Question about HP Pavilion zd8000 Notebook
Hpzd 8000 does not turn on...it is getting as soon as i turn it on....
The laptop blue signal turn on , and inmediately turn off
  • Anonymous Aug 19, 2008
    Mine does the same thing. I will try the suggested solution.
My Zd800 did the same thing and I figured out that the power adapter connection was flakey. I move it around in the back and finally the blue light stays on. I actually replaced one power adapter thinking it was out...turned out to be the connection to the back of the computer. I have tried other power adapters and same results. Considering taking the thing apart and soldering the wires. This computer has been a royal pain the a$$ since I bought it. I will try another laptop manufacturer on my next one. Any suggestions?
Posted on Aug 19, 2008
SOURCE:
PASSWORD bios toshiba satellite C845 D- SP4186SM
Type your password otherwise you will stay locked out.
Dec 29, 2013 | Toshiba Satellite Computers & Internet
Freemotion 790 Interactive treadmill belt squeaks as soon as you turn it on
Inmediately LUBE the deck belt, this happen because the lack of maintenance schedule, see your instr. manual and follow the steps.
2) Lube the rollers bearing use the wd-40
see the video attached.
God bless you
Dec 07, 2012 | FreeMotion 790 Interactive Treadmill
Blue screen when boots up how do i restore computer to factory settings
Hello:
Start your Latitude and maybe a blue bar will appear at the top of the screen like: www.dell.com. Inmediately you see this, try to press F11 to begin the restore utility. Or simply keep pressing this key just after you switch on the laptop.
I hope this helps. Thanks
Feb 14, 2011 | Dell Latitude C400 Notebook
How do i restore to factory settings on windows 7 starter on a dell inspiron mini?
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer)
or
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
Hope this helps
Feb 01, 2011 | Dell Computers & Internet
Battery charger says charged. camera will not turn on
Hi there i can 't get your these word." camera charger is blue, used battery and new,". Please let me know the battery is new or or its old? If its old then the battery life is finished. Thats why he can't store the power.
Thanks.
Feb 15, 2010 | Olympus Mju Tough 8000 Compact Digital...
Problem just started. Getting na signal on TV.
1. Remove the video/display cable from both TV & Laptop.
2. Again Connect the two devices properly.
3. Press "Function Key+F5" to connect to the TV (External Display)
4. Also put your TV in "TV/AV" mode.
tell me if it don't helps...tc! :)
Jan 05, 2010 | Toshiba Laptop Computer Battery PA2510,...
Gray screen
alternate click on " MY COMPUTER" then properties, the hardware, then device driver, click on video , alternate click on the unit and select updae driver
Apr 12, 2009 | Dell Inspiron 8000, 8100, 8200 Series...
Laser mouse 8000 won't connect to blue tooth
try to check whether the drivers are properly installed
Mar 11, 2009 | Microsoft Wireless Entertainment 8000...
HP Pavilion zd8000 Notebook Logo
70 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
