Question about Endless Summer 2009 Open Flame Patio Heater
How do I unfreeze the brass connection on the pressure regulator hose from the galvanized(?) fitting at the base of the pipe running up the shaft to the heater assembly? I have two of these heaters that I purchased in Moscow, Idaho in the mid 1990's. The flame does not stay lighted and gradually goes out on both heaters; I presume that the pressure regulators need replacing, but the brass fittings cannot be unscrewed from the galvanized fittings at the end of the pipes. I have plenty of good wrenches, and I have done plenty of home plumbing.
    Brigadier General:
  • 4,736 Answers
It's probably not the pressure regulators, as much as the pilot assembly and burners need cleaning. In addition, the Thermocouple(s) may be giving up the ghost and should be replaced. As far as the brass fitting to the "galvanized" pipe is concerned, that's a Black Iron fitting. Galvanized pipe or fittings are not approved to be used with gas. As a matter of fact, depending on where you live, Galvanized piping is not approved any longer for potable (drinking water) water piping
Once you turn the tank(s) OFF and disconnect them from each heater, to perform the maintenance I mentioned above. When you reconnect the hose to the tank, turn the tank valve ON VERY, VERY SLOWLY (Slow motion, slow), until the valve is fully open. Then light each one as you normally do and turn the burner(s) to high.
If you find you need Themocouples, you can purchase them from Blue Rhio, the manufacturer of Endless Summer heaters.
Hope this helps you to accurately troubleshoot and solve the problem. Please let me know.
Posted on May 27, 2011
How to stop water hammer
Connect hose-to-galvanized pipe adapter to shut off valve at washing machine.
Install galvanized 45 or 90 and then attach vertical 18" pipe with cap.
Then install galvanized-to-hose adapter and connect washing machine hose.
Crude illustration:
http://waterheatertimer.org/images/Add-air-chamber-1.jpg
Gene
h
Dec 04, 2013 | Water Heaters
Tip
Brass Tube Fitting
The essential step of tube fitting production include heating, melting, mixing and conveying the raw material into a particular shape. It is important that this shape is maintained during the cooling process. All Brass tube fittings are made in accordance with ASTM standards. All diameters of solid wall Brass tube fittings are continuously extruded through an annular die. Thermoplastic fittings are either injection or compression molded. They are fabricated using section of pipes or machined from molded plates.
Om Tubes Brass Tube Fitting connects different types of tubes to one another. It can be used for in-line, offset, multi-port, and mounting configurations. Various tubing sections like pipe, hose, or other components are connected through tube fitting. Usually the system is configured with straight sections connected by fittings or some specially formed connections and joints. Om Tubes being Brass Tube Fittings Distributors provides you with best quality & services. Products at Om Tubes are of various wall types and all are produced in accordance with the requirements of a variety of industry standards and specifications like ASTM and AWWA. We sell Good Quality Brass Tube Fitting at Om Tubes.
http://omtubes.com/brass/brass-tube-fittings
on May 08, 2017 | Miscellaneous
Can i flush my water pipes out using bicarbonate soda ,from the mains supply to my house,as i have blue green stains in shower ,basin ,toilet ,a blood test shows a copper reading of 23.1, in bloodstream ,...
Flushing pipes won't help this problem at all. What you're seeing is electrolysis, caused by galvanized pipes connected to copper pipes. A tiny electrical current (like a little battery) is created that causes copper molecules to corrode from the inside of the copper piping. You need to install an electrolytic union (breaks the electrical connection between the galvanized and the copper) at each of those connections. This must have started after some plumbing was done where copper was used to replace galvanized. That's the place to look and that's where you'll find this problem. Do this soon -- the blue/green stains are copper that's been corroded from the inside of your copper piping which will soon start leaking as a result. This could also happen at a water heater, which should have an electrolytic union at EACH connection (Hot, Cold and Drain if there's a recirc. system). Don't let someone tell you a brass fitting does the same thing -- that's an old plumber's wives tale that isn't true. Google Electrolytic Union to see what the fitting looks like.
Feb 19, 2018 | Home
Water pressure decreases as the water runs
Probably a clog in galvanized pipe.
Expansion tank is not whole-house pressure regulating tank. It is localized protection for plumbing exposed to high pressure caused by very hot water.
If you house has pressure regulating valve, then that can be a cause.
For low water pressure in household, the following link might help:
http://waterheatertimer.org/Low-hot-water-pressure.html
Aug 07, 2011 | Amtrol ST-12-C THERM-X-TROL ASME Expansion...
5 gallon compressor broke underneath regulater the double threaded metal piece that accepts all the fittings broke! can it be fixed or where can we find out what part it is exactlY?mastercraft vertical 2...
Mine ( Square-D PUMPTROL REGULATOR) used a standard galvanized pipe fitting called a straight 1/4NPT pipe in many lengths availabe at places like RONA and HOME DEPOT. Brass ones are less common but way better for the purpose as you don't want black scale corrosion anyware near the diaphram in th bottom of the regulator. The outside pipe diameter is a little more than half and inch but just check with a T from another bin in the store which has the 1/4 stamped right into the metal. They may have used thin wall steel pipe which is no good when you are using pipe wrenches!
Mar 28, 2011 | Garden
I have a hotpoint hot water heater it's about 6 years old. When I turn the hot water on it runs very slowly the water pressure is very low and it's like this throughout the house how do I fix this problem...
You have clog in the water line.
Since all hot water pipes are involved, clog is probably near water heater.
Buy pressure gauge at hardware store that threads onto hose connection.
Brady BTG 100 at Amazon
Picture of gauge
Check outdoor pressure for baseline pressure in your home.
Turn off electricity to hot water heater for an hour or two so there is not scalding water.
Open drain valve on water heater to see if water heater is clogged with sediment.
http://waterheatertimer.org/Water-heater-will-not-drain.html
Put pressure gauge on drain valve and compare with outside pressure.
Open hot water spigot on bathtub and see if tank pressure drops ... if tank pressure drops significantly with bathtub spigot on, then clog is on incoming cold water before tank, and could be on outgoing hot water pipes too.
If tank pressure stays about the same, then clog is on outgoing hot water pipes.
Clog can be sediment caught in cold water shut off valve located above tank. Open and close valve and test pressure again. Take apart incoming cold water pipes above tank and check for sediment. Replace valve. Look at condition of cold water nipple on top of tank.
Sediment caught at hot water elbow near tank.
Sediment can fill up old pipes. Take apart hot water pipes above water heater and see condition.
Look at condition of hot water nipple on top of tank.
You may have to take apart pipes up to first or second elbow.
Pipes can decay at joint where copper pipe connects to galvanized pipe. Check for copper to galvanized connections on cold or hot pipes and replace section of galvanized pipe. Copper pipe will probably be good, the galvanized pipe will deteriorate. Replace copper-to-galvanized joint with 3/4" non-conducting union from hardware store
Dec 06, 2010 | Water Heaters
The hose leading out of the water heater on the inside of the trailer has rusted off. My dad has in the past use epoxy putty to repair it but it has come loose again and I would like to know if and how it...
Coming out of the back should be a 1/2" NPT short nipple, or a check valve with 1/2" NPT threads. ( NPT = National pipe thread. Just ask for a 1/2" galvanized pipe nipple the right length.(short, or 2" usually) If it's a check valve, it will usually be brass or plastic/nylon. I prefer galvanized just because the tend to hold up better. Most water lines connect to that, unless yours has a different fitting such as a female flare going to a male flare fitting in tank. Either way, you'll have to get old one out and match it, to allow for water line fitting to re-attach, or change end of water line to proper fitting to attach to nipple. Without seeing exactly what you have, I can't explain exactly what you need to do.
Nov 01, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Will a compression fitting work on 1/2'' galv. pipe?
They do make a compression coupling for galvanized pipe, but I don't trust them very much. When you unscrew the joint with a pipe wrench just make sure to back it up with another, so you don't start to unscrew the next joint back.
Oct 04, 2009 | Plumbing
I have a older home with very slow hot water flow. Is there anything I can do myself? The pipes are cast iron.
Have you tried removing the aerators from the faucets and cleaning out the sediment. You can also drain down the water tank to try and remove any sediment that has settled in the bottom.
Sep 21, 2009 | Plumbing
How can I connect a 20# tank?
lp gas hose, regulator, pipe fittings to adapt the hose to your heater.. use brass fittings.
Mar 08, 2008 | Procom 10K BTU, Vent Free, 2 Plaque...
Endless Summer 2009 Open Flame Patio Heater Logo
107 people viewed this question
Top Endless Summer Heating & Cooling Experts
Paul Carew
Craig Butler
Craig Butler
Are you an Endless Summer Heating and Cooling Expert? Answer questions, earn points and help others
