Question about Thermador Kitchen Ranges
Hi need a lpg kit for a thermador model prds486 and need it shipped to europe
  • 1,998 Answers
That would depend on which part you are looking for I can attest I have repaired these often and if your looking the the oven control switch I wish you great luck in finding this part due to thermador discontinueing the part after the 5 th year this unit came out although If you are unable to find the part going through thermador http://www.thermador.com/ this next link i have found actually makes discontinued parts so it may be well worth contacting them if the piece you are looking for is discontinued http://www.erepco.com/ if you have any further questions or unable to find your part useing either of these two sites message me back and I will look further into your problem and I await your reply Thanks Rick
Posted on May 27, 2011
Hi all i have a AGA MASTERCHEF Model 100 DF Serial number D0000124 and cant find LPG coversion Kit AGA says no kit can anyone help please Mal
Hi I have the same problem - mine is LPG and I need to convert it to NG... if anyone has any solutions I would be really grateful.
Thanks - Juliz
Feb 03, 2013 | Kitchen Ranges
Oven is Electrically charged Or Uses LPG domestic Gas?.
GS460 is not the full model number for the range. The range needs both electrical power (120V AC) and gas. The electric power is used for the burner igniter and controlling the range thermostat.
The GS460LEK can be used with either NG or LPG. It came with the NG orifices installed at the factory; a conversion kit needs to be installed to use LPG. (The cap in the regulator also needs to be turned 180 degrees to read LP.) This should be done by a trained installer. Most Whirlpool ranges will have the conversion kit attached on the back of the range near the regulator. See the installation guide from Whirlpool for your model, try https://www.whirlpool.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchView?catalogId=10561&langId=-1&storeId=10211&krypto=m3wLp9EUOpUUfCAXtvB5kw%3D%3D&ddkey=http:OCManualsLiteratureSearchView .
The installation guide for the GS460LEKQ0 is available at https://www.whirlpool.com/digitalassets/MLPDF/Installation%20Instructions%20-%208522956.pdf .
I hope this helps.
Mar 28, 2012 | Whirlpool GS460 Gas Kitchen Range
What is the product # for the conversion kit from nat gas to lp? who carries this item? Does the conversion kit come with a regulator?
Some Thermador ranges are not field convertable from natural gas to LP. The PRG364EDG falls in this category. If you have one that is not convertiable; you will need a different range.
The PG364GEBS is not a listed unit at Thermador; I've found it for sale at AJ Madison. Since that vendor doesn't list the conversion kit (and they sell ones for other Thermador ranges), I do not believe this is a field convertible unit.
Thermador has manuals and installation guides for many of their appliances here: http://www.thermador.com/trade/specifications-guides . Most Thermador ranges come with the installation guide, as well as the owner's guide, if you still have your documentation. Otherwise, try the Thermador site for the documentation (check if the company uses a different part number internally). If the conversion kit is available, the part number will be provided in the section on the Gas Requirements and Hookup. If it isn't, the installation guide will clearly state that fact.
Other models are convertible. The PRD304GHU uses the conversion unit: PALPKITHC. You will need to confirm your model since the number of orifices will depend on the number of burners and the low simmer feature. (The PRD304GHU is also a 4 burner with 2 of them extra-low simmer burners model.)
For units that are convertible, you can usually order the part through the same stores that sell the appliance. Alternatively, have your gas service installer order the parts. The installation guide for the conversion kit will be included in the kit. For most ranges that are field convertable, the regulator converts from natural gas to LP by rotating a cap in the regulator by 180 degrees. (Take out the part, turn it over so that LP shows and reinstall.)
I hope this helps and I wiish that I had better news for you.
Mar 03, 2011 | Thermador PG364GEBS Stainless Steel Gas...
Is there a recommended type of LPG kit for 2004 BA Futura? What are the potential issues with fitting LPG to this model?
All LPG kits are custom to vehicles they are being installed on. The possible problems are the same with all models. They include Leaks, lose of Mileage and the obvious dangers of filling the tanks when needed. I will tell you this much, it is unlikely you will save any money converting to LPG as most conversions get far less mileage than they do on regular fuel. Also, a Conversion kit is a full conversion. Once installed you are not going to have the option of switching between the two when the LPG system fails. You would think with the faster burn rate you would have better acceleration in LPG vehicle and better Mileage since the Typical LPG fuel is a higher burning and cleaner burning fuel but in reality it it usually just the opposite in conversions and they have a tendency to vapor lock more often.
Sep 20, 2010 | Ford Futura Cars & Trucks
What part do i change when convertin a ranni propane gas to natural gas
I think the part numbers listed in the solution are LPG injectors.The orifices (injectors) needed to change over from Propane (LPG) to Gas (NAT.) would be 2 High Injectors 100F-2031-B-1.80 and one Low Injector 1004F-2036-B-1.95.
Feb 17, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
What are the conversion rates from gas to lpg for our Prima LPR851 Hob? so we can fit our kit
wat gas?natural to LPG call the service center of the unit to buy an injectors nozzle want u want(LPG to natural or Natural to LPG)tell the model of ur unit.
Sep 08, 2009 | Cooktops
Is there a conversion kit from lp to natural gas for this model VM450SSP
Usually there are no conversions for LPG - NG on BBQ units. You need to contact the manufacturer about this and then get a 'Gas Safe' engineer to carry out the conversion.
The reason for this is that LPG is a higher pressure (37mb) than NG (20mb), and stringent testing must be carried out for leaks etc.
I hope this helps
Jul 07, 2009 | Vermont American Tool Company VM450SSP...
Natural gas to lp conversion kit for a Thermador GGNCV30 cooktop
Your LP gas provider will get the orifices for you just call them with the model number of your thermador. They have gotten them for me many times.
May 07, 2009 | Thermador SGS36GS Gas Cooktop
Thermador PG484GGBS: How to convert from Natural Gas to LP?
I just did it with mine, I called thermador and they told me the number of the conversion kit to buy for my model.
I bought the kit from the retailer and did it myself, not very difficult.
no explosions yet :)
nic
Dec 25, 2007 | Thermador PG484GGEBS Stainless Steel...
Kitchen Ranges Logo
222 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
