Question about Cell Phones
On my Avaya 9040 transtalk cordless phone, when I try to register the phone to our system, it says Failed No DRM found. How do I fix this problem?
5 Suggested Answers
  • 1214 Answers
SOURCE: Phone won't register
Try this,
remove the battery from each of the handsets that will not register for about 30 seconds. Reinstall, and try to register the handsets.
I had the same problem, and this is how I got it to register.
Reply back if this worked.
Posted on Jan 23, 2009
SOURCE: Worth repairing Avaya 9031 transtalk (3 of them)?
Drew Telecom Group
891 Wakefield Street
Plainwell, MI 49080
269-685-5400
We use them for all of our Transtalk repair. They usually have a 2-3 day turn around.
Posted on Dec 30, 2009
KingDWS
  • 1606 Answers
SOURCE: I have a new Uniden cordless phone. The handsets
You can downlaod the manual from uniden in pdf form.
http://www.uniden.com/products/productdetail.cfm?product=DECT1580-4
the -4 or -5 refers to how many handsets you set. The 1580 is the actual model number.
To register I think all you do is place them on the master pad once then on their own charger stations. On some models they come all done so you just plug them in charge them up and use them.
Posted on Mar 23, 2010
SOURCE: I have a SKPE Phillips
Firstly, unplug the base unit, then remove from this base unit the ethernet cable and most importantly, unplug the telephone line! Then remove the batteries from the 2nd handset. Keep everything unplugged for a few minutes, then plug the power into the base unit, wait 1 minute, then plug in the Ethernet cable and wait 5 more minutes. Do NOT plug in the telephone line just yet. After the 5 minute wait, put the batteries back into the 2nd handset and then follow the registration instructions from the manual (copied below)...
Make sure you have configured the language, country code, and area code of your
phone before registering additional handsets.
1. Press "Reg.". Register shall be highlighted.
2. Enter the system PIN (Default: 0000). Use "Clear" to correct typing errors.
3. Press "Enter" to confirm.
• Your handset starts searching for the base.
4. Press the top button on the base unit until the two indications turn off.
• If registration is unsuccessful, the signal icon displays steadily.
TIP: IF REGISTRATION FAILED, REPEAT THE ABOVE PROCEDURE.
Like other methods, you must hold down the button on the base unit until the lights STOP blinking. When you have successfully registered your 2nd handset, then plug in the telephone line into the base station. I did the above and it worked! The trick is to be patient and wait the few minutes while everything resets itself.
Posted on Aug 05, 2010
We now have a avaya 3810 wireless phone. i cant seem to get it into operation. when i press talk button it says aquiring link then turns off. the manual is not very helpful in the setup process.
Plug the antennae in. With it plugged in, stand next to it and turn teh cordless on. If it never "aquires link" then there is a problem with it, send it in for repair.
Feb 02, 2011 | Avaya Merlin Magix Handset 3810 TransTalk...
Won't link with base New old stock unit flashes "Acquiring Link" message and nothing else.
It will need to be repaired. You willl have to send it in. I can recommend someone if you need.
Feb 19, 2010 | Avaya Partner 3910 TransTalk Cordless...
Ayaya Lucent Partner 18D Cordless call waiting.
The cordless will not work that way. If you hit flash, that will put calls on hold, etc....
The only thing you can do is have the flash button on the 18D itself.
Aug 28, 2009 | Avaya Lucent Partner 616 Phone
Our avaya 9040 was shutting off when you removed it from the charger so someone told us it was the battery, we purchased a new one and now it wont even turn on?
You need to contact your Avaya Business Partner to verify whats wrong with this phone. Chances are you bought a Gray Market equipment. So find your local guy on www.avaya.com
Cheers
Jun 25, 2009 | Avaya Partner Transtalk 9040 cordless...
I want to change my phone frequency
It sounds like your phones have registered with each others. Normally these phones are supposed to be digitally encoded. Try de-registering the phones and then register them again with the base. Hopefully this will fix your problem.
If they're analogue phones you can try scroll through the menu settings to change channels.
Apr 16, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
Uniden 2.4 GHz cordless phone won't register to base
Same happened to me. Unplug the base from power and the phone line for 30 minutes. Same for the handsets - all. Take out the batteries. Retry. After it says 'registration failed'. Leave it in the cradle. Several minutes later it found itself.
Mar 10, 2009 | Uniden 2.4 GHz Cordless Phone System
I have a Avaya 4690 ip phone. when I reseat the ethernet cables for the phone after initializing it comes up with "registration error". How do I fix that?
That phone is registerring with a server. There is nothing you will be able to do. You need to contact your system administrator
Jan 09, 2009 | Avaya IP Office 4690 Speakerphone...
Drew Telecom Group
Plainwell, MI 49080
269-685-5400
Nov 25, 2008 | Avaya Partner Transtalk 9040 cordless...
Cell Phones Logo
203 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
