I am using samsung syncmaster 2233 ..but in ubuntu,its resolution is not correct.I cant see some data.I tried "moniter settings" and "display" in ubuntu..but when i select proper resolution my moniter shows some lines...nothing is clear....what will i do??? i know you have an answer
  • 205 Answers
SOURCE: moniter says out of frequency set resolution lower or see user guide
The settings you need to change are actually on the computer's video hardware. Assuming you are using a Windows machine, right click anywhere on the desktop. Select Properties, then the Settings tab. You should see a resolution slider that you can adjust. There should be an Advanced button that will give you access to other settings that are possible with your hardware. This is where you can adjust the frequency.
If you are unable to see anything because of this problem then you may need to boot into Safe Mode to correct this. Let me know.
Good luck.
Posted on Dec 22, 2007
SOURCE: Display Resolution
samsung syncmaster 510N nonoptimize mode recomended mode :-1024x768 60hz how can i fix this?
Posted on May 21, 2008
carputers
  • 255 Answers
SOURCE: no sound on my samsung Syncmaster 2233 monitor
check output from computer with another set of speakers.
Posted on Sep 08, 2009
SOURCE: want samsung 17"syncmaster 794mg default
press menu button and hold it above 6sec
Posted on Jan 30, 2011
mace1mace
  • 1138 Answers
SOURCE: I have two monitors. One Samsung SyncMaster 2233
hello Gabriel
Could you check your SyncMaster 2233 for me and tell me your findings. If this monitor is connected from your computer and when both switch on, did the led indication lamp from your monitor lit steady green? or this lead indication lamp lit green then turns red?
1. If the led indication lamp lit steady green then there is nothing wrong with the settings, configurations, driver or hardware on your computer. The problem would be the backlight inverter lamp in your monitor is busted. Or it could be the inverter board that supplies high voltage for the backlight inverter lamp that is bad. You can replace the backlight inverter lamp located at the upper and lower part of the monitor with a replacement part you can purchase at shoppejimmy.com. Inverter board repair can be risky if you don't have the skill. Even opening the back cover of your monitor and replace by yourself the inverter lamp is risky too, could inflict more damage. you can bring it to a local professional service man.
2. If the led indication lamp lit green then turns red, then if not the video card the power supply section from your monitor is bad, you can replace polarized capacitor with same value. Just inspect and those with blown or leaking capacitor. You can also check the terminals and solder joints for the 15-pin vga terminal connector where vga cable is connected on your monitor. Resolder the terminals.
3. If the red indication lamp did not lit at all. Power supply section in the monitor is bad. You can check the output voltage from the power supply section. +5VDC is supplied for the main board and +24VDC is for the inverter board. Replace leaking or blown capacitor with same value.
Just remember, this should be done when computer and monitor is turn off
Post back if you have more questions. I am willing to give you assistance.
Posted on Feb 10, 2011
Mac mini is not showing the display(moniter using syncMaster 940bw moniter)
try to adjust the resolution settings of your mac mini using other monitor.It works for me
Sep 14, 2011 | Samsung Computers & Internet
"Not Optimum Mode","Recommanded Mode 1280
FIXED : Before you start your legacy game, software where the "Recommanded Mode 1280 x 1024 60Hz" keeps showing, change your display FROM VIDEO CARD DISPLAY control application to 1024x768 or your choice.
My Syncmaster 2233 had same problem of "Not optimum mode" box coming on whenever I started any old game like Age of Empires etc. It got fixed by selecting FROM DISPLAY CARD DRIVER CONTROL UTILITY's (mine from Catalyst Control Center) >Set desktop area to > 1024 x 768 in my case BEFORE STARTING old application/game. Switch back to your normal resolution after you are done with this application.
Hope this helps.
Regards
Saurabh
Jun 29, 2011 | Computers & Internet
I am trying to connect a samsung syncmaster 151v to my computer and the moniter reads video mode not supported what am i doing wrong?
Your resolution is set to high for the monitor to accept it. Go into control panel and click on Display then click on display setting and lower your resolution keep going lower until your monitor accepts the resolution size and your monitor should work for you.
I hope this helps you out any positive feedback to me would be greatly appreciated.Thank you
Apr 09, 2011 | Samsung Computers & Internet
My samsung syncMaster 753s moniter does not support resolution of xp what i do further
Your monitor can easily support Windows XP resolutions. The problem almost certainly lies in your video settings. You need to lower your screen resolution and/or refresh rate.
If you can not start Windows due to this problem, you will have to start Windows in VGA compatibility mode. Follow these steps:
  1. When your PC starts up, press F8 a few times
  2. This will bring up a menu whereby you can select VGA mode from the list
  3. Once you are logged into Windows, right click anywhere on the desktop & select "properties"
  4. Then go to display settings & select a resolution of 1024 X 768.
  5. Go to advanced settings and make sure your refresh rate is no more than 70 to 75Mhz
  6. Restart Windows normally & your display should be correct.
Let me know if you have any further questions.
Best wishes,
Graemevm
Mar 30, 2011 | Samsung SyncMaster 753S 17" CRT Monitor
Samsung SyncMaster 2233SW Monitor "Not
The "native" resolution of the monitor is the "optimal" resolution -- it looks best to use this resolution.
So, right-mouse click anywhere on your Windows desktop "wallpaper".
Click Properties.
Click Settings.
Move the "Screen Resolution" slider to the recommended settings.
Click Apply.
Click OK.
Nov 21, 2010 | Samsung SyncMaster 2233SW Monitor
Blurred image in Samsung Syncmaster732nw monitor
For best pictures, you need to set your PC video resolution to the native resolution of this monitor, which is 1280x1024 @60Hz. Try that first before opening up the monitor to look for bad components.
Post back, see what usually goes wrong with SAMSUNG monitors: http://s807.photobucket.com/home/budm/allalbums
Mar 29, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
Samsung 244t Monitor display issue
if the monitor will match well with Nvidia GTS8800 graphic card, you need to consider two issue:
1) resolution match from windows display property and moniter manu same one.
2) refresh frequency match from windows display property-->advance-->monitor and monitor manu--> refresh frequency
if two side setting could be all matched that you can use normally
if two side setting could not be matched any above step that you can not use some resolution normally possible.
hope help you something fixed, please take a rating let me know how much helped you thanks! keep in touch your question
May 29, 2009 | Samsung SyncMaster 244T 24" LCD Monitor
Prob with screen resolution
options listed would be correct for that monitor if you installed the drivers and inf file for the display. if it is another monitors resolution settings then you may just have the wrong monitor installed
Jan 30, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Computers & Internet Logo
163 people viewed this question
David Payne
David Payne
