Question about GPS
I have nuvi 650. It is in Pre-Boot Mode: I've been holding Power button for at least 3 minutes, but display not flicker, "Pre-Boot Mode" still on the screen.
  • 4 more comments
  • kaganova May 27, 2011
    the problem is that I cannot follow even 1st step, because I cannot turn off my nuvi: it doesn't respond at all on pressing power button. The screen is frozen and says: "GARMINtm" with blue up-arrow above "N" and "Pre-Boot Mode" on the bottom of the screen.
    What else I can try?
    Thank you!
    I cannot follow even 1st step because my nuvi doesn't respond to pressing power button.
    Windows do not recognize my nuvi, so I downloaded and reinstalled USB driver fromhttp://www8.garmin.com/support/download_...
    I tried also to reinstall a firmware; the WebUpdater found the device "nuvi 650 (Unit ID 3407830423)". But at the end of installation dialog it says: "The update file is corrupted".
    Windows doesn't see the device.
    So Nuvi looks comletely dead...
    Can I do anything else?
    Thank you!
    Thank you!
  • kaganova May 28, 2011
    I contacted Garmin, and they said nothing could be done with my nuvi online. They suggested me either send it to them for repair or yet better buy a new nuvi 1350 (analog of my 650).
    Thank you!
    Thank you!
    Thank you!
  • 17,970 Answers
Here is the procedure how I find it:
1. Power OFF your Nuvi.
2. Press and keep holding the most right upper corner of the LCD screen
3. Power ON your Nuvi but DON NOT release your finger either from Power button nor from LCD screen (keep both pressed until the procedure ends)
4. You will notice Nuvi boots in Pre-Boot mode. Now quickly connect your USB cable. Prior to that make sure you have the latest Garmin USB drivers installed on your PC (it comes with MapSource software)
5. If you managed to connect your USB to your Nuvi when it is still in pre-boot mode, you will see that Windows recognizes a new device - "Garmin GPS unit" and starts searching for drivers. Nuvi after a while turns the pre-boot mode off, but nevermind, finish installing the windows drivers. If your are using XP just click "Automatically install driver software" and when it says "Your Hardware is ready for use" you can unplug your Nuvi.
6. Drag the "nuvi_sys.rgn" file over "Updater" and select USB.
7. Now repeat steps 1-4.
9. Updater will recognize the unit then you can press Update button
10. Once the "Loader" text appears on your Nuvi, you can release your fingers from LCD right upper corner and from Power button.
11. Wait until update finishes, then disconnect your Nuvi.
If this isnt work, I can offer two suggestions:
1.- If Windows doesn't recognize your Nuvi, then reinstall the usb drivers that can be downloaded from Garmin's website.
2.- If you can get the computer to recognize the Nuvi, run Webupdater and reinstall the firmware even if you already have the latest version.
The Garmin website has USB drivers (for all Garmin GPS units) here: garmin.com/support/download
Hope helps.
Posted on May 27, 2011
  • ZJ Limited
    ZJ Limited May 27, 2011
    If the upgrade file is corrupted, and you download this from Garmin site, I suggest ask and concact with the Garmin Support for some solution tip (generally is free); some users recommended not use WebUpdater for upgrade.
    Keep in mind this quote post:
    I contacted the local Garmin support rep and I was given the following sequence to recover from this condition:
    1. Power off the unit.
    2. HOLD down the power button and you will see "Pre Boot Mode" appear on
    the lower part of the display. KEEP HOLDING the power button down and
    the display will flicker, do this until the pre boot mode message
    disappears. This seems to take a long time (60 seconds at least).
    3. Once the pre boot mode message disappears release the power button
    and your device will perform some activites to recover from the above
    problem.
    Apparently this sequence will only work with the above error. I hope this assists other if they encounter this problem.
    I still don't know why the firmware upgrade process failed BUT after
    performing the above sequence I found that the firmware upgrade had
    actually worked (strange).
    Keep us updated.
  • ZJ Limited
    ZJ Limited May 28, 2011
    That, in part, is good news. You need to evaluate this proposal to take your desicion. Good luck and thank you for using Fixya.
My Garmin Nuvi 650 has given me a message system software missing. what do i do to get it and what happened for it to go missing???? thanks pb
heres and update click on the link http://www8.garmin.com/support/download_details.jsp?id=1921
or try doing this
2. HOLD down the power button and you will see "Pre Boot Mode" appear on the lower part of the display. KEEP HOLDING the power button down and the display will flicker, do this until the pre boot mode message disappears. This seems to take a long time (60 seconds at least).
3. Once the pre boot mode message disappears release the power button and your device will perform some activites to recover from the above problem.
I still don't know why the firmware upgrade process failed BUT after performing the above sequence I found that the firmware upgrade had actually worked (strange).
Mar 28, 2011 | Garmin Nuvi 660 GPS Receiver
No voice to Garmin Nuvi 660
In case it is a software problem try this and see if it will fix it......follow these steps.
3. Once the pre boot mode message disappears release the power button and your device will perform some activites to try recover from the problem.
Jan 17, 2009 | Garmin Nuvi 660 GPS Receiver
No voice directions
In case it is a software problem try this and see if it will fix it....Try this and see if it fixes your problem...follow these steps.
Jan 03, 2009 | Garmin Nuvi 660 GPS Receiver
Have Garmin Nuvi 660, after a few min. I lose sats. was working fine for the last year. Just the other day it started. I was in the mountains/ bad weather so I thought that was the problem. I have update...
Dec 24, 2008 | Garmin Nuvi 660 GPS Receiver
After 2 - 10 Minutes Satellite connection is lost
Try this and see if it fixes your problem....first disable bluetooth then follow these steps.
Dec 19, 2008 | Garmin Nuvi 660 GPS Receiver
Acquiring satellites
Oct 19, 2008 | Garmin Nuvi 660 GPS Receiver
Nuvi 660
it should take no longer than 2 minutes max to get a reception when turned on.
check the specs in your book some have 4-12 satellites the more the faster and more accurate it is.
3 possibilities
1-remote location
2-lot of steel or tall buildings
3-defective
Aug 12, 2008 | Garmin Nuvi 660 GPS Receiver
Nuvi 660 not locating satellites
Try this and see if it fixes your problem...first disable bluetooth then follow these steps.
3. Once the pre boot mode message disappears release the power button and your device will perform some activites to recover from the problem.
Dec 25, 2007 | Garmin 010-00358-00 GPS Receiver
Garmin nuvi 660 personal travel asistant
Are you running this unit while it is charging? Does the Nuvi 660 have a sufficient charge?
Try to do a hard reset on the unit.
Dec 13, 2007 | Garmin iQue 3600 GPS Receiver
GPS Logo
412 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
