission
P1781 Automatic Transmission
P1782 Automatic Transmission
P1783 Automatic Transmission
P1785 Automatic Transmission
P1790 Automatic Transmission
P1791 Automatic Transmission
P1792 Automatic Transmission
P1794 Automatic Transmission
P1796 Automatic Transmission
as you can no such code exists for a jaguar ,contact code reader manufacturer
Jan 03, 2011 | 2004 Jaguar S Type
Automatic switch off my sigmatel s3 mobile
automatic switch off mobile & it lost its phone data(my msg.)date and time
;my mobile setting will change
please send us solution for this
my email id chetanthorbole16@yahoo.co.in .
Thanks
chetan
Sep 30, 2008 | Handmark Software MobileLists (950142) for...
Acer Aspire 4720 Notebook Logo
18 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
