Question about Salter 200 - 400# Mechanical Bathroom Scales / Analog Bath Scale
The mechanism to reset the scale to 0 is stuck. There is no way to turn it without breaking the gear. Is this fixable?
I have a Seca model 707 waist high digital scale and starting last month it started going 5 lbs heavy for a few weeks than the correct weght now its back to about 5 lbs heavy. is this fixable?
get out the operation manual and look in the index or glossary for the "calibration" routine. it is a failry simple process of recalibration. As these units age the solid state components inside chage a little bit. it needs to be reset, that's all
Mar 11, 2011 | Seca 710 Waist High Mechanical Balance...
Resetting the scale to 0
mcdevito75 here, There should be some sort of knob or screw near the weight indicator too reset the indicator to zero. Make this adjustment without any weight on the scale.
Jun 23, 2010 | Terraillon TFA Nautic Body Fat Scale
Taylor 7532S, battery replaced, error message 0-Ld
Try to reset the unit. Use the following steps
- Open the battery compartment on the bottom of the scale. Push the tab on the door and lift the cover.
- Remove the battery from the compartment. Close the battery compartment door.
- Sit the scale right side up on a hard surface floor.
- Step on the scale and stand still on it for five to ten seconds. Step off the scale.
- Turn the scale over and open the battery compartment. Re-insert the battery. Close the battery compartment cover.
- Place the scale right side up on the hard surface floor.
- Press one foot on the scale until the display shows zeroes or dashes. Remove your foot.
- Wait for the scale to shut off by itself. When you step back onto the scale, it will be reset.
Hope this solution has been helpful?
Jan 26, 2010 | Taylor 7532 Ultra Thin Glass Digital Scale
The cd disk ia stuck
Unplug unit from AC wall socket for minute or so to get it reset, replug it and turn it On that might reset CD mechanism and stuck CD come out.
If that does not solve the problem, CD mechanism will be inspected for any gear damaged that causing problem. You may be need tech to fix it.
Thanks.
Nov 29, 2009 | Sony DAV-HDX500 System
Tray wont open makes a buzzing sound
usually this is cuased by a mechanical jam of the running gear of the tray, sometimetimes firmly pulling the tray out will fix the problem but sometimes this can break it completely. If it was me I would open the unit and take the mechanism apart to free it but this does rely on some technical ability and noone without electrical knowledge should really open these type of products. the buzzing is generally the motor working hard to push against the stuck tray.
Nov 23, 2009 | Audio Players & Recorders
Ryobi AP12 Thickness Planer---rubber feed rollers do not rotate
It is fixable if you are technically competent. All parts are still available online. It could be one of two problems:
1 - The rollers are driven by two gear & chain mechanisms on the height adjuster side of the unit. I did have a drive chain break once.
2 - If it isn't that than the gearbox has cracked / gear stripped under the torque load. This is also fixable, each individual gear and the gearbox housing are still available (10-09), but it requires substaintial teardown.
As you disassemble the unit just be careful once you remove the crossover height adjuster shaft - you don't want to turn one lifter by itself and have the planer higher on one side. It really is a simple teardown, just lots of parts. If you like the planer it is worth it; parts are cheap. If you are like me, you enjoy tearing stuff down to see how it's made and you hate throwing out $200 tools because only one little part broke!
Aug 06, 2009 | Tools & Hardware - Others
Resetting the scale
You do not reset the scale. It only saves the last recorded weight of the user. So, if you weighed yesterday, it will put your recorded weight in memory. The next time you select your user number and step on the scale, it will compute the difference from your previous record and save your current weight.
Jan 24, 2009 | Health & Beauty
Left Deck Door Stuck Shut on Cassette Deck
The cassette mechanism has a large gear that rotates to different positions for the different modes. On time around is a play - stop cycle. It is stuck in one position and won't come around to the stop spot. Need to take the cover off and help it to turn to get the cassette out. Then figure out if something is wrong preventing it from turning or if the wheel driving it is the problem. They are all a little different so this is where your mechanical apptitude comes in.
By the way, you'll figure out right away they don't intend these things to be fixed.
Hope Ya Fix It.
Feb 04, 2008 | Audio Players & Recorders
Tape "was" stuck and now it's worse
What may have happened is, that in the process of forced removal, gear timing has been fouled up, assuming the cassette carriage is gear driven. Proper gear positioning is critical, and if it is off by one or more teeth, it won't load the tape properly. Often, there are marks or pointers on the gears which must be lined up, in a particular mode, as specified in manufacturer service literature. If there are gear teeth broken, or cracked gears, then they must be replaced. Servicing in such a case is questionable, as VCRs of the past 10+ years are poorly made, prone to break, disposable. Early units, like back in the '80s, were much higher quality, especially mechanically. Unless this is a high $$ rig, you will probably be better off trashing it, and purchasing something else.
May 24, 2007 | Hitachi VTMX4510A S-VHS VCR
Salter 200 - 400# Mechanical Bathroom Scales / Analog Bath Scale Logo
54 people viewed this question
Top Salter Health & Beauty Experts
traccie
Level 1 Expert
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Salter Health and Beauty Expert? Answer questions, earn points and help others
